» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  |
11-04-2009, 12:27 AM
#1 | | I could call and ask Fred... Name: Jeff City: Stovall State: NC County: Granville Join Date: Feb 2009  11-04-2009, 12:27 AM
But I figured I'd ask here so you guys can poke fun at me. I'm not sure what the joint is called but I cut it with a dado stack on the tablesaw, so I guess it's call a dado  . Anyways when joining a case side to a bottom you cut wide groove in the side of the case it's the same width as the thickness as the bottom and you then beat the edge of the bottom into the groove you just cut in the side of the case. I know you don't glue this bad boy, because wood moves and if it ain't allowed to move... well somethings got to give and chances are high the side of the case will split that would not be good...
I usually secure this kind of joint with a length of 3/4 sq wood with over sized screw holes that screw into the side and the bottom and has seemed to work pretty well. But I'm thinking why couldn't a guy take and screw some screws in from the outside of the case side plug the holes with dowels and sand flush? Heck a guy could even get creative and chisel out a square hole and plug it that way to hide the screw hole. maybe even use contrasting wood for the plugs, am I thinking wrong, would this work and still allow the wood to move without splitting?
What other ways are there to join this kind of joint?
Thanks | | Views: 335 |
11-04-2009, 07:30 AM
#2 |
Name: Fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 52 Avg Visit Freq/Week = 6.84 over 180 days | Re: I could call and ask Fred... hmmm.... lessee.... you beat it into submission but it still moves? must be a wifeankids joint!  |
11-04-2009, 11:55 AM
#3 |
Name: David City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 52 Avg Visit Freq/Week = 3.50 over 180 days | Re: I could call and ask Fred... If the shelf and the side are both "real" wood, and the grain runs around the case in the "normal" way, IE Side grain runs up and down, bottom panel grain runs left to right (or right to left  ), then you can glue the joint
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux |
11-04-2009, 01:26 PM
#4 |
Name: Jeff City: Stovall State: NC County: Granville Join Date: Feb 2009 Avg Visit Freq/Week = 5.83 over 180 days | Re: I could call and ask Fred... Originally Posted by DavidF If the shelf and the side are both "real" wood, and the grain runs around the case in the "normal" way, IE Side grain runs up and down, bottom panel grain runs left to right (or right to left  ), then you can glue the joint Thanks David, I called Fred and he said the same thing you did  |
11-04-2009, 02:09 PM
#5 |
Name: David City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 52 Avg Visit Freq/Week = 3.50 over 180 days | Re: I could call and ask Fred... Hope it works out. I always new Fred knew what he was talking about .gif)
__________________
11-04-2009, 02:25 PM
#6 |
Name: Fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 52 Avg Visit Freq/Week = 6.84 over 180 days | Re: I could call and ask Fred... Originally Posted by DavidF Hope it works out. I always new Fred knew what he was talking about .gif)
hey now let's not start callin me too smart!  |
11-04-2009, 02:46 PM
#7 |
Name: David City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 52 Avg Visit Freq/Week = 3.50 over 180 days | Re: I could call and ask Fred... Originally Posted by FredP hey now let's not start callin me too smart!  Sorry Fred, didn't mean to......
__________________
11-04-2009, 07:29 PM
#8 |
Name: Jeff City: Rougemont State: NC County: Durham Join Date: Mar 2008 Avg Visit Freq/Week = 3.38 over 180 days | Re: I could call and ask Fred... Jeff,
Sorry, but I'm conceptually challenged on your question. Do you have a picture or a sketch of the joint to share with us for general information?
Fred and Dave are both good, so you've got good advice there.  |
11-04-2009, 08:15 PM
#9 |
Name: Jeff City: Stovall State: NC County: Granville Join Date: Feb 2009 Avg Visit Freq/Week = 5.83 over 180 days | Re: I could call and ask Fred... Both pieces, solid wood, the same species (Red Oak) - Question: Can I glue this joint? Answer: Yes I can  |
11-04-2009, 08:26 PM
#10 |
Name: Danny City: Seagrove State: NC County: Montgomery Join Date: Oct 2006 Age: 52 Avg Visit Freq/Week = 6.81 over 180 days | Re: I could call and ask Fred... Yes glue, then shoot some brads in it till the glue dries.  I did not say that out loud did I.
Danny |
11-05-2009, 10:28 AM
#11 |
Name: Jeff City: Rougemont State: NC County: Durham Join Date: Mar 2008 Avg Visit Freq/Week = 3.38 over 180 days | Re: I could call and ask Fred... Gotcha! I used the same joint for the bottom shelf on a QS red oak bookcase that I built last spring (QS wood that we cut at Jim's place in Berea). In my case the bottom shelf was 3/4" red oak plywood veneer. To compensate for the plywood thickness the dado was cut undersize (width) and the ply got a small rabbet on the underside to match the dado width. Worked just fine! |
11-05-2009, 11:48 AM
#12 |
Name: David City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 52 Avg Visit Freq/Week = 3.50 over 180 days | Re: I could call and ask Fred... Originally Posted by Jeff Gotcha! I used the same joint for the bottom shelf on a QS red oak bookcase that I built last spring (QS wood that we cut at Jim's place in Berea). In my case the bottom shelf was 3/4" red oak plywood veneer. To compensate for the plywood thickness the dado was cut undersize (width) and the ply got a small rabbet on the underside to match the dado width. Worked just fine! With plywood for the shelf and solid wood for the side, this would be one of the cases where you would NOT glue the whole length of the shelf. Just the front 2" and leave the rest to float, remembering to leave a small gap between the back of the shelf and the cabinet back to give clearance for the sides to shrink
__________________
11-05-2009, 07:43 PM
#13 |
Name: Jeff City: Rougemont State: NC County: Durham Join Date: Mar 2008 Avg Visit Freq/Week = 3.38 over 180 days | Re: I could call and ask Fred... Originally Posted by DavidF With plywood for the shelf and solid wood for the side, this would be one of the cases where you would NOT glue the whole length of the shelf. Just the front 2" and leave the rest to float, remembering to leave a small gap between the back of the shelf and the cabinet back to give clearance for the sides to shrink David,
Thanks for the tip. I guess the reasoning is that the ply will not expand/contract, but the solid wood sides need to be free to move as needed. I don't remember if I glued all or part of the shelf in the dado (maybe none of it because it was a pretty good fit). Thanks again.
I hope that Jeff Mills and others can use the info to their benefit for their projects. |
11-06-2009, 09:31 AM
#14 |
Name: David City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 52 Avg Visit Freq/Week = 3.50 over 180 days | Re: I could call and ask Fred... Originally Posted by Jeff David,
I hope that Jeff Mills and others can use the info to their benefit for their projects. That's exactly right.
__________________
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Fred | Jeff Mills | Off Topic | 2 | 06-01-2009 06:43 PM | | Hey Fred ? | Jeff Mills | Off Topic | 6 | 04-28-2009 07:52 AM | | Call for help... | NCTurner | Woodturning | 8 | 11-12-2008 02:41 PM | | Hey Fred | jeff... | Safety & Health | 21 | 06-05-2008 09:57 PM | | Blame Fred P | botebum | Who We Are | 20 | 12-29-2006 12:31 AM | | » Stats |
Members: 3,663
Threads: 25,105
Top Poster: DaveO (14,701) | | Welcome to our newest member, Keith Senderak | |
