» Announcements | Everyone Log on at 9:00PM Thursday December 4th to set a members online record.  |  |
06-18-2008, 08:32 PM
#1 | | Administrator Senior Moderator
Name: Tracy City: Salisbury State: NC County: Rowan Join Date: Feb 2008 Age: 47 Avg Visit Freq/Week = 7.00 over 30 days | Well I think my first cedar box is a disaster.
The tails in my joints were breaking off, and it did not go together as well as expected. I used the jig I bought from Woodline; http://www.woodline.com/p-1825-route...ry-system.aspx at the Charlotte woodworking show for the first time. The cedar seemed to be brittle in the joints. Is this a characteristic of cedar? I planed it down to 1/2" to make the box. As for the finish, I think it went well. The box was rushed a little as I usually do. I have got to learn to not get in a hurry and I think my projects will turn out much better. The next one will be better, cause I am going to slow down.
__________________ Tracy Making Friends One Post At A Time  |
06-18-2008, 08:45 PM
#2 |
Name: Rob City: Sanford State: NC County: Lee Join Date: Mar 2008 Age: 44 Avg Visit Freq/Week = 7.00 over 30 days | I haven't had much luck with box joints, I bought the same jig. Jig worked well, I just think I lacked the patience to set everything up.
__________________
Learning to turn one stick at a time.
06-18-2008, 08:47 PM
#3 |
Name: Mike City: Westfield State: NC County: Stokes Join Date: Dec 2005 Age: 51 Avg Visit Freq/Week = 7.00 over 30 days | Yeah red cedar is pretty brittle, I don't even try to dovetail it.
(oh, I thought it was dovetailed)
I'm working on a cedar box, maybe I can make some pictures later.
Keep working at it, maybe try hand cut dovetails, they work better in hard to manage wood.
Reason: saw other post after I started.
06-18-2008, 08:59 PM
#4 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 30 days | ERC is a ***** to work with. It is very brittle and will give you problems with machine cut DTs or box joints. I actually find the fitting of box joints more difficult than DTs. There is so much more room for error. If you have to force box joints together, something is sure to break off. But if they aren't a force fit, then it doesn't look tight enough
Wax on, wax off Grasshopper. Only practice will make you better.
Dave
__________________   Nothing left to do but smile, smile, smile
--Dr. Seuss
06-18-2008, 09:08 PM
#5 | | Administrator Senior Moderator
Name: Tracy City: Salisbury State: NC County: Rowan Join Date: Feb 2008 Age: 47 Avg Visit Freq/Week = 7.00 over 30 days | Originally Posted by DaveO ERC is a ***** to work with. It is very brittle and will give you problems with machine cut DTs or box joints. I actually find the fitting of box joints more difficult than DTs. There is so much more room for error. If you have to force box joints together, something is sure to break off. But if they aren't a force fit, then it doesn't look tight enough
Dave  That is exactly the problem I had. Too tight and the joints broke, too loose and the joints looked like Fido's ***. This will be the project that I learn from. I got enough cedar to screw up several of these and not spend a ton of $$. I have gave some away (which makes me happy) and have some to work with. Maybe dove tails will be the next trial. Somewhere in this the Loml will net a new jewelry box.
06-18-2008, 09:39 PM
#6 |
Name: Alan Schaffter City: Washington State: NC County: Beaufort Join Date: Dec 2005 Avg Visit Freq/Week = 7.00 over 30 days | As others have said, dry ERC can be brittle. I use a saw/dado blade, a box joint jig, and my table saw. I have never made box joints with a router, but suspect some of the principles are the same: - Use a good jig. I prefer a box joint jig and a tablesaw for cutting box joints.
- Whatever you use, ensure the saw blade or router bit is SHARP
- Feed the stock carefully and slowly
- Make test cuts to ensure your settings are correct
I made two ERC boxes for some old sharpening stones (I don't know why, but it seems to be a tradition to store sharpening stones in cedar boxes like the ones below from Woodcraft??). I milled my ERC box stock to 1/4" and cut the box joint fingers 1/8" which is pretty thin. I had no problems with over-tight fit and did not break any fingers.  |
06-18-2008, 09:43 PM
#7 |
Name: Phillip City: Lexington State: NC County: Davidson Join Date: Jun 2008 Age: 48 Avg Visit Freq/Week = 7.00 over 30 days | Tracy, if you want to learn patients you should take up scrolling - that will really slow you down  I haven't tried it yet but there is away you can cut those dovetails on the scrollsaw - I will try it soon and let you know how it comes out
Phillip
__________________
My Saw Is Making Dust |
06-18-2008, 10:17 PM
#8 | | Administrator Senior Moderator
Name: Tracy City: Salisbury State: NC County: Rowan Join Date: Feb 2008 Age: 47 Avg Visit Freq/Week = 7.00 over 30 days | Originally Posted by PLC'woodart Tracy, if you want to learn patients you should take up scrolling - that will really slow you down  I haven't tried it yet but there is away you can cut those dovetails on the scrollsaw - I will try it soon and let you know how it comes out
Phillip It is strange that I have all the patience that I need in ever thing else in my life. But when it comes to building something I have NO patience, I guess I am too anxious to see the outcome. I can disassemble and rebuild the most intricate piece of equipment or electronic device and take hours to do it; Build a wooden box and it comes out like this one    .
I will somewhat conquer this thing called woodworking, all in due time with the instruction and help from this group of people.
06-18-2008, 10:20 PM
#9 |
Name: Mike City: Westfield State: NC County: Stokes Join Date: Dec 2005 Age: 51 Avg Visit Freq/Week = 7.00 over 30 days | I cut the dovetails for my first machinist tool box in 3/8 plywood with a scroll saw. It worked pretty well and the box is still together. |
06-18-2008, 10:38 PM
#10 | | Director Moderator
Name: Tom City: Raleigh State: NC County: Wake Join Date: Jul 2005 Age: 46 Avg Visit Freq/Week = 7.00 over 30 days | I personally don't care to ever work with ERC again for all the reasons above. You are a better man then I. |
06-19-2008, 07:06 AM
#11 |
Name: Danny City: Seagrove State: NC County: Montgomery Join Date: Oct 2006 Age: 51 Avg Visit Freq/Week = 6.77 over 30 days | I use tablesaw with dado blade, a jig & help from Tom Hintz's website.
Danny |
06-19-2008, 07:29 AM
#12 |
Name: Tom City: Yadkinville State: NC County: Yadkin Join Date: Jun 2006 Avg Visit Freq/Week = 6.53 over 30 days | Tracy. hang onto that box. It will be a reminder of how you have progressed in WW'ing. If anyone asks, tell them it is your rendition of "primitive WW'ing".
__________________
The Tao of Tom: Be good to your pet(s). Invest in good Karma.
06-19-2008, 07:32 AM
#13 |
Name: Robert City: Youngsville State: NC County: Franklin Join Date: Oct 2007 Avg Visit Freq/Week = 6.07 over 30 days | Oh I should have such disasters .gif) I would be tickled to death with results like that ! Cedar is brittle when scrolling as well , but that is what CA glue is for !
I have some good info on scrollsaw dovetails if you are interested
as for being on a hurry, I can relate to that as well. My solution is to have one or more projects going so I can work on something else while other things are drying
Methinks you have done well sir
__________________
...~Robert~
It ain't scrap till I say it's scrap ! |
06-19-2008, 08:30 AM
#14 | | Moderator
Name: Scott City: Cary State: NC County: Wake Join Date: Jul 2007 Avg Visit Freq/Week = 6.77 over 30 days | Tracy I would be proud of a 1st attempt like that. I believe we learn from every woodworking project. I have cut box joints on a scroll saw with some success but I have not tried cedar.
I saw a live demo of this Lee Valley jig at the spring Raleigh Klingspor show. Might be the way to go.
__________________
Making Saw Dust With a Scroll Saw
Scott |
06-19-2008, 12:35 PM
#15 |
Name: Rick City: Dobson State: NC County: Surry Join Date: Dec 2005 Avg Visit Freq/Week = 3.73 over 30 days | Tracy,
Dovetails or Box joints are a pain in ERC. I know I've tried many times. I now use either Miller dowels or brass pins at the joints. Quicker and less heart ache.
Rick Doby |
Posting Rules
Members: 2,138
Threads: 16,404
2nd Top Poster: jeff... (6,359) | | Welcome to our newest member, gachua | » Today's Birthdays | |
None
