» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  | |
01-03-2006, 09:52 PM
#1 | | Dado's with a Router? Name: Wayne City: Cary State: NC County: Wake Join Date: Dec 2005 Age: 62  01-03-2006, 09:52 PM
Moderator Hi All,
Need some advice. I have not yet invested in a dado set for my tablesaw and continue to depend on my using my router for cutting dado's. My latest undertaking is a cabinet to house my new compressor and bench grinder and I attempted to use the router for the shelf dado's. I am using 3/4" plywood that of course is not exactly 3/4" - just a wee bit less, hense my joint is sloppy when using a 3/4" straight bit in the router. Do you know of a straight router bit that I could use in this application? (I seem to recall seeing something in a magizine by CMT (i think), but am not sure if that is what I need and where to get one. (I don't have the patence to use a 1/2" bit and nudge my way to the correct width of dado.)
I would appreciate any suggestions that you could send my way.
Thanks,
__________________ ..............found out many years ago that Elbow Grease doesn't come in a bottle!!!! | | Views: 1302 |
01-03-2006, 09:59 PM
#2 |
Name: Monty City: Hickory State: NC County: Catawba Join Date: Jul 2005 Avg Visit Freq/Week = 2.02 over 180 days | Re: Dado's with a Router? I bought the undersized plywood bit set from Freud.
All these bits are 1/32" undersized, IIRC.
The other option, of course, is to use an adjustable dado jig with a ½" bit, in two passes. |
01-03-2006, 10:04 PM
#3 | | Moderator
Name: Wayne City: Cary State: NC County: Wake Join Date: Dec 2005 Age: 62 Avg Visit Freq/Week = 7.16 over 180 days | Re: Dado's with a Router? Thanks. I will check these bits out......
#4 |
Name: D L Ames City: Fayetteville State: NC County: Cumberland Join Date: Oct 2005 Age: 51 Avg Visit Freq/Week = 0.00 over 180 days | Re: Dado's with a Router? I have the same set by Freud, they seem to work pretty good. I wish I could have gotten them with 1/2" shanks though.
D L
__________________ People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. George Orwell (1903 - 1950) |
01-03-2006, 10:44 PM
#5 | | Executive Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 67 Avg Visit Freq/Week = 6.88 over 180 days | Re: Dado's with a Router? Canuk,
I have a 9-piece set of bits from Woodline America that give you both undersize and oversize bits along with 1/4", 1/2" and 3/4" straight bits on 1/2" diameter shafts. They are one sale right now for $39 on their website at http://www.woodline.com/scripts/prod...?idproduct=591. I bought mine at the Charlotte WW Show last year and they work well. You can also get a 1/4" shank set for $49. While not the quality of the Freud set, they are carbide and do a good job (I always score my dado lines and tape them on plywood to avoid chipout.) I also use a 50" Tru-Grip Clamp 'n Tool Guide to guide the cut. BTW, when you do buy a dado blade for your tablesaw, I recommend the Freud SD506 (6") or SD508 (8"). They are sweet!
__________________
Rob Payne  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
01-03-2006, 10:46 PM
#6 | | Member
Name: Steve DeWeese City: Horse Shoe State: NC County: Henderson Join Date: Oct 2005 Age: 45 Avg Visit Freq/Week = 0.00 over 180 days | Re: Dado's with a Router? You can make a simple set of jigs that will let you get it exactly right without "sneaking up". Below is a quick sketch:
Hopefully this will make sense with the sketch. Above is the board to receive the dado and the two jigs made from scrap. Take a straight piece of wood 3/4" x 2" x more than the length of your dado. Glue and screw that to a piece of plywood or masonite 1/4" x 6" x the length of board #1. Clamp that overhanging a bench. Put a 1/2" straight bit in your router and extend it more than 1/4". Run the router along the fence on top of the 1/4" piece. That will trim the jig to the exact width from the base of your router to the outside edge of the bit. Do the same on the second jig. Clamp jig #1 along the top layout line of your dado and then space jig #2 using a piece of your plywood in between the two jigs. Clamp jig 2 in place, remove the "spacer" and run the router (set to the depth of your dado plus the thickness of the base of the jig (1/4") along both jig fences. You will have an exact fit with a flat bottom and very simple layout. If this doesn't make sense, I'll try and post more sketches to clear up any questions. |
01-03-2006, 10:53 PM
#7 | | Executive Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 67 Avg Visit Freq/Week = 6.88 over 180 days | Re: Dado's with a Router? Steve's method is a really good one and one that's very easy to implement -- but remember that you need to make a different set of these jigs if you're going to use a 3/8" bit for an undersized 1/2" dado, because the router-to-bit distance changes. But of course, all of us have plenty of scrap!!
__________________
01-03-2006, 10:59 PM
#8 | | Member
Name: Steve DeWeese City: Horse Shoe State: NC County: Henderson Join Date: Oct 2005 Age: 45 Avg Visit Freq/Week = 0.00 over 180 days | Re: Dado's with a Router? If short on scrap just call Dave O |
01-03-2006, 11:51 PM
#9 |
Name: D L Ames City: Fayetteville State: NC County: Cumberland Join Date: Oct 2005 Age: 51 Avg Visit Freq/Week = 0.00 over 180 days | Re: Dado's with a Router? Dave, send me some scrap so I can make one of these will you?
D L
01-04-2006, 01:30 AM
#10 |
Name: Monty City: Hickory State: NC County: Catawba Join Date: Jul 2005 Avg Visit Freq/Week = 2.02 over 180 days | Re: Dado's with a Router? Here, take a look at this, too. Same idea, just uses a bearing guided bit. Either way, the idea is to rout the groove exactly the same width as the thickness of the shelf.
Hope this helps.
You do realize, of course... now that you've received all this help, you have to show us the finished project when you're done!  |
01-04-2006, 09:14 AM
#11 |
Name: Joe City: Holly Springs State: NC County: Wake Join Date: Sep 2005 Age: 66 Avg Visit Freq/Week = 7.00 over 180 days | Re: Dado's with a Router? This is a jig I made from Shopnotes plans. They have a short video on their site. It works great. I use a 3/8 spiral bit no matter what size groove I'm cutting.
Found the url http://www.shopnotes.com/main/sn76-toc.html
01-04-2006, 09:25 AM
#12 |
Name: David City: Pittsboro State: NC County: Chatham Join Date: Oct 2005 Age: 52 Avg Visit Freq/Week = 3.50 over 180 days | Re: Dado's with a Router? I like the bearing guided bit method myself
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux |
#13 |
Name: D L Ames City: Fayetteville State: NC County: Cumberland Join Date: Oct 2005 Age: 51 Avg Visit Freq/Week = 0.00 over 180 days | Re: Dado's with a Router? Joe, does that work with a bushing guide in the router base or a bit with a pilot bearing like Insom posted?
D L
01-04-2006, 09:27 AM
#14 |
Name: Charles City: High Point State: NC County: Guilford Join Date: Nov 2005 Avg Visit Freq/Week = 3.31 over 180 days | Re: Dado's with a Router? Originally Posted by D L Ames I have the same set by Freud, they seem to work pretty good. I wish I could have gotten them with 1/2" shanks though.
D L We are coming out with a 1/2" shank set very soon. Item number will be 89-650. Should be available within about 2 months.
Charles M
Freud America, Inc. |
01-04-2006, 09:30 AM
#15 |
Name: Charles City: High Point State: NC County: Guilford Join Date: Nov 2005 Avg Visit Freq/Week = 3.31 over 180 days | Re: Dado's with a Router? The sets are nice to have but you can also get an individual bit for 3/4" plywood. Freud item number for the 1/2" shank version is 16-116 and 1/4" shank is 16-103.
Charles M
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 3,663
Threads: 25,106
Top Poster: DaveO (14,701) | | Welcome to our newest member, Keith Senderak | |
