» Upcoming Events |
Klingspor Wood Workers Show Case - Raleigh, NC -- September 11
Klingspor Extravaganza - Hickory, NC -- October 29 and 30
2011 North Carolina Woodworker Calendar Contest
Entry deadline by August 16th Click for more!!
Welcome New Member Chat! Every Thursday evening at 7:30pm Click here for more!
02-12-2009, 06:08 PM
#1
F-Clamps or Pipe Clamps
City: Yadkinville
State: NC
County: Yadkin
I am about to try my hand at gluing panels. I am building a small two-shelf "entertainment center" for LOML's treadmill room. I plan to glue some 1/2" oak to make the 17" x 24" shelves. I am using oak of varying widths, the two widest pieces at the outside edges of the panels.
I have enough of the F-style clamps for the job, but will they provide adequate clamping pressure (as the bars do flex slightly with enough pressure)? Or should I invest in some pipe clamps for the task?
__________________
The thing that holds up all my woodworking is simply getting started.
02-12-2009, 06:17 PM
#2
Administrator
City: Clayton
State: NC
County: Johnston
Avg Visit Freq/Week = 6.22 over 180 days
Re: F-Clamps or Pipe Clamps
IMO, pipe clamps are better than F-style clamps for flat panel glue-ups due to a more rigid bar. But both are not as good as parallel jaw clamps.
You can make your F-style much more functional by using cauls like Bowclamps or making your own. The use of cauls will counter act the bowing of the F-style clamps thin bars and help to keep your panel flat.
Of course you could go very low tech and make a clamping table that uses wedges and not need any other clamps
Dave:=)
__________________
  Nothing left to do but smile, smile, smile
--Dr. Seuss
#3
Administrator
City: Raleigh
State: NC
County: Wake
Avg Visit Freq/Week = 6.96 over 180 days
I've glued up a dozen or so panels using F-style clamps. If you're using the Bessey Tradesman clamps, no problem. The Harbor Freight ones are OK up to 18", the 24" and 36" flex a bit too much for my taste. But, if you use enough of them (say every 8"), you'll be able to generate more than enough pressure. If you're flexing the bar, you're probably over tightening them.
Pipe clamps are great, relatively cheap, and can generate a lot of pressure. None of which is needed provided you joint the edges of the boards properly. Pipe clamps do have the advantages that they sit on "feet", making it easy to do all the alignment.
The best clamps for panel glueups are parallel clamps. Not because of clamping pressure (they're actually at the low end of the scale) , but because they're really easy to use. Big feet, wide jaws (sounds like my dog!) They're also the most expensive (again, sounds like my dog!).
02-12-2009, 07:05 PM
#4
City: Yadkinville
State: NC
County: Yadkin
Avg Visit Freq/Week = 6.14 over 180 days
Thanks, guys. I will have a go at it with the F-clamps. The edges are jointed, but there is the micro gap here an there (operator error on the jointer).
__________________
02-12-2009, 10:10 PM
#5
Administrator
City: Raleigh
State: NC
County: Wake
I've had those. If possible, try to correct it before you do your glueup. A hand plane can fix a lot of problems. Once I had a sizable dip, so ripped a super thin piece (almost a shaving) on the table saw, glued it, then rejointed.
Of course, CA glue and a little sawdust does miracles too
Biggest problem I had with F-clamps is the handles. They get in the way, which you can fix with a platform. I took a box of leftover tile (i.e. something heavy) and covered it with wax paper. Glued the boards and put a clamp on either side of the panel. Then carefully put it on the box (it overhangs on all sides). Then added the rest of the clamps.
Another option is to take a two 2x4's and cut notches for the bars to rest in. Not unlike those K-body clamps  That keeps the handles elevated above the table.
02-12-2009, 10:25 PM
#6
City: Pfafftown
State: NC
County: Forsyth
Avg Visit Freq/Week = 4.08 over 180 days
I used the F-clamps for my first projects and they worked fine. But, I bought some parallel clamps (Bas was the enabler there) and I liked them so much that I bought four more. They really work nice.
Here is a great deal on some parallel clamps in the classified section. I wish these were posted before I bought mine. I wish someone would buy them because I keep looking at them!
02-12-2009, 10:26 PM
#7
City: Oxford
State: NC
County: Granville
Avg Visit Freq/Week = 7.00 over 180 days
My humble opinion only, so it is worth exactly what you have paid for it -----
95% of the time people clamp too tightly anyway. If the stock is properly prepared then the pressure of an F-
clamp without bowing the bar is enough to do the job. In most cases, too much pressure leads to glue starvation in the joint and results in a weak joint.
George
__________________
2B1ASK1
02-13-2009, 09:24 AM
#8
City: Clayton
State: NC
County: Johnston
Avg Visit Freq/Week = 5.21 over 180 days
George
Here, here George
__________________
Jimmy
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did" Mark Twain
02-13-2009, 10:21 PM
#9
City: Charlotte
State: NC
County: Mecklenburg
Avg Visit Freq/Week = 2.61 over 180 days
Another here here  to George and Jimmy. Too much pressure especially with pipe clamps.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
pipe clamps!!!
Vanilla Gorilla |
Hand Tools and their Use |
22 |
08-14-2008 07:51 AM |
clamps
nelsone |
"How To" Forum |
8 |
12-31-2006 03:46 PM |
How to get discount qualified
» Stats |
Members: 4,585
Threads: 30,664
Top Poster: DaveO (15,152)
| Welcome to our newest member, JonathanK |
