04-21-2007, 03:18 PM
#1 |
Name: Peter City: Asheville State: NC County: Buncombe Join Date: Mar 2007 Age: 39 Avg Visit Freq/Week = 3.83 over 95 days | Interesting discovery... I'm in the midst of a new sideboard style project. It will have a maple ply carcasse with Sapele tabletop, drawer faces and framing. Sapele is fairly expensive ~$4.5 / BF for 4/4 stock. I didn't really consider solid wood construction partly because of stability, mostly because of perceived cost considerations. I'm estimating the cost of materials for this project at ~$300. This doesn't include consumables I already have like Dominoes, finish products, metal for legs, glass for door faces... etc.
I was thinking how much the project would have cost if I had chosen to go solid wood and I discovered that it would have been fairly equitable! Wow, I hadn't even considered how expensive quality plywood is. I may reconsider my construction materials in the future. I guess I just assumed that solid wood construction would be much more cost prohibitive. Actually, never really figured it out before.
__________________
'More than any other time in history, mankind faces a crossroads. One path leads to despair and utter hopelessness. The other to total extinction.Let us pray we have the wisdom to choose correctly.' -Woody Allen
04-21-2007, 05:18 PM
#2 | | Libraries Administrator
Name: Rob Payne City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 66 Avg Visit Freq/Week = 6.71 over 95 days | Re: Interesting discovery... Peter,
You're right when you consider the cost of good quality hardwood plywood. I pay about $2.60/square foot for A-1 White Oak plywood and $2.70/Board Foot for S2S White Oak. I'm currently doing a set of Dining Room built-in base and wall cabinets and will use 6 sheets of 3/4" A-1 WO ply and nearly 165 BF of S2S WO lumber. I prefer using plywood for the dimensional stability one gets for carcases, but none of it will be exposed on the outside surfaces.
Here's what it will look like:
__________________
Rob  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
04-21-2007, 06:20 PM
#3 |
Name: Chuck City: Rocky Mount State: NC County: Nash Join Date: Nov 2005 Avg Visit Freq/Week = 4.94 over 95 days | Re: Interesting discovery... Peter, I've reached the same conclusion on quality ply vs. solid stock. I use ply when I don't want movement but use as much solid stock as possible. I will admit that it takes a lot more labor to dimension and glue up a large panel than to simply cut a sheet of ply!
Chuck |
04-22-2007, 12:31 AM
#4 |
Name: Peter City: Asheville State: NC County: Buncombe Join Date: Mar 2007 Age: 39 Avg Visit Freq/Week = 3.83 over 95 days | Re: Interesting discovery... Originally Posted by cpowell Peter, I've reached the same conclusion on quality ply vs. solid stock. I use ply when I don't want movement but use as much solid stock as possible. I will admit that it takes a lot more labor to dimension and glue up a large panel than to simply cut a sheet of ply!
Chuck What I've realized is that this may be offset by all the time gluing edge banding or building frame and panels to hide plywood. Not to mention the horrible finish issues! i know this may seem crazy, but this is like a revelation to me!
__________________
04-22-2007, 10:06 AM
#5 |
Name: Sabre2 City: Peyton State: CO County: El Paso Join Date: Feb 2007 Avg Visit Freq/Week = 0.00 over 95 days | Re: Interesting discovery... When I decided to start woodworking 5 years ago I debated on solid wood vs ply construction. My decision was to use solid wood based on a couple of factors. One is handling a 4x8 sheet by my self is not what I want to do and I don't really have the room to break down sheets to size. Second, I like the satifaction of using solid wood construction. I know it takes a lot more time to cut stock to size, plane down and then glue up a panel, but much easier to handle. I buy all my wood back east when visit my dad (if I drive). I just stack it on the side of my shop and grab what I need to use. This way I never think about the cost.  It would be much easier to use ply in most instances because of wood movement, but .
Self confession: I used oak ply once (not furniture grade) and the results were less than stellar. I sanded thru the ply and the finish was terrible. However it was not all the ply's fault as I was just starting out.
Gary |
Posting Rules
Members: 1,931
Threads: 15,235
2nd Top Poster: jeff... (6,004) | | Welcome to our newest member, Berta | |
