| | #1 |
| Member | Inquiring about saw mills in eastern nc Hi Guys my name is Chris and I am within the next week or two going to cut down a huge Red Oak tree and a Pecan tree. I am planning on drying out the lumber and am wondering if June is a good time to cut the tree down in regards to drying the wood out with ease a little later on. Or should we wait a few more months until the sap begins to fall. Also, both trees main trunk is approximately 30" in diameter. I want to load the pieces up on a car trailer and have boards cut out of them from a local saw mill. Do you guys know of any on the eastern side of the state and the approximate cost they would charge to handle such logs this size? Any and all suggestions, advice would be appreciated. Thanks, Chris |
| | #2 |
| Webmaster Senior Moderator Advisory Panel | Re: Inquiring about saw mills in eastern nc Chris you might want to check with any of these sawyers - Region 4 Feltz Sawmill Eric Feltz 903 Myra Road Raeford NC 28376 (910) 875-5827 (910) 308-7796 Link to the site Beaver Branch Portable Sawmill sawing up to 24 ft. long Ivey Pridgen Burgaw,N.C. (910) 259-4777 (910) 540-0705 Region 5 Kevin's Custom Sawing and Furniture Air dried hardwoods/softwoods and custom portable milling services Kevin Everett 112 Boyd Loop Rd Everett's Corner Beaufort Co. Tel. (252) 923-0345 That's all I have to offer Dave
__________________ ![]() Honestly Honey, that will cost around ![]() Today's mighty Oak is just yesterday's NUT that held it's ground "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind." --Dr. Seuss |
| | #3 |
| Member | Re: Inquiring about saw mills in eastern nc Kevin has a nice portable WoodMizer, really knows how to use it, and charges reasonable fees. He is located in Washington. Not sure how far he will travel, but give him a call. |
| | #4 | ||
| | #5 |
| Member | Re: Inquiring about saw mills in eastern nc When is the best time of the year to cut the trees down in regards to the moisture content. Should I wait until the sap begins to fall. I don't want this wood to check too badly during the drying process. |
| | #6 |
| Member | Re: Inquiring about saw mills in eastern nc Originally Posted by Truefire Chris, I don't think it matters much, but I really don't know. The key to preventing checking (and case hardening) is to treat the ends and don't allow it to dry too fast.
The folks at VA Tech and U of Wisc. are the lumber experts, especially cutting and drying hardwood. Their Forrest Service Products Labs are part of the USDA and they publish a lot excellent stuff, most of which is available for free online. You can't go wrong with anything by them or Dr. Eugene Wengert. Here is a link to the pdf version of Air Drying of Lumber USDA Forest Service Forest Products Laboratory Madison, Wisconsin Unfortunately it doesn't address when to cut. Here is another place to start Forest Service Products Laboratory |
| | #7 |
| Member | Re: Inquiring about saw mills in eastern nc Alan is dead on the money. Get the ends of those logs sealed with Anchor Seal or Baily's Seal, as soon as possible after cutting. This will cut down on checking substantially. If you can't find either of those, get some black rubber type roof sealer and put it on thick.
__________________ I'm a great believer in LUCK! I find the harder I work, the more I have of it. Thomas Jefferson |
| | #8 |
| Member | Re: Inquiring about saw mills in eastern nc Originally Posted by Truefire Sap rising and falling is a misnomer - it does neither - it's something to do with photosynthesis. A tree cut off the stump in the dead of winter or in the full of summer will have the same moisture content - less of course there is drought or something weird like that. Bottom Line - it does;t matter there is no better time than others to cut down trees.
When the tree falls off the stump trim the butt cut and apply ancorseal - you can't get it on to soon - the sooner the better. Buck you logs to 16' 6" ~ 17' and again apply ancorseal to the bucked end - let sit a few hours than one dry apply another coat to both ends - 2 thick coats on the log ends does wonders to help prevent end grain splitting and help keep the log wet on the inside. Now speaking for rubber or tar roofing cement - who ever suggests tar should be taken out back and beaten - that stuff gets all over everything, including the sawmill and sawyer - Tar is a PITA to try and clean up - Ancorseal is a clear wax water based type paint, it's much easier on the sawyer and his equipment. I include a hourly fee for tarred logs - however much time it takes me to clean it up is how much extra I charge - has been as little as an hour to 6 hours at my flat rate of $50.00 per hour. Thanks
__________________ Mills Custom Sawing |
| | #9 |
| Member | Re: Inquiring about saw mills in eastern nc Thanks guys, where is a good place to purchase ancorseal or Baily's seal? Can I find it local near Greenville or should I just purchase it online? Any websites cheaper than others? Thanks. Chris |
| | #10 |
| Member | Re: Inquiring about saw mills in eastern nc Chris - ditto Jeff's comments. When I obtain a large oak log, I try to apply the end sealer almost immediately after the log is felled, and definitely before moving the log. This one action will do more to provide high quality wood than any other. Here's the link to end sealer on the Bailey's web site: http://www.baileysonline.com/search....ealer&PageNo=1 Typically, unless you will be milling it right away, if you fell a log during the winter months, you will have less problems with degradation than if you fell it during the hot summer months. Scott |
| | #11 |
| Member | Re: Inquiring about saw mills in eastern nc Scott and Jeff thanks a great deal on your advice and helpful information in regards to finding sealants to apply to newly downed logs. Thanks again, Chris ![]() |
| | #12 |
| Member | Re: Inquiring about saw mills in eastern nc Has anyone ever had success in using tar/rubber & then cutting the ends off just before going through the sawmill? |
| | #13 |
| Member | Re: Inquiring about saw mills in eastern nc In regards to utilizing the rubber cement on the ends of the lumber (logs) I never have. I am sure it is cheaper then the sealant designed for such, if I had to choose and pay just a few more dollars extra for the sealant...well I would simply due to it's nature being less messy and it is water based so would be easier cleanup. I would probably Private Message one of the other guys in the neighborhood that had a little more experience in this matter than myself. Plus I can only imagine what my wife would say when entering the house somewhat covered in TAR....I laugh now just simply thinking about it... ![]() |
| | #14 |
| Member | Re: Inquiring about saw mills in eastern nc I think I may be being "tarred" for my comment about roof cement. Rubber roof cement is NOT tar! I only suggested it because Anchor Seal and Baily's are not readily available locally. ![]() AND, because VT suggested it if you can't find anything else. It's definitely better than paint. If I was sawmilling, I'd square up the ends of my customers logs and then saw it. I realize this is another step in the process, maybe, but I guess Ivey and my local guy have spoiled me. My $.02 worth. ![]()
| | #15 |
| Member | Re: Inquiring about saw mills in eastern nc Originally Posted by Gotcha6 Still going to get all over everything it touches. I'll do whatever I customer asks within reason - they are paying the bill. But like I said it's a mess to try and clean up and seems to get into the strangest places... IMHO roofing cement belongs on the roof, log end sealer belongs on the end of logs.
Thanks
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lucas Saw Mills | woodnick | Power Tools and Their Use | 4 | 05-06-2008 11:04 PM |
| Looking for Cherry Source/ Saw Mills | sawhorse | Wood | 14 | 08-09-2007 11:21 AM |
| Hello from Hope Mills | GENEREED | Who We Are | 26 | 05-01-2007 12:19 AM |
| Hello From Mills River | sammy | Who We Are | 17 | 08-09-2006 09:17 AM |
| Eastern Elm | BobN | Wood | 3 | 06-14-2006 06:20 PM |
