North Carolina Woodworker
Changes to DQ as of 12/1/2008 Very important that you read
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
Notices
» Announcements
Everyone Log on at 9:00PM Thursday December 4th to set a members online record.
Featured Photos
by TFicquette
24826 photos
9957 comments
by Touchwood
51 photos
147 comments
by striker
24826 photos
9957 comments
by SteveColes
Klingspor Extravaganza 2007
38 photos
0 comments
» Online Users: 23
3 members and 20 guests
erasmussen , Makinsawdust , tom hintz
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
LinkBack (1) Thread Tools Display Modes
Old 06-17-2007, 01:13 PM   #1
City: Rocky Mount
State: NC
County: Nash
Threads: 97
Avg Visit Freq/Week
= 7.00 over 30 days
LOML likes the plant stand from American WWer, link here http://www.americanwoodworker.com/us...nth/page2.html
This would go in the living room. I want to modify the plans, using a triangle center post, straighten the arm lines, and replace the discs used in the AWW plans with triangles. Lower set of arms would be 120 deg apart. Upper set would also be 120 deg apart and would extend in opposite direction of lower set. Lower set arms will be longer than upper.
The idea would be a triangle theme throughout, rather than rectangles/circles.
The modified plan would allow 7 plants rather than 9. I think 9 is overkill for our living room location.
Thinking bloodwood post, arms. Triangular pot bases would be bubinga. Probably use wenge accent pieces.
As a compromise I guess I could use triangular post and discs for the pots to sit on instead of triangles.
So, whaddya think about the design shape...and wood selection?
Chuck
Show Printable Version Email this Page   Quote this post in a PM to cpowell
Old 06-17-2007, 01:36 PM   #2
jglord's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 28
Avg Visit Freq/Week
= 5.37 over 30 days
Other than doing 120 degree arms being harder - i.e. 90 degree set-up is usually pretty easy - I think your idea is fine. With 9 plants, it could easily get to look like a bush instead of individual plants.
Sounds like the wood you've selected will be beautiful. I'd consider a marine finish to both protect the wood from water and to preserve the color.
__________________
"Anything worth cutting down a tree for, is worth doing right."
Cut to size, and hammer to fit.
Show Printable Version Email this Page   Quote this post in a PM to jglord
Old 06-17-2007, 02:05 PM   #3
JohnW's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 13
Avg Visit Freq/Week
= 4.90 over 30 days
Chuck,
I agree 100% that the four arm configuration is "too much" I've see this same concept in metal with the 3-arm theme minus the top pot for a total of 6 plants. Wouldn't want much more or it would be too crowded.
As you said, the triangular design allows you to easily offset the top and bottom arms which will allow your hanging plants the room to ...hang.
I think I would use disc's for the pot holders. Once the pots are there they would not be very visible and a disc with a shallow well routed out would help to hold the pots in place. Unless you are using triangular pots....
I like your wood choices for color blend. My only caution would be:
IMHO, A lot of different colors on the stand might be too busy... But as long as the colors blend it should look nice.
I'll be interested in how yours turns out. Please post a pic. This would make a nice gift for my flower lovin green thumbed mom. errrr make that a "white thumb".
Show Printable Version Email this Page   Quote this post in a PM to JohnW
Old 06-17-2007, 02:32 PM   #4
City: Rocky Mount
State: NC
County: Nash
Threads: 97
Avg Visit Freq/Week
= 7.00 over 30 days
Originally Posted by JohnW View Post
Chuck,
My bubinga is 9 1/2 inches wide. I worked out the geometry and an equilateral triangle with 9 inch sides only gives me a diameter of 5 1/4 inches for the pots. That's too small to work with.
Looks like circullar discs to sit the pots on. I like the "routed well" idea but am not quite sure how to easily make the cut.
Chuck
Old 06-17-2007, 04:36 PM   #5
JohnW's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 13
Avg Visit Freq/Week
= 4.90 over 30 days
Chuck...Another suggestion.
Craft stores sell clear plastic flower pot trays with a lip around the edge. You can attach these to your disks to hold the flower pot and water the plants from this bottom tray which is typically the best method of watering. A few stick-on rubber non-slide thingys whatever they're called, on the bottom of the tray might be all that's needed to keep them on your wooden disk. If you want it more secure, use hot glue or screw and gasket washer to hold the plastic tray down.
These trays will also help keep the water off your wooden creation. The trays are available in different colors if clear doesn't do it for you.
Keep thinking....A good plan is coming together.
Old 06-17-2007, 11:41 PM   #6
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 117
Avg Visit Freq/Week
= 7.00 over 30 days
If you do want to make a well in the disks, you can do as I did with my Wine Cellar Project "Bottle Shelves" (click to expand):
These were hollowed out using a Jasper Circle Cutter with a 3/4" Core Box bit for the hollow perimeter cut and a 1/2" straight bit to remove the remaining stock down to the last 1/4" "post" with the cutter pivot pin in it -- that was them cut off with a chisel and a small mop sanding attachment used to clean up the imperfections. This hollow is the diameter of a wine bottle, about 3-1/4" IIRC. Take your time and the results can be excellent. On key point: be careful of router bit burn on the perimeter cut -- keep the cut radius increment as small as possible and move the router fairly quickly to avoid the burn with the bit spinning in place against the wood. Bubinga is real hard, but I did these in White Oak and it went fine. HTH YMMV...
__________________
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 06-26-2007, 10:20 PM   #7
City: Rocky Mount
State: NC
County: Nash
Threads: 97
Avg Visit Freq/Week
= 7.00 over 30 days
Here's a few pics showing some progress. I'm going for straight lines and triangles...DON'T laugh!
The post, legs, and arms are in bloodwood. Discs for plants will be long grain glued onto the flats of the legs and arms, appx 7 inch diameter in bubinga. I'll make a cap for the post. I'm thinking about a flattened triangular pyramid. The stand will hold 6 small plants of LOML's choosing.
Legs and arms are attached with screws in a triangular pattern since everything is cross grain. Will plug with wenge for an accent. I have figured out why most of the ones I've seen are square post...the triangular post is a lot more trouble to work with.
I'll post some pics when I get the top and discs in place.
Chuck
Click image for larger version
ID:	3442   Click image for larger version
Old 06-28-2007, 09:13 AM   #8
City: Rocky Mount
State: NC
County: Nash
Threads: 97
Avg Visit Freq/Week
= 7.00 over 30 days
Here's a pic with a single bubinga disc. The disc is 6 inches diameter cut from a scrap piece...actual will be 7 - 7 1/2 diameter.
I don't like the color blend. The "brown" bubinga and reddish hued bloodwood don't look very good. More importantly, LOML doesn't like it.
I think ebony-colored discs would look cool. Is there a dye I could use to make the wood black?
Any other ideas?
I've looked at walnut, wenge, padauk, cherry, sapele. Light colored wood has been ruled out by SWMBO.
Chuck
Name:	bloodwood planter WIP.JPG
Old 06-28-2007, 09:47 AM   #9
Asst. Webmaster
Senior Moderator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 568
Avg Visit Freq/Week
= 7.00 over 30 days
Chuck
I have heard the India Ink is an excellent jet black dye to ebonize wood. You should be able to find it at any decent art supply store or I am sure that Transtint makes a black dye that you could use. DavidF ebonized the legs of his demilune table, maybe he'll chime in with his suggestions.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 06-28-2007, 09:48 AM   #10
McRabbet's Avatar
State: NC
County: Henderson
Threads: 117
Avg Visit Freq/Week
= 7.00 over 30 days
I'd go with Black Walnut or ebonized Maple -- check with DavidF on the method he used to ebonize the legs on his Lake Jordan Demilune Table.
Gee whiz, Dave -- you and I sure think alike! I was posting the above while you posted your comment!
__________________
Old 06-28-2007, 04:29 PM   #11
Advisory Panel
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 199
Avg Visit Freq/Week
= 6.53 over 30 days
Looking good Chuck
IMO the stand would look great without contrasting woods. The beauty of the bloodwood would work for disk and stand. IIRC bloodwood is likely to change color. Of course, all choices should be made in deference to LOYL
Roger
__________________
I ain't never had too much fun!
Show Printable Version Email this Page   Quote this post in a PM to sapwood
Old 06-28-2007, 05:43 PM   #12
City: Wake Forest
State: NC
County: Wake
Threads: 129
Avg Visit Freq/Week
= 6.53 over 30 days
Transtint does make a black, I have some, and it is quite difficult to wash off if you get it on your hands. DAMHIKT.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 07-01-2007, 12:41 PM   #13
City: Rocky Mount
State: NC
County: Nash
Threads: 97
Avg Visit Freq/Week
= 7.00 over 30 days
Here's finished pics. I went with bloodwood throughout after experimenting with India ink ebonizing. I tried ebonizing with poplar, cherry and bloodwood. Poplar just did not look good. Cherry looked better. The bloodwood looked fantastic but I couldn't bring myself around to covering up beautiful wood.
I added a triangular pyramid cap to the center post and wenge accent plugs. LOML is happy!
One coat of marine spar varnish (with UV filtering). This is the first time I've used spar varnish and it is really easy to brush on. Unfortunately, it does darken the color a bit.
I'll put a second coat on the disc top surfaces and maybe touchup a few places. I'm afraid if I put another full coat it will result in a level surface and I like the look I have after one coat, plus I don't want any more darkening. Bloodwood has a silky smooth surface. A little bit of varnish goes a LONG way! I can see my reflection in the finish after a single coat.
Chuck
ID:	3474   Click image for larger version
Old 07-01-2007, 05:52 PM   #14
McRabbet's Avatar
State: NC
County: Henderson
Threads: 117
Avg Visit Freq/Week
= 7.00 over 30 days
Superb job, Chuck -- glad to hear that LOML is happy with it, too! Nice deep color to the wood -- you're probably right about the single coat to avoid darkening the wood any further. I would suggest using clear plastic plates under the pots to avoid any water standing on the disks to protect the finish even further.
__________________
Old 07-01-2007, 10:44 PM   #15
City: Rock Hill
State: SC
County: York
Threads: 27
Avg Visit Freq/Week
= 1.87 over 30 days
I really like it, both design and execution!. I may try one of those myself.
Show Printable Version Email this Page   Quote this post in a PM to MarkW
Closed Thread
pics , plant , stand
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
LinkBacks (?)
LinkBack to this Thread: http://www.ncwoodworker.net/forums/f29/plant-stand-pics-9084/
Posted By For Type Date
Dying wood? - Router Forums This thread Refback 07-09-2008 04:43 AM
Similar Threads
Newest WIP, design opinions wanted-Mo' Pics DaveO General Woodworking 41 04-02-2007 10:37 PM
1st Lathe project: Cherry plant stand JimThomasson Woodturning 16 03-18-2007 11:42 AM
Plant stand project DaveD General Woodworking 13 05-29-2006 10:41 PM
Design Opinions Needed... cpowell General Woodworking 11 02-27-2006 11:04 PM
Plant Stand Pics cpowell General Woodworking 9 01-08-2006 09:08 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,124
Threads: 16,348
2nd Top Poster: jeff... (6,350)
Welcome to our newest member, eismanius
» Today's Birthdays
cfelts (66)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
