11-11-2007, 11:57 PM
#1
How to attach a top??
City: Clayton
State: NC
County: Johnston
Administrator
I believe that may have got myself into a bind. On one of my latest projects, I can't figure out how to attach the top. My biggest problem is that I don't have access to the underside of the top once the piece is fully glued up. The drawer openings don't allow enough clearance for me to drive a screw or anything like that.
The top is triangular ~15" deep by 25" wide, and it is to be attached to cabinet sides of solid wood. Here's some pics -
I have thought about attaching the top before the face
frame is attached, but that would leave me without a point of attachment to the front. And I had planned on attaching the FF and then hand-planing the sides down to match the angles of the sides.
Right at this moment nothing is glued up, just dry fitted so I am open to any suggestions
TIA,
Dave
__________________
  Nothing left to do but smile, smile, smile
--Dr. Seuss
11-12-2007, 12:17 AM
#2
City: Goldsboro
State: NC
County: Wayne
Avg Visit Freq/Week = 6.07 over 180 days
Re: How to attach a top??
It looks like the top will expand most front to back. Can you add a couple of "runners" that will allow you to use z-clips accessible through the drawer opening?
__________________
Genuine antique. Made in the USA. Father was union member. Mother did the labor.
11-12-2007, 12:38 AM
#3
Administrator
City: Clayton
State: NC
County: Johnston
Avg Visit Freq/Week = 6.84 over 180 days
Mark, that's a good idea. I am still concerned that I won't have the clearance to do any serious screw driver/drill-driver work in the space. It's only about 5.5" tall, through the less than 3" drawer opening.
I think that I may have come up with a possible solution - I will attach the top to the back panels only with Z clips. I will carefully measure for the set up of one or two clips that will attach to the front FF. I will assemble the FF assembly off the carcass, with it hand planning work. Then I will attach the FF to the carcass and hope the I measure well enough for the front Z clips to line up right. I might have enough room to get a stubby screw driver and hand in there to tighten them up a bit once all is assembled, giving me a little wobble room on the assembly.
Please I welcome any other suggestions, there has got to be a better way than what I have concocted
Dave
__________________
--Dr. Seuss
11-12-2007, 12:46 AM
#4
Guest
Name:
City:
State:
County:
Dave have you considered screw cleats? 3/4" sq strips screwed to the sides and front and to the top? You should be able to get the screws in with a offset ratchet screwdriver, which is made for getting in tight spaces. I've replaced many a top on cabinets this tool is the bomb...
http://www.mohawk-finishing.com/cata...asp?ictNbr=692
BTW - glad to see something made out of the spalted QS Beech. How was it to work with?
Thanks
11-12-2007, 12:57 AM
#5
Administrator
City: Clayton
State: NC
County: Johnston
Thanks
I have thought about going along those lines. I have never had a lot of luck with driving screws in any other method other than direct in-line pressure. Maybe with a good pilot hole and chasing the thread into the wood first they might go in easily.
The QS Beech was very nice to work with. Quite hard and a little prone to burning like Cherry. Some of the spalted sapwood was pretty soft, but still good wood. A very distinct difference between it and the heart wood. The spalting is outstanding. I feel bad using this wood for what I am doing, but the cost, workability and stability was way better than Poplar. My parents want to paint this     . I hope to convince them against that crazy idea with some beautiful wood
Dave
__________________
--Dr. Seuss
11-12-2007, 01:14 AM
#6
City: Raleigh
State: NC
County: Wake
Avg Visit Freq/Week = 3.31 over 180 days
Dave,
Beautiful work.
I like the recommendation of a Fine Woodworking article a while back. The author suggests that tops should be firmly attached on one edge. The basic idea is two fold, 1. to only allow movement in a direction that will not cause problems - e.g. a dining table should be attached in the center, allowing the wood to expand in both directions, but, 2. preventing the top from becoming loose when the wood is very dry. Another example is when a table will be against the wall, it should be attached at the back to prevent the top from pushing against the wall.
In the case of your cabinet, you might consider adding a small triangular block at the back and then driving a screw into the top. Use z-clips on the front of the sides and into the face frame.
__________________
"Anything worth cutting down a tree for, is worth doing right."
Cut to size, and hammer to fit.
11-12-2007, 01:15 AM
#7
Guest
Name:
City:
State:
County:
Dave
Yeah I think a pilot hole would help - Also try course thread drywall screws they go in with a good bite and with the course thread you don't have so much turning to get it snug. Believe it or not but a lot of higher end furniture is screwed together with drywall screws...
Just remember to make your hole in the screw cleat a little bigger than the shank of the screw to allow for some movement in temp / humidity changes. I think a slot might be a little over kill just an over sized hole is good enough. STOP... What am I saying? I'm sure you already know this... Smack me next time you see me...
Yep would be a shame to paint that pretty wood... I knew it was going to be hard and dense after all a lot of bench top are made of beech. I didn't know it would be prone to machine burning like cherry. Thanks for the review, it's good to get a little real life information on a new to me wood.
Thanks
11-12-2007, 08:56 AM
#8
City: Ocala
State: FL
County: Marion
Avg Visit Freq/Week = 5.68 over 180 days
Dave,
Is there enough room (overhang) for the use of figure 8 clips? You would have to drill a recess in the top of the sides so they would be flush then with the other half extending out from the sides you could screw them to the bottom of the top from the outside. Is this clear as mud?
__________________
Norm
You only live once. If you do it right that’s all you need.
11-12-2007, 10:33 AM
#9
City: Charlotte
State: NC
County: Mecklenburg
Avg Visit Freq/Week = 6.88 over 180 days
Use a ratchet with a screwdriver tip. Much better than those offset screwdrivers. You can apply the inline pressure, but still get the torque you need. Definitely drill pilot holes. That should allow you to use cleats or figure 8 with no problems.
11-12-2007, 10:45 AM
#10
City: Pittsboro
State: NC
County: Chatham
Avg Visit Freq/Week = 4.01 over 180 days
How about adding battens to the top only on the long angled sides, these could be screwed to the top. The battens would drop down inside the case sides and could be then screwed from the outside with either decorative brass screws or you could use screw caps. The front would not be directly attached to the FF, but with the long sides fully secure that may not matter. If you wanted to you may be able to attach a right angle bracket above the top drawer and screwed into the top with access through the drawer opening.
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
11-12-2007, 11:24 AM
#11
City: Holly Springs
State: NC
County: Wake
Avg Visit Freq/Week = 7.00 over 180 days
Since you're going to paint it, why not screw the top to the rails and plug the counterbores?
11-12-2007, 11:41 AM
#12
City: Myrtle Beach
State: SC
County: Horry
Avg Visit Freq/Week = 6.77 over 180 days
Dave, I have good luck with the following method. Attach a piece of solid 3/4 x 3/4 along the entire inside top front of the carcus and the same on the sides comming out of the vee. Drill a 1/4" hole in each side strip about 6" out of the vee. Now attach a piece of the same strip along the underside front of the top so that the two pieces are in contact with each other when the top is placed on the cabinet. Now attach a piece of 1/2" ply (1 1/2" wide) to the strip on the top so that it overhangs 3/4" to the front. When you are ready to put on the top, put it in place and slide it to the front securing the front side. Reach inside and screw up through the pre-drilled holes at the back. The 1/4" holes will allow plenty of room for movement of the top.
__________________
The lyf so short The craft so long to lerne
11-12-2007, 01:35 PM
#13
City: Raleigh
State: NC
County: Wake
Avg Visit Freq/Week = 6.49 over 180 days
How about a couple of biscuits? Or just glue it on with some construction adhesive once you have the cabinet base in place. Or 4 small pieces of aluminum angle (middle of sides and 2 along front). Screw to the top first, drop top on base, and use angled powered screwdriver/drill to finish up.
http://www.toolbarn.com/product/milwaukee/0370-20/
11-12-2007, 03:37 PM
#14
City: franklinton
State: nc
County: franklin
got any dowel points? drill holes in the suports. insert points place top in posiyion and bump it with your hand a couple o times and drill holes in top at marks. i dont beleive expansion is going to be a problem with a top that size. if you think it will you can ream the holes a little to make the dowels a little looser. glue dowels and set top.
fred
11-12-2007, 08:51 PM
#15
Executive Vice-President Libraries Administrator
City: Hendersonville
State: NC
County: Henderson
Avg Visit Freq/Week = 6.81 over 180 days
I recently attached a top using the equivalent of a keyhole-style hanger. Your top will have the "keyholes" and the carcass the "hanger screws". First, layout the position for four #12 flathead screws into the top of the backs and the stiles, forming a rectangle (be sure two front screws and two back screws are equidistant from each other). Next, transfer the screw positions to the underside of the top and drill a starting hole (clearance for the screw head) for each screw 1-2" toward the back of the top. Set up a small 14º dovetail bit in a handheld router to run against a temporary fence set parallel to the front-to-back alignment of the screws. Route a dovetail back toward the front of the top at each screw location. It you adjust the screws to the correct height, the top will drop onto the screw heads and you can push it back into a lock position. Clever, eh?
__________________
Rob Payne
 Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Attach this top
Jay |
General Woodworking |
11 |
07-29-2006 04:49 PM |
» Stats |
Members: 4,214
Threads: 28,024
Top Poster: DaveO (15,002)
| Welcome to our newest member, magellan44 |
