» Upcoming Events |
Klingspor Wood Workers Show Case - Raleigh, NC -- September 11
Klingspor Extravaganza - Hickory, NC -- October 29 and 30
2011 North Carolina Woodworker Calendar Contest
Entry deadline by August 16th Click for more!!
Welcome New Member Chat! Every Thursday evening at 7:30pm Click here for more!
11-16-2006, 12:32 AM
#1
freud dado tear out?
City: Durant
State: OK
County: Bryan
I just bought a freud dado and it tears out (red oak) with every pass I take. The only way I can keep it from tearing out is using a backer board on the piece that I want to dado. Am I doing something wrong? I want to make a few fingerjoints and using a backer board with my jig would be a huge PAIN. Any help would be appreciated..... Thanks in advance.
11-16-2006, 07:48 AM
#2
City: High Point
State: NC
County: Guilford
Avg Visit Freq/Week = 0.08 over 180 days
Re: freud dado tear out?
Most dado sets these days are made with negative hook angles to reduce face tearout/chipping and this can result in blowout at the back of the cut, particularly when making deep cuts. The backer board is the most sure fire way to reduce or eliminate it. Making multiple passes will help but is not necessarily a good idea for box joints because each subsequent pass would have to register exactly or the fit of the joint will suffer. The SBOX8 box joint set we make has positive hook angles so it is less prone to blowout.
11-16-2006, 12:09 PM
#3
City: Durant
State: OK
County: Bryan
Avg Visit Freq/Week = 0.00 over 180 days
Thanks for the info.
11-16-2006, 12:15 PM
#4
City: High Point
State: NC
County: Guilford
By the way, welcome to the group!
11-16-2006, 12:20 PM
#5
City: Hope Mills
State: NC
County: Cumberland
Avg Visit Freq/Week = 6.57 over 180 days
Brad, welcome to the site!
which dado set do you have? The dial-a-width set has recently been reviewed, and considered a solid performer, I don't have nearly that kind of budget and am considering the SD-208, which generally runs around $95-100... Interested in which set you are experiencing the issues with. thanks!
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it. Henry David Thoreau
11-16-2006, 12:31 PM
#6
City: Durant
State: OK
County: Bryan
It is the DD208. It is the same as the SD208 but the DD has the perma shield covering I think. Other than a little bit of tear out it works great. Square corners, flat bottoms, everything you want a dado to do. I have never had a dado before and was thinking I may be doing something wrong to cause the tear out. I will just have to get used to using a backer board to prevent it. Thanks
11-16-2006, 12:43 PM
#7
City: Hope Mills
State: NC
County: Cumberland
Thanks for the quick response! It looked like a good piece, but if something is available at Lowe's and Sears? Prolly gonna get the box set, too. We'll see what the future budget allows.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
How to get discount qualified
» Stats |
Members: 4,585
Threads: 30,664
Top Poster: DaveO (15,152)
| Welcome to our newest member, JonathanK |
