North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 02-16-2007, 09:53 PM   #1
Dust Collection
City: Horse Shoe
State: NC
County: Henderson
Threads: 8
Show Printable Version Email this Page   Quote this post in a PM to sammy
sammy sammy is offline 02-16-2007, 09:53 PM
im looking for reasonably priced duct for my shop. I want to use metal pipe vs. PVC. I am currently talking to KB Duct but i think they will be way out of my price range. The saleman basically told me that they are high priced and we should not waste either of our time. So i wanted to see what experiences you all have had and if you can give some names i could contact.
Old 02-16-2007, 10:04 PM   #2
Tarhead's Avatar
City: Concord
State: NC
County: Cabarrus
Threads: 217
Avg Visit Freq/Week
= 6.96 over 180 days
Re: Dust Collection
NB Handy in Greensboro has one of the largest HVAC warehouses in the state. The have a retail counter and will take you back and let you see what they have and let you compare different options. Prices are consistantly less than Lowe's and HD and they have multiple choices of all the pipe, fittings and conectors you would need.
Show Printable Version Email this Page   Quote this post in a PM to Tarhead
Old 02-16-2007, 10:47 PM   #3
City: Apex
State: NC
County: Wake
Threads: 301
Avg Visit Freq/Week
= 6.30 over 180 days
Re: Dust Collection
For my info only, why do you want metal instead of PVC. I find PVC to be more flexable. The joints don't have to be solvent welded ( glued). This makes it easy to rearrange system when a new machine is added. Almost totally leakproof.
Show Printable Version Email this Page   Quote this post in a PM to junquecol
Old 02-16-2007, 10:48 PM   #4
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
= 6.53 over 180 days
Re: Dust Collection
For me, I ordered all of my major fittings from Oneida (wyes, elbows, etc). I can't say they were the cheapest, but they were as cheap as I knew of at the time. I bought all of my pipe and reducers at the BORG. Although the gauge is different, I have had zero problems with the pipe collapsing.
FWIW, the 4" aluminum blast gates by shop fox are as cheap as you will find anywhere. For larger sizes, your guess is as good as mine.
You have my prayers going the metal route. Please do a few things I did not do.
WEAR GLOVES AT ALL TIMES
Use a strait line laser (if you have one) to run your pipe straight.
Get a good set of shears and a good set of crimpers (you will have to recrimp some of the fittings as they do not have enough "crimp" on them.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 02-16-2007, 11:13 PM   #5
NCPete's Avatar
City: Hope Mills
State: NC
County: Cumberland
Threads: 213
Avg Visit Freq/Week
= 5.99 over 180 days
Re: Dust Collection
Travis, you forgot to mention this one:
have plenty of bandaids on hand, and maybe some larger bandages
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it.
Henry David Thoreau
They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
Show Printable Version Email this Page   Quote this post in a PM to NCPete
Old 02-17-2007, 12:37 AM   #6
Executive Vice-President
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 155
Avg Visit Freq/Week
= 6.88 over 180 days
Re: Dust Collection
Sammy, I suspect that you needed to let folks know the size of your system as part of the equation -- your 3HP Grizzly Cyclone has an 8" diameter intake port and IIRC, you want to run a mainline trunk 40' or so down the centerline of your shop [Sammy's shop is 32 x 60, if I recall]. As you've already found, spiral metal "quick connect" ductwork is very expensive, but if you can work with 6" diameter, you'll find that 6" Sewer and drain PVC is lots less expensive. You can assemble joints without glue and a wide range of fittings are available, including wye's, sweep elbows and the like (including reducing versions). Check out McMaster-Carr for fittings (you may find some at Lowe's in the 6" size, too) and suppliers like Ferguson's or Hajoca will carry the 6" light green bell-end pipe in 10' lengths (~$2.50 ft +/-). 4" drops -- use S&D from Lowe's for about $1/ft. I've made my own blast gates -- we've got some info in the Links Library.
Just my $.02 -- Hope this helps -- Rob
__________________
Rob Payne
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 02-17-2007, 10:00 AM   #7
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
Re: Dust Collection
Yes, I forgot the band aids. I got one bad cut doing the piping.
If you are running 8", I got the pipe at the Borg for it as well. The 90's at the BORG are a royal PITA being such thin metal and don't have enough radius. I kept my pipe sizes primarily to 8 and 6 inches to minimize transitions and not have to have so many different sizes of pipe.
Old 02-17-2007, 11:52 AM   #8
dino drosas's Avatar
City: Myrtle Beach
State: SC
County: Horry
Threads: 93
Avg Visit Freq/Week
= 6.69 over 180 days
Re: Dust Collection
I used spiral metal duct from Penn State Industries and found them to be the least expensive overall. The Onedia duct wasn't too bad but the connector clamps got the price up over the top. I started the ducting comming through the wall with a three way wye with 6" main lines and did all the reducing at the drops. For the duct collector , I went with the ClearVue and could not be happier. 5 hp at less than $1,000.00 including the shipping and better preformance and specs than the rest of the field. My shop is DUSTLESS! I have emptied the 30 gal hopper about five times and still haven't gotten as much as a teaspoon of fine dust from the bottom filter cleanout. If any of you are ever in Myrtle Beach, stop by and have a look-see (probally be a cold beer close by).
Show Printable Version Email this Page   Quote this post in a PM to dino drosas
Old 02-17-2007, 12:04 PM   #9
City: Myrtle Beach
State: SC
County: Horry
Threads: 93
Avg Visit Freq/Week
Re: Dust Collection
Thes pictures should have been attached to my previous post.
Dino
Old 02-17-2007, 12:07 PM   #10
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
Re: Dust Collection
How is the dust collection on your bandsaw? Ohe hookup or two?
Reason I ask, is mine is less than what I would call satisfactory.
Old 02-17-2007, 12:25 PM   #11
City: Myrtle Beach
State: SC
County: Horry
Threads: 93
Avg Visit Freq/Week
Re: Dust Collection
Dust pickup on bandsaw is good unless I an resawing heavy stock(8 to10 inches), I only have one dust port but am getting ready to add another to the top cabinet. Since I have sealed all seams with foam weather seal, it is actually quite good.
Dino
Old 02-17-2007, 12:28 PM   #12
NCPete's Avatar
City: Hope Mills
State: NC
County: Cumberland
Threads: 213
Avg Visit Freq/Week
Re: Dust Collection
I could probably be entertained by the chips flying throught the Clearview cyclone
__________________
Henry David Thoreau
Old 02-17-2007, 03:42 PM   #13
toolferone's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 172
Avg Visit Freq/Week
= 1.91 over 180 days
Re: Dust Collection
Yup me too !
__________________
Tom
Southeast Woodworking Specialist
www.dreamshopwoodworks.com
Show Printable Version Email this Page   Quote this post in a PM to toolferone
Closed Thread
collection , dust
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dust Collection woodrat General Woodworking 6 11-09-2006 01:20 PM
Dust Collection SteveColes Power Tools and Their Use 14 05-02-2006 01:25 PM
Dust Collection Travis Porter Hand Tools and their Use 8 03-18-2006 09:28 AM
Dust Collection Travis Porter General Woodworking 5 02-24-2006 03:33 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,667
Threads: 25,111
Top Poster: DaveO (14,702)
Welcome to our newest member, Brockmania
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
