06-27-2008, 02:39 PM
#1 |
Name: Lorraine City: Littleton State: NC County: Warren Join Date: Dec 2005 Avg Visit Freq/Week = 5.75 over 95 days | Question about splitting red oak with bandsaw I am in the mist of making a red oak display cabinet, comes from Woodsmith No. 78 if anyone has that book. The pattern allows the doors to be made without stile and rail cutter. I have a simple stile and rail cutter but it doesn't have the profile that comes on most doors and cabinets. Hope that make sense. You can see the cabinets I used on my kitchen, the pics are in my gallery. To the problem. The doors are put together with 3/8th inch pieces that go together to make the completed door. I have rough wood at 2/4 thickness and hate to waste so much. I would like to cut it in half with a 1/2hp craftsman bandsaw. Is it strong enough to make the cuts? Is there a way of making my simple stile and rail cutter work for doors with 8 panes? I would like to do that even if it doesn't have the cute profile. Thanks  Lorraine |
06-27-2008, 03:43 PM
#2 | | Moderator Advisory Panel
Name: Tom Ferone City: Raleigh State: NC County: Wake Join Date: Jul 2005 Age: 46 Avg Visit Freq/Week = 7.00 over 95 days | Re: Question about splitting red oak with bandsaw Lorraine, let me if I can help. When you say "2/4" thick do you mean 1/2" thick or 2" (8/4) thick.Your band saw might resaw the rails and styles with a wide blade and few teeth. It will be slow going I would think.
Okay, I just read the article on the doors. It is a bit unusual, but it will work and you only need a 1/4" round-over (a very common bit) and a 1/2"dia core box (round nose) bit. These are bits you might have or should because you will use them a lot (my.02 worth)
If you want to use your bits then you will need to cut out the back of the r&s to leave a rabbet instead of a groove. You need to do this carefully because you don't want to cut away where the r&s join each other. you will need to then cut dado's where the divider go.
I hope this helps. |
06-27-2008, 05:04 PM
#3 |
Name: Lorraine City: Littleton State: NC County: Warren Join Date: Dec 2005 Avg Visit Freq/Week = 5.75 over 95 days | Re: Question about splitting red oak with bandsaw I am sitting here now looking at a cabinet that is complete with the exception of the doors. There has to be a better way than the one the book shows. Maybe it is time to bite the bullet and purchase the stile and rail cutter for glass. $89.00 .gif) Tomorrow is my birthday,  maybe I should just order it for myself? You think? .gif) It's just money. |
06-27-2008, 06:14 PM
#4 |
Name: Randy Jordan City: Macon State: NC County: Warren Join Date: Jan 2006 Age: 58 Avg Visit Freq/Week = 5.31 over 95 days | Re: Question about splitting red oak with bandsaw OK Lorraine. I'll be your enabler!  If you think you will build more cabinets like these, go for the R&S bits.
I wish I knew enough about the subject to offer an alternative. Sorry...
Take care,
__________________
Randy Being "over the hill" is much better than being under it!!! |
06-27-2008, 10:07 PM
#5 |
Name: Chuck City: Rocky Mount State: NC County: Nash Join Date: Nov 2005 Avg Visit Freq/Week = 4.94 over 95 days | Re: Question about splitting red oak with bandsaw Originally Posted by toolferone If you want to use your bits then you will need to cut out the back of the r&s to leave a rabbet instead of a groove. You need to do this carefully because you don't want to cut away where the r&s join each other. you will need to then cut dado's where the divider go. The first time I made doors with glass panes I cut the stiles "top to bottom". Color and grain matching/glueing/shaping the spacers to look right was a pain.
Lorraine - Remember to stop your stile cuts short when you remove the backs. You can clean to the line with a chisel.
Chuck |
06-29-2008, 10:08 PM
#6 |
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 4.72 over 95 days | Re: Question about splitting red oak with bandsaw You do not need a rail and stile cutter for glass doors. You can use your regular rail and stile cutters, glue the pieces up, fit a temporary piece in the grooves and use a rabbetting bit to cut them out.
I bought the glass bit set and realize after the fact that it isn't anything special.
__________________ I need some additional tools. I need a
multi-spindle line borer - waiting and saving
pocket hole machine - waiting and saving
Festool sander and vacuum -tbd
Edge bander - waiting and saving` Stanley 112 scraper - got a Lie Nielsen
oscillating edge sander
floor model chisel or slot mortiser - tbd
and a bigger shop  |
Posting Rules
Members: 1,931
Threads: 15,235
2nd Top Poster: jeff... (6,003) | | Welcome to our newest member, Berta | |
