North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
LinkBack (2) Thread Tools Display Modes
Old 01-07-2006, 11:15 PM   #1
Mobile Lumber Storage Rack - Lumber Support
hpetty's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 28
Show Printable Version Email this Page   Quote this post in a PM to hpetty
hpetty hpetty is offline 01-07-2006, 11:15 PM
I'm building a mobile lumber storage rack like this one:
http://www.woodworkersjournal.com/pl...ails/5/13/1865
The plans call for heavy duty lumber shelf standards, which are a little pricey. Years ago I built a lumber storage rack (from a WoodSmith plan) using 1/2" pipe. I drilled holes into 2x4 uprights at a slight 3 degree angle to insert the end of a 16" piece of black pipe. I then used the pipe as the shelf supports. Is there any reason this wouldn't work for this cart? Would it weaken the 2x4s too much when I drill the holes. I used my other rack for several years and never had a problem with the drilled 2x4s. Any thoughts from others?
__________________
Mules kick. So do table saws!
Old 01-07-2006, 11:27 PM   #2
D L Ames's Avatar
Name: D L Ames
City: Fayetteville
State: NC
County: Cumberland
Threads: 66
Avg Visit Freq/Week
= 0.00 over 180 days
Re: Mobile Lumber Storage Rack - Lumber Support
Hugh, boring that large/many holes in 2x stock might weaken it some. Is there any way you could modify the plan and use 4x stock for the uprights that would support the shelves? I think that would provide you with a little more support.
D L
__________________
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. George Orwell (1903 - 1950)
Show Printable Version Email this Page   Quote this post in a PM to D L Ames
Old 01-07-2006, 11:33 PM   #3
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 692
Avg Visit Freq/Week
= 7.00 over 180 days
You might consider just laminating 2 2x's together. I haven't found any non pressure treated 4x stock in framing lumber. The bearing surface would be greater allowing the pipes to hold more weight. Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 01-07-2006, 11:49 PM   #4
Executive Vice-President
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 155
Avg Visit Freq/Week
= 6.88 over 180 days
Hugh,
I had considered building that rack myself when I first saw the article and looked back to review it. Assuming you would drill 7/8" diameter holes, you'll be left with only 5/16" of wood on each side of the holes -- As suggested you could use 4x4 stock or sister two lengths of 2x4 stock for the uprights (the sisters could sit on top of the base cross braces shown on the plans). If you add them, do it before you cut the long notches for the upper cross braces. Rob
__________________
Rob Payne
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 01-08-2006, 12:34 AM   #5
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 216
Avg Visit Freq/Week
= 6.46 over 180 days
Where's Steve Coles when you need him ?????
I saw his mobile storage rack Thursday and it looks great
Perhaps he'll chime in shortly
Sapwood
__________________
I ain't never had too much fun!
Show Printable Version Email this Page   Quote this post in a PM to sapwood
Old 01-08-2006, 10:43 AM   #6
Advisor
Founder
SteveColes's Avatar
City: Apex
State: NC
County: Wake
Threads: 1072
Avg Visit Freq/Week
= 6.81 over 180 days
Sapwood
If you already deep into construction, then I would bite the bullet and get the recommended "heavy duty lumber shelf standards" or if it is not too late I'd sister the 2 x 4 as almost everyone already has suggested.
But if you are only in the planning stage then take a look at this one I believe this started with our toolferone and then got picked up by Paul Comi in CA. And I believe toolferone got the idea or the cart itself some where else.
What sapwood is referring to, is this type of cart. It works and is cheap to build, if you don't count all the 7/64 drill bits I broke Mine is made completely from HD 3/4 " sandeply.
Show Printable Version Email this Page   Quote this post in a PM to SteveColes
Old 01-08-2006, 08:31 PM   #7
D L Ames's Avatar
Name: D L Ames
City: Fayetteville
State: NC
County: Cumberland
Threads: 66
Avg Visit Freq/Week
Hey Steve........Do you have any quick tips on "How Not to Install Screws" for a project like this?
D L
__________________
Old 01-08-2006, 08:43 PM   #8
City: Henderson
State: NC
County: Vance
When I need a strong down and dirty shelf bracket, I take a piece of 1/8 X 1 1/2 inch band steel, the length of the 2x4 plus the shelf bracket then double it, bend it in the middle,and drill two holes in each side of open end. Take the 2x4 and dato a kerf in each side 1/8" deep and 1 1/2" long. Insert the open ends of the steel band into the dato kerf and screw to fasten. Looking down at it from the top, it will look like a vee coming out of the 2x4.
This is a very strong arangement, for the screws do not hold the load, the dato cuts do. It still leaves you plenty of wood and should'nt cost any more then the pipe.
good luck
paul
Show Printable Version Email this Page   Quote this post in a PM to angler240
Closed Thread
lumber , mobile , rack , storage , support
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.ncwoodworker.net/forums/f29/mobile-lumber-storage-rack-lumber-support-1225/
Posted By For Type Date
Project Plans ToolCrib.com Blog This thread Refback 09-20-2008 05:56 PM
Wood Storage 101: 14 Lumber Storage Plans and 7 Storage Tips - ToolCrib.com Blog This thread Pingback 09-17-2008 11:55 AM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,101
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
FLEE (61)
MikeF (41)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
