» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  | |
06-30-2008, 08:22 PM
#1 | | Question about sled for tablesaw Name: Lorraine City: Littleton State: NC County: Warren Join Date: Dec 2005 Age: 61  06-30-2008, 08:22 PM
DQ I see many sleds on tablesaws where a piece of wood can be cut leaving a true straight cut. These saws are quite large with a fence on the back and front. They appear to be as big as my table itself. I don't understand how one that large can be used unless some tablesaws are larger than mine. Mine is a Ridgid purchased at Home Depot. Am I missing something? Lorraine | | Views: 893 |
06-30-2008, 08:47 PM
#2 | | Moderator
Name: Bob City: Hillsborough State: NC County: Orange Join Date: May 2007 Avg Visit Freq/Week = 7.00 over 180 days | Re: Question about sled for tablesaw Hey Lorraine... The miter sled can be as large or as small as you want, if you make it yourself. It just depends on the size of materials you regularly cut. I've seen a bunch of plans for making these sleds all over the web and in some of the mags. I opted to buy instead of build and ended up with the Incra sled. It works fine, but if I had to do it again I'd make one like David Marks uses.
__________________
To everything... turn, turn, turn!
06-30-2008, 08:48 PM
#3 | | Treasurer
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 6.53 over 180 days | Re: Question about sled for tablesaw Originally Posted by lwhughes149 I see many sleds on tablesaws where a piece of wood can be cut leaving a true straight cut. These saws are quite large with a fence on the back and front. They appear to be as big as my table itself. I don't understand how one that large can be used unless some tablesaws are larger than mine. Mine is a Ridgid purchased at Home Depot. Am I missing something? Lorraine You can make one any size you like. Size does matter though as the larger the sled the larger the piece you can cross cut, ie the space between the front and rear fence. You put long miter gauge runners on it and you should be set. It does not matter if you have a Rigid tablesaw or a Powermatic Model 66 the principal is the same and will work. You just have to get your runners in the right place. |
06-30-2008, 09:48 PM
#4 |
Name: Jim City: Lexington State: SC County: Lexington Join Date: May 2008 Avg Visit Freq/Week = 0.12 over 180 days | Re: Question about sled for tablesaw I have two. One will cut 13 inches and the other cuts 26 inches. The small one is smaller than my BT3100 saw top and the big one is bigger. The big one is a little tougher to handle but your wood goes on the sled and then the sled goes on the saw. You have to hold it at least roughly flat but the front is well onto the saw before you cut. When you finish the cut, even my big sled is solid on the saw.
Jim |
06-30-2008, 11:04 PM
#5 | | DQ
Name: Lorraine City: Littleton State: NC County: Warren Join Date: Dec 2005 Age: 61 Avg Visit Freq/Week = 0.00 over 180 days | Re: Question about sled for tablesaw Thanks guys, I now understand. I guess I will see if a woman can handle the big sled. Thanks again. Lorraine |
06-30-2008, 11:18 PM
#6 | | Senior Administrator
Name: Bas City: Raleigh State: NC County: Wake Join Date: Aug 2007 Age: 36 Avg Visit Freq/Week = 6.96 over 180 days | Re: Question about sled for tablesaw In addition to long runners, you will also need an outfeed table if you make a really large sled. And yes, the sled should be large. Any time you cut plywood, or a large glued-up board, you'll need it. I find that even 24" is too narrow now and then.
Having two sleds is smart. A small, manageable one for 80% of the cuts, and a great big heavy beast for the large work. If it's really big, attach it to the ceiling and use a winch!  I made my sled out of 3/4 oak ply. That was a mistake. 1/2 is plenty, it doesn't need to be that heavy.
__________________
Bas.
I don't need it. I just want it.
07-01-2008, 12:01 AM
#7 |
Name: Geoff City: Greensboro State: NC County: Guilford Join Date: Feb 2008 Avg Visit Freq/Week = 5.25 over 180 days | Re: Question about sled for tablesaw I think my latest issue of Fine Woodworking (#199) has a great article on building a very cool sled. I thought it was a pain to make one, so I just bought the Jessem Master Slide.
Good luck and post picts when you're done .gif) |
07-01-2008, 09:40 AM
#8 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.30 over 180 days | Re: Question about sled for tablesaw I have both a home made panel cutter (Norm's version) and a Dubby from In-Line Industries. I highly recommend the Dubby. You can do both ninety degree and angled cuts with the Dubby. I have the video showing how Norm built his (hint, hint). It is probably the simplest there is, and works well. |
07-01-2008, 11:57 AM
#9 |
Name: Update your profile with your name City: Pittsboro State: NC County: Chatham Join Date: Jul 2006 Avg Visit Freq/Week = 2.64 over 180 days | Re: Question about sled for tablesaw Rockler is having a sale on a sled now in case you are interested. http://www.rockler.com/index.cfm?key...FQS7sgodviVqtg |
07-01-2008, 12:38 PM
#10 |
Name: Alan Schaffter City: Washington State: NC County: Beaufort Join Date: Dec 2005 Avg Visit Freq/Week = 6.69 over 180 days | Re: Question about sled for tablesaw Originally Posted by mike_wood That is a good deal on that unit! It has a lot of good features- accurate metal scale (printed or engraved?) like the Dubby, adjustable 90deg stop, nice fence with a sacrificial face and flip stop, adjustable miter slot bar. The only negative I see is it that it only comes in a left-of-blade sled.
You can't hardly make one for that price!! |
07-04-2008, 12:30 AM
#11 |
Name: Amy City: Chapel Hill State: NC County: Orange Join Date: Jul 2006 Avg Visit Freq/Week = 3.38 over 180 days | Re: Question about sled for tablesaw I want to build one like Norm's sled. It seems very straight forward. Also Tage Frid explains step by step how to make one with pictures in Book 1: Joinery page 43-44. I made a sled like this for my old tablesaw. This sled is very similar to David Marks sled. It worked well, but I made it kinda large.
Amy |
07-04-2008, 05:04 PM
#12 | | DQ
Name: Lorraine City: Littleton State: NC County: Warren Join Date: Dec 2005 Age: 61 Avg Visit Freq/Week = 0.00 over 180 days | Re: Question about sled for tablesaw I just spent birthday money so I guess I will make a sled. I think 1/2" would be best for me. I have an outfeed table behind my tablesaw so that will help. Thanks to all for the help. Happy 4th of July Lorraine |
07-04-2008, 05:34 PM
#13 |
Name: Alan Schaffter City: Washington State: NC County: Beaufort Join Date: Dec 2005 Avg Visit Freq/Week = 6.69 over 180 days | Re: Question about sled for tablesaw Don't forget, with a wide sled you may need to extend your miter slots in your outfeed table. |
07-04-2008, 08:00 PM
#14 | | DQ
Name: Lorraine City: Littleton State: NC County: Warren Join Date: Dec 2005 Age: 61 Avg Visit Freq/Week = 0.00 over 180 days | Re: Question about sled for tablesaw Allen, might have a problem there. My outfeed table consist of a work table that sits behind my tablesaw. In fact at the moment the outfeed table sits slightly lower than the tablesaw top. I understand what you are saying though. Thanks for the heads up. Lorraine |
07-04-2008, 08:21 PM
#15 | | Senior Moderator Events Director
Name: Scott City: Cary State: NC County: Wake Join Date: Jul 2007 Avg Visit Freq/Week = 6.49 over 180 days | Re: Question about sled for tablesaw Originally Posted by lwhughes149 In fact at the moment the outfeed table sits slightly lower than the tablesaw top. Lorraine if your outfeed table is the same height as the bottom of the miter slots on the saw that also would work. I have been to your shop and I would suggest it might be easier to adjust the saw height to make that happen then your work table. I would also just tack in a couple short strips to work table to keep the sled from twisting when you reach the outfeed. If you countersink screws you can remove the strips when not needed.
__________________
Making Saw Dust With a Scroll Saw
Scott |
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 3,663
Threads: 25,105
Top Poster: DaveO (14,701) | | Welcome to our newest member, Keith Senderak | |
