North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 08-18-2008, 12:09 AM   #1
How do I fix bow in plywood drawer frame w/ pics?
Travis's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 67
Show Printable Version Email this Page   Quote this post in a PM to Travis
Travis Travis is offline 08-18-2008, 12:09 AM
Much to my chagrin I have an 1/8" inch bow over a 26" span in the plywood frame for a bank of drawers in a dresser. The drawers are suppose to fit with a 1/6" clearance. Some how this happened although the case was perfectly square. I considered maybe wrapping with damp towels and clampping down over a period of time. Check out pictures below to get a visual. The rule should read 7".
Thanks
__________________
"the good thing with me and woodworking .... I have nothing to unlearn"
Old 08-18-2008, 12:22 AM   #2
Travis's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 67
Avg Visit Freq/Week
= 0.16 over 180 days
Re: How do I fix bow in plywood drawer frame w/ pics?
Correction: 1/16" clearance not 1/6".
__________________
Old 08-18-2008, 01:15 AM   #3
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 262
Avg Visit Freq/Week
= 6.69 over 180 days
Travis- check all your openings, you might have two warped faceframes and if each is 1/32 off it will obviously give you 1/16 total error. Use a straight edge to check all frames.
I assume you will be using flush inset drawers, otherwise if they are overlay drawer fronts, no big deal. One idea is to live with it- make the drawer fronts match the frame bow and all.
Dampening and clamping is one approach. Dry clamping might work, also. In any case you need a good opposing surface to anchor the other half of the clamp- not one of the other shelves. Clamping may not work in the long run however.
Can you reemove the warped piece and install a new one? The best guarantee of a straight frame.
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Old 08-18-2008, 01:18 AM   #4
BillPappas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 24
Avg Visit Freq/Week
= 5.48 over 180 days
I think I would plan on fitting the drawers to the bow. If you get the drawers to fit evenly I don't think you will see the bow.
Regards,
Show Printable Version Email this Page   Quote this post in a PM to BillPappas
Old 08-18-2008, 08:32 AM   #5
rywilson's Avatar
City: Rolesville
State: NC
County: Wake
Threads: 14
Avg Visit Freq/Week
= 4.90 over 180 days
I just watched Norm do a piece where he talked about fixing this type of issue. He fixed the problem by nailing through the backer into the dust frames in the dresser. He drew straight lines in the inside of the backer where the dust frames should line up. He then used clamps to make sure the dust frames were lined up and then put brads through the back.
I think a similar approach could work here also.
Show Printable Version Email this Page   Quote this post in a PM to rywilson
Old 08-18-2008, 09:11 AM   #6
Joe Scharle's Avatar
City: Holly Springs
State: NC
County: Wake
Threads: 159
Avg Visit Freq/Week
= 7.00 over 180 days
Design Change!
Insert center divider for aesthetic enhancement.
Show Printable Version Email this Page   Quote this post in a PM to Joe Scharle
Old 08-18-2008, 10:47 AM   #7
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
= 6.53 over 180 days
Did you cut all of the dividers at the same time? Could the one that is bowed be slightly longer than the others? Could happen if you cut them at different times.
BTW, how did you assemble this carcass? Any chance of taking it apart and replacing/adjusting the bowed one?
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 08-18-2008, 02:05 PM   #8
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 188
Avg Visit Freq/Week
= 3.46 over 180 days
A central divider might work if you put it in all drawer boxes or the bow might just get transfered to the next one. Make it set back from the front for the inset drawer fronts and make the drawer boxes narrower to accomodate the dividers. I think nailing to the back won't do the job in this case. Or, make the drawer front fit the opening. Only you will know, but that might be one person too many!!
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF
Old 08-18-2008, 03:40 PM   #9
rick7938's Avatar
City: Autryville
State: NC
County: Cumberland
Threads: 106
Avg Visit Freq/Week
= 3.15 over 180 days
I've had good luck spraying the piece liberally with hot water and clamping slightly tighter than necessary to allow for a little spring-back after drying.
Good Luck.
Show Printable Version Email this Page   Quote this post in a PM to rick7938
Old 08-19-2008, 11:28 PM   #10
Travis's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 67
Avg Visit Freq/Week
Thanks for the great advice.
I will try soaking with spraying with hot water then clamping first then nailing theback panel while clamped in place. If that does not work I will ether add a drawer divider on match the curve of the frame to the drawer front. Will post results later as they come.
Thanks again.
__________________
Closed Thread
bow , drawer , fix , frame , pics , plywood , w or
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Prefinished Plywood & Maple Drawer Blanks Bob Buchholz Where Can I Find, Buy or Sell 3 07-29-2008 12:11 PM
Face frame for Cabinets jjahr General Woodworking 10 08-24-2007 04:21 PM
Frame Less Kitchen Cabinets Help! jeeves General Woodworking 11 07-06-2006 09:12 PM
Mirror Frame Terry User Announcements 5 05-15-2006 05:37 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,103
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
