North Carolina Woodworker
Changes to DQ as of 12/1/2008 Very important that you read
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
Notices
» Announcements
Everyone Log on at 9:00PM Thursday December 4th to set a members online record.
Featured Photos
by JRD
24826 photos
9957 comments
by gordonmt
508 photos
12 comments
by TracyP
24826 photos
9957 comments
by tmerrill
24826 photos
9957 comments
» Online Users: 34
2 members and 32 guests
JOAT , Steve Martin
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 11-07-2005, 09:31 AM   #1
Advisory Panel
clowman's Avatar
City: Willow Spring
State: NC
County: Wake
Threads: 179
Avg Visit Freq/Week
= 5.83 over 30 days
The perfect mitre. You know, the kind that are machine made. The kind you see on picture frames. I want mitres that are tight, elegant. While I realize nobody can tell me what my problem is. Ok, maybe you can, but what I am looking for are tips, tricks, techniques to accomplishing this elusive task.
Here is what I have tried. I have set both my table saw mitre gague and my mitre saw that I am pretty sure cut on an accurate 45 angle. ( I say pretty sure, cause if it does in fact cut an accurate 45, the mitres should all fall into line when I make the frame ). I am thinking it may be my assembly method. Heck, I don't know. My problem is, that when I go to put the frame together, I nearly always have "gaps" in the joint. Usually on opposite ends of my frame, mostly on the outside edge. How do I fix this? It's definately possible that I have 2 machines that don't cut perfect 45s. I make sure that the 4 sides of the frame are of equal length, thickness, and width.
What do you people do to get nice tight mitres? Got anything to share?
__________________
-Clay
Show Printable Version Email this Page   Quote this post in a PM to clowman
Old 11-07-2005, 09:42 AM   #2
Member
Steve D's Avatar
City: Horse Shoe
State: NC
County: Henderson
Threads: 69
Avg Visit Freq/Week
= 0.23 over 30 days
Clay,
The best method I have seen uses the table saw with a dedicated sled. The sled has another piece of plywood or MDF attached on its surface that piece is a triangle with a 90 degree corner so that the blade cuts through the 90 deg. point. One side of the angle is cut on the left side and its mating piece is cut on the right side. Even if the setup isn't perfect you still end up with a 90 deg corner. You need to label the parts so the mating corners are assembled properly and as you mentioned, make sure that you have the same thickness, width and length.
This is a similar concept:
Steve D
Show Printable Version Email this Page   Quote this post in a PM to Steve D
Old 11-07-2005, 10:00 AM   #3
Monty's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 229
Avg Visit Freq/Week
= 0.70 over 30 days
Another extremely important point is to make sure the opposite sides of your frame are EXACTLY the same length - this should involve using stops to set the length. Even if your angles are perfect, a slight imperfection in the lengths of the sides will kill the tight fit.
__________________
My fledgeling woodworking web site: ShootingBoard.net
Show Printable Version Email this Page   Quote this post in a PM to Monty
Old 11-07-2005, 10:11 AM   #4
Joe Scharle's Avatar
City: Holly Springs
State: NC
County: Wake
Threads: 121
Avg Visit Freq/Week
= 7.00 over 30 days
Clay, when mine mess up it's usually because I let the blade 'push' the work. If you find that happening, you may want to try the 2 cut method. First close, second nibble. Especially for the "other" end as the previously cut miter tip will want to slide under any stop block. I always cut the back rabbet slightly oversized because sometimes after all that, I still have to 'kiss' the disc sander! And of course, then I've shortened the piece.
Show Printable Version Email this Page   Quote this post in a PM to Joe Scharle
Old 11-07-2005, 10:14 AM   #5
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 157
Avg Visit Freq/Week
= 3.73 over 30 days
The last two posts have it spot on - equal length and clamp the piece while cutting the mitre
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF
Old 11-07-2005, 10:18 AM   #6
Monty's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 229
Avg Visit Freq/Week
= 0.70 over 30 days
Um... what's a mitre?
__________________
Old 11-07-2005, 10:19 AM   #7
chris99z71's Avatar
City: Garner
State: NC
County: Wake
Threads: 162
Avg Visit Freq/Week
= 1.17 over 30 days
Or if you've got an extra $200 kicking around, I've always thought that one of these would be pretty schweet. It doesn't solve the problem of getting things the exact same length, but once it's set up, it should give a nice clean 45°.
__________________
"If you can't learn to do something well, learn to enjoy doing it poorly."
----9-11-01----343----Never Forget----
Show Printable Version Email this Page   Quote this post in a PM to chris99z71
Old 11-07-2005, 10:30 AM   #8
Advisory Panel
clowman's Avatar
City: Willow Spring
State: NC
County: Wake
Threads: 179
Avg Visit Freq/Week
= 5.83 over 30 days
You jest with me Insom
__________________
-Clay
Old 11-07-2005, 10:38 AM   #9
Monty's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 229
Avg Visit Freq/Week
= 0.70 over 30 days
Actually, I was jesting with DavidF! I didn't notice that you used the Queen's English spelling as well...
Anyway, if you're going to cut mitres instead of miters, you need to make sure you measure it all out in millimeters.
__________________
Old 11-07-2005, 10:40 AM   #10
chris99z71's Avatar
City: Garner
State: NC
County: Wake
Threads: 162
Avg Visit Freq/Week
= 1.17 over 30 days
This may make all of you want to run me out of the country, but I'd much prefer to work with the metric system...
Fractions suck
__________________
Old 11-07-2005, 10:48 AM   #11
Advisory Panel
clowman's Avatar
City: Willow Spring
State: NC
County: Wake
Threads: 179
Avg Visit Freq/Week
= 5.83 over 30 days
Ha.. I was a bit unsure of that spelling, so I looked it up before I posted. I noticed that miter ( which I thought it was ), and the defination was a queen's headress or something like that. I said to myself... "Self.. that's not it". I did of course, neglected to look down a bit further and note that there was another defination as well... What can I say, I'm just a country boy...
__________________
-Clay
Old 11-07-2005, 11:01 AM   #12
Advisory Panel
cskipper's Avatar
City: Forest City
State: NC
County: Rutherford
Threads: 424
Avg Visit Freq/Week
= 3.73 over 30 days
This sounds incredibly basic, but we fought with this on a project. It turned out that the fence was just a tiny smith off square with the saw.
__________________
Cathy Skipper
Show Printable Version Email this Page   Quote this post in a PM to cskipper
Old 11-07-2005, 11:02 AM   #13
City: Holly Springs
State: NC
County: Wake
Threads: 121
Avg Visit Freq/Week
= 7.00 over 30 days
I'm with Chris on metrics. Even the Brits who invented the 'feet' system gave it up in the '70's!
Old 11-07-2005, 12:06 PM   #14
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 157
Avg Visit Freq/Week
= 3.73 over 30 days
A miter is as in "A Bishops miter" - the popes hat is a miter.
Of coarse there is a "Bishops mitre" in wood working carried over from the stone masons craft where one leg of the molding is worked in the stile with a fake mitre, also called a masons mitre.
__________________
Old 11-07-2005, 12:09 PM   #15
Monty's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 229
Avg Visit Freq/Week
= 0.70 over 30 days
I like the way you talk.
__________________
Closed Thread
search
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
How to use the advanced search features clowman Frequently Asked Questions 0 11-08-2005 03:40 PM
How to quick search for a message clowman Frequently Asked Questions 0 11-08-2005 03:39 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,124
Threads: 16,348
2nd Top Poster: jeff... (6,350)
Welcome to our newest member, eismanius
» Today's Birthdays
cfelts (66)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
