North Carolina Woodworker
Changes to DQ as of 12/1/2008 Very important that you read
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
Notices
» Announcements
Everyone Log on at 9:00PM Thursday December 4th to set a members online record.
Featured Photos
by bluewing92
24868 photos
9957 comments
by michaelgarner
24868 photos
9957 comments
by JackLeg
24868 photos
9957 comments
by cranbrook2
24868 photos
9957 comments
» Online Users: 36
10 members and 26 guests
AlexL , AndyBarnhart , jerrye , mlzettl , NCPete , Partman , rsitzejr , sawduster , TN Woodie , TopKnot
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 08-16-2008, 09:38 PM   #1
DQ
City: Littleton
State: NC
County: Warren
Threads: 132
Avg Visit Freq/Week
= 3.50 over 30 days
Does anyone have any hints on achieving the perfect half mitered lap joint? I have used two versions from Woodsmith and come along fine until the mitered cuts are made to join the pieces together. They are lined up looking from the rear of the tablesaw even with the corner, looks simple but I can't get a perfect cut each time. I am using a block with hopes of each cut being the same, occasionally one or two will cut too far up into the shoulder distroying my perfect cut. Comments welcomed.
Show Printable Version Email this Page   Quote this post in a PM to lwhughes149
Old 08-16-2008, 10:48 PM   #2
City: Apex
State: NC
County: Wake
Threads: 234
Avg Visit Freq/Week
= 6.77 over 30 days
If memory serves me correct, and it may not, I remember these as having one member square, with a miter on the face. The other is a miter, with the back removed. If this what you are trying to do, I would use a router with a pattern bit to remove the waste. Cut a 45 on a piece of stock, and clamp it to square end member. Using 45 as a guide for bearing, hog out the waste. Use a square end board to guide router bit and hog out back of mitered piece. Clear as mud? Bruce
Show Printable Version Email this Page   Quote this post in a PM to junquecol
Old 08-16-2008, 11:03 PM   #3
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 47
Avg Visit Freq/Week
= 6.30 over 30 days
Are you using a router or a tablesaw with dado?. I have had problems with work rocking up on both, so I usually place a feather board on the fence to keep the work flat to the table. If you are using a plunge router to remove the waste, I can't help much except to say I have best luck taking thin cuts and making multiple passes.
This is just technique info, as I have not made any half-lapped miter joints yet, so take it for what it may be worth to you.
__________________
My only regret in life is that I did not listen more and talk less
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Old 08-16-2008, 11:37 PM   #4
Threejs's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 27
Avg Visit Freq/Week
= 6.77 over 30 days
I have never made this joint (that I can remember), but "The Joint Book" shows that you should make a jig like this one to use on your table saw.
Show Printable Version Email this Page   Quote this post in a PM to Threejs
Old 08-17-2008, 12:31 AM   #5
DQ
City: Littleton
State: NC
County: Warren
Threads: 132
Avg Visit Freq/Week
= 3.50 over 30 days
The technique that I am using this second time, comes from Woodsmith, I will give the book number tomorrow am, it calls for a jig, which I made and used, that part of the process worked great, the jig puts the angles in place, the problems comes when the last cuts are made. Will give book number for those who have woodsmith. It clearly shows the problem I have had on both applications.
This is a joint that must be mastered, it is a good joint with lots of glue strength, can be used in so many applications in the woodworking of furniture to say nothing of picture frames. Woodsmith has a demo that shows how to make and use the jig that I made for my second attempt. It looks so simple that when I made one of the cuts into the shoulder I was supprised, I just knew I would be able to make my perfect each and everytime. Not so. I will not give up.
If memory serves me correctly the book number is 167
Old 08-17-2008, 09:19 AM   #6
Threejs's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 27
Avg Visit Freq/Week
= 6.77 over 30 days
Don't know if you have seen this, but this is a video from woodsmith, in reference to the article in issue 167.
http://www.woodsmith.com/issues/167/...lf-lap-joints/
Old 08-17-2008, 09:35 AM   #7
Vice-President
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 117
Avg Visit Freq/Week
= 7.00 over 30 days
The jig that Threejs (David) suggests is a good one as long as the stock is flat on both sides and equal thickness. I have used a dado blade on my table saw to cut half laps with a miter gauge, but it is very important to keep the stock tight to the table when making the cuts. All of the stock must be milled exactly to the same thickness as well. If you want to make this joint using decorative framing stock, then the top cut (through the uneven decorative side) can be done on a radial arm saw equipped with a dado blade. I would place stock-holding fences on the RAS table (like David's jig above, but secured to the table) to insure the accuracy of the 45 degree miter angle.
__________________
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 08-17-2008, 10:55 AM   #8
DQ
City: Littleton
State: NC
County: Warren
Threads: 132
Avg Visit Freq/Week
= 3.50 over 30 days
David & Rob, I you will look at the video, come to the last cuts where you have removed the jig and are making the last cuts at 45 degree angles, stop set on each cut to keep the cuts the same, you are seeing the cut from the backside of the tablesaw and coming to the fence side of the point, that is the place where I am having trouble, some come out great with a perfect miter on the final piece but some will cut too deep into the shoulder. I am used two woodsmith examples and had the same results each time. I think it is just difficult to see the line up with the saw blade from the rear of the tablesaw, I have a outfeed table behind my tablesaw.
Closed Thread
half , joing , lap , mitered
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
I Had the Mortise Half Done LeftyTom General Woodworking 2 01-07-2008 11:05 PM
a box half a%%ed finnished FredP General Woodworking 17 06-17-2007 08:36 AM
Claiming Half the Basement LeftyTom Workshops 10 04-26-2007 04:08 PM
half gloat walnutjerry Old Off Topic Forums 11 04-01-2006 01:37 PM
Resaw it for me and I will give you half Rob-bee General Woodworking 3 01-13-2006 12:16 AM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,138
Threads: 16,404
2nd Top Poster: jeff... (6,359)
Welcome to our newest member, gachua
» Today's Birthdays
None
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
