North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 07-26-2009, 03:48 PM   #1
How to make this cut?
City: Lincolnton
State: NC
County: Lincoln
Threads: 16
Show Printable Version Email this Page   Quote this post in a PM to mxracer
mxracer mxracer is offline 07-26-2009, 03:48 PM
One of the reasons I recently got into woodworking is to make some of my own beekeeping equipment. The hive bodies and supers are one of the things I'd like to make , the one thing that I'm not sure about are the handles. The image below depicts what I need to do. This type of cut is what I need, any cut that has a ledge on the bottom will hold water and promote rot, so it needs to be this type of cut.
Would this be a shaper ONLY or some other options????
Thanks,
Dan
Old 07-26-2009, 04:12 PM   #2
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 692
Avg Visit Freq/Week
= 7.00 over 180 days
Re: How to make this cut?
You could probably do that with a large radius cove bit. The only limiting factor would be being able to raise the bit high enough over the router table to get the spacing down from the top. You might need a collet extension.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 07-26-2009, 04:19 PM   #3
FredP's Avatar
City: franklinton
State: nc
County: franklin
Threads: 120
Avg Visit Freq/Week
= 6.84 over 180 days
drill press with a forstner bit and a guide block.tilt the table and locate the guide block so the bit will exit at the right height then clamp the box to it. set depth stops. maybe......
__________________
fred p
Hey ya'll watch this!
www.ncwoodencreations.com
Show Printable Version Email this Page   Quote this post in a PM to FredP
Old 07-26-2009, 04:28 PM   #4
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 139
Avg Visit Freq/Week
Rough sanding drum in hand drill or micro-plane cylinder in a hand drill. Dremel with a sanding drum.
Hand chisel.
I'm pretty sure that is done with a shaper in production. But how many frames do you need to make?
If it is over twenty then get a shaper.
__________________
I meant to tell you, Mors Kochanski said "thats a spoon made by an expert" -BR-
Show Printable Version Email this Page   Quote this post in a PM to Mike Davis
Old 07-26-2009, 05:13 PM   #5
Glennbear's Avatar
City: Baskerville
State: VA
County: Mecklenburg
Threads: 166
Avg Visit Freq/Week
= 6.30 over 180 days
I agree with Dave that a large cove bit would do it but I would use a hand held router to eliminate the depth problem encountered when using a router table. Another possibility would be a bowl routing specialty bit.
__________________
" I get knocked down but I get up again" - Chumbawamba
Show Printable Version Email this Page   Quote this post in a PM to Glennbear
Old 07-26-2009, 08:37 PM   #6
Gregory Paolini's Avatar
City: Waynesville
State: NC
County: Haywood
Threads: 3
Avg Visit Freq/Week
= 2.24 over 169 days
If it were just one or two, I would grab some carving gouges... Assuming you have several, I would make a jig for use with a router and a guide bushing. You could angle the jig with a simple wedge, in order to get the sweep in the cut. Your jig doesn't have to be pretty, just functional. I would imagine you'll have 20 minutes tied up in making it...
Hope this helps
__________________
Gregory Paolini
www.GregoryPaolini.com
Custom Furniture, Cabinetry, and Woodworking Instruction
Show Printable Version Email this Page   Quote this post in a PM to Gregory Paolini
Old 07-26-2009, 09:18 PM   #7
sbjguitars's Avatar
City: Newton Grove
State: NC
County: Sampson
I might try a Wanger Safety planer in the drill press with the table tilted.
Show Printable Version Email this Page   Quote this post in a PM to sbjguitars
Old 07-26-2009, 09:21 PM   #8
City: Lincolnton
State: NC
County: Lincoln
Threads: 16
Avg Visit Freq/Week
= 6.30 over 150 days
Thanks for the responses guys.
I will have many to make.
I'll have to play a bit with a router and making a jig as suggested. With an estimated growth of 6 or so hives next year and 20 or so of these cuts per hive I wouldn't want to do them manually.
Old 07-26-2009, 10:19 PM   #9
JackLeg's Avatar
City: Albemarle
State: NC
County: Stanly
Threads: 228
Avg Visit Freq/Week
= 6.07 over 180 days
A template and a hand held router like the Colt should make that pretty easy to do in numbers. Or am I in "left field" on this?
__________________
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. – UNKNOWN!
Show Printable Version Email this Page   Quote this post in a PM to JackLeg
Old 07-26-2009, 11:16 PM   #10
Kdub's Avatar
City: China Grove
State: NC
County: Rowan
Threads: 6
Avg Visit Freq/Week
= 3.50 over 180 days
I'm seeing possibly using a biscuit jointer pressed in and raised as it's pulled to the bottom of the handle area. Or a lancelot blade on the side grinder may do the trick. they can take a lot of wood out fast. good luck
kurt
Show Printable Version Email this Page   Quote this post in a PM to Kdub
Old 07-26-2009, 11:46 PM   #11
Bas is online now Bas
Senior Administrator
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Avg Visit Freq/Week
= 6.96 over 180 days
I did this using a core box bit, a simple jig and a guide bushing.
You could change the jig from being a straight channel to a semicircle. Or, route it straight like I did in the cutting board (although not as deep), and then use something like a belt sander or ROS to make a half-moon on the bottom
__________________
Bas.
I don't need it. I just want it.
Show Printable Version Email this Page   Quote this post in a PM to Bas
Old 07-27-2009, 12:20 AM   #12
JOAT's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 53
Avg Visit Freq/Week
= 1.91 over 180 days
I've seen plenty of bee hives with a slat to lift with, never noticed any rot problem. I believe the top was on a slant tho.
Or you could form the sides out of multiple pieces, doesn't need to be one piece. Then you could cut or carve your curve in one in the middle, join another on top of that. Or even cut a hole completely thru using a sabresaw, making a angle on the bottom edge, then covering the hole on the inside with a slat, I'm sure the bees won't mind.
Me, I might just use a hand power sander, sand a divot in the side, then use a chisel to square up the top of it. But in real life I'd probably just glue or nail a strip with an angled top for the rain to slide off along the side, and presto, a handle.
__________________
JOAT
Plans? Plans? Don' need no steenkin' plans.
Show Printable Version Email this Page   Quote this post in a PM to JOAT
Old 07-27-2009, 10:00 AM   #13
Phil S's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 25
Avg Visit Freq/Week
= 6.92 over 180 days
If I had to make as many of these cuts as I think you do, I would use my chain saw. After firmly securing the box I would use the bottom quadrant of the tip and start at the bottom of the cut with the bar at 45 degrees to the box just contact the wood and then rotate the bar up to vertical. You may have to do it from each side of the cut to balance the cut. use a firm grip on the saw, stabile footing and run the saw at about 3/4 speed. I think if you practiced a little you could make a good handle cut in less than a minute. This comes from my days in Minnesota when I tried to learn how to carve tree stumps into animals. phil
Show Printable Version Email this Page   Quote this post in a PM to Phil S
Old 07-27-2009, 10:30 AM   #14
Site Programmer
froglips's Avatar
City: Hillsborough
State: NC
County: Orange
Threads: 430
Avg Visit Freq/Week
Another option could be a tablesaw cove cut.
A ramp jig would be needed to create the depth. Probably not the best of ideas to come in perpendicular to the blade. So maybe come in at an angle for the bulk of the stock, then do just the last bit perpendicular.
Maybe use a dado stack.
__________________
"Why is it that I loathe washing dishes, but I absolutely love sitting out here in the shop washing parts with kerosene?"
Roger Welsch, Busted Tractors and Rusty Knuckles
Show Printable Version Email this Page   Quote this post in a PM to froglips
Old 07-27-2009, 10:50 AM   #15
City: Dobson
State: NC
County: Surry
Threads: 51
Avg Visit Freq/Week
= 4.67 over 180 days
CMT makes a router bit for making bowls. I used one to make a tray for a high chair. It would be easy to make a jig on risers to angle the cut. Here's CMT's website with a video.
http://www.cmtutensili.com/viewdoc.asp?pars2=1~22~1
Rick Doby
Show Printable Version Email this Page   Quote this post in a PM to rbdoby
Closed Thread
cut , make
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How did he make this? PeteM General Woodworking 4 06-29-2007 03:44 PM
Need someone to make this DavidF Request For Custom Projects 10 05-30-2007 10:23 AM
What would you make? lwhughes149 General Woodworking 11 12-13-2006 08:25 PM
How do I make this cut? cpowell General Woodworking 10 03-30-2006 10:42 AM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,103
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
