» Announcements | Everyone Log on at 9:00PM Thursday December 4th to set a members online record.  |  | |
07-30-2008, 11:19 PM
#1 |
Name: Brian City: Raleigh State: NC County: Wake Join Date: Jun 2008 Age: 40 Avg Visit Freq/Week = 6.77 over 30 days | Was wondering what the best way to cut drawer openings from solid stock is. I'm going to attempt to build my first complete small (40lx30wx21h) coffee table and am trying to get an idea for what I'm going to be getting myself into and what tools or tool accessories may be required. I've got a PC circular saw, a decent (I think) Skil router, a so so jigsaw that I've almost replaced several times, and a Delta 10" table saw.
Top is 3/4 BB, table skirt is going to be 13/16 poplar and legs are going to be lodge pole pine logs.
My question is, what is the best way to cut the drawer opening in the front skirt? Can I mark it out, drill the corners and cut with a jigsaw or would my best bet be using a router and some type of template? I'm sure the router method would probably come out cleaner, but my problem with that is my present router doesn't accept guide bushings without a proprietary adapter which I might not be able to get in time to do me any good. Not to mention the couple of places I've found that have it are charging $10 and up to ship the $2-3 part
Also, if I use a 4" high drawer should I shot for a minimum skirt height of say 5.5 or 6"?
TIA,
Brian.
__________________
If there's a New way, I'll be the first in line.
BUT, it BETTER work this time. Dave Mustaine. www.housecreekcreations.com
Games, Art, and More.
07-30-2008, 11:31 PM
#2 | | Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 66 Avg Visit Freq/Week = 7.00 over 30 days | The straightest and most accurate drawer cutout is made by selecting a board at least 1/4" wider than your finished size for the full apron and ripping the stock carefully to remove a section the exact height of your desired opening (the apron is now in three pieces). Then crosscut the center of those pieces to remove the drawer opening and glue the apron stock back together. This works even with figured wood as the glue joint causes a minimal offset. Remember to trim the apron to the final width if you started extra wide.
__________________
Rob  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
07-30-2008, 11:44 PM
#3 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 30 days | Yep, I would 100% agree with Rob. That is the method I used to make the apron and drawer face on this table -
The only gotcha is to make sure that you allow for the saw kerf in your sizing of the original board. I would add at least ¼" to the width and ½" to the length. It is always easier to trim or plane it down to size later.
Dave
__________________   Nothing left to do but smile, smile, smile
--Dr. Seuss
07-30-2008, 11:47 PM
#4 |
Name: Brian City: Raleigh State: NC County: Wake Join Date: Jun 2008 Age: 40 Avg Visit Freq/Week = 6.77 over 30 days | Rob, thanks for the response.
I can picture what you're describing and it does sound like it would produce great results if done properly. I'm a little worried though that the "additional" steps may be a bit above my current skill set and provide more opportunities for me to muck up and create scrap instead of an apron!
Brian.
__________________
07-30-2008, 11:51 PM
#5 |
Name: Brian City: Raleigh State: NC County: Wake Join Date: Jun 2008 Age: 40 Avg Visit Freq/Week = 6.77 over 30 days | Dave, thanks for the reply as well. Looks like I was typing away while you were responding as well!!
That's a very nice job on that table and I can certainly see what Rob meant by not being able to tell it was done that way. Maybe I can pull it off without sacrificing too much good wood since I only plan on doing 1 drawer. Definitely food for thought.
Thanks guys,
Brian.
__________________
07-31-2008, 12:05 AM
#6 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 30 days | Brian if your tablesaw or bandsaw is well tuned you should be able to cut a good glue line and not lose anything but the saw kerf. Even if not a few swipes with a plane or a run across the jointer will clean that up and you will still have a nice reveal on the long grain. The reveal for the sides of the drawer front can be adjusted by moving the corresponding apron sides a little to avoid dealing with the end grain fitting.
It's as easy as ripping and cross cutting a board.
Dave
--Dr. Seuss
07-31-2008, 12:13 AM
#7 |
Name: Ed City: Charlotte State: NC County: Mecklenburg Join Date: Apr 2006 Avg Visit Freq/Week = 6.77 over 30 days | I think your least opportunity for error is the way Dave and Rob described. Trying a cutout with a jigsaw will really be tough to get a straight line. |
07-31-2008, 08:52 AM
#8 |
Name: Geoff City: Lillington State: NC County: Harnett Join Date: Jan 2008 Avg Visit Freq/Week = 7.00 over 30 days | Creating scrap is how we learn!!!  Go the rip/crosscut route and see how you underestimate your capabilities. |
07-31-2008, 09:51 AM
#9 |
Name: Joe City: Holly Springs State: NC County: Wake Join Date: Sep 2005 Age: 65 Avg Visit Freq/Week = 7.00 over 30 days | Cutting a well defined rectangle from solid stock is tricky and will certainly remove too much stock. Only pic in my album I could find to show ripping/crosscutting a drawer front is below.
The top stretcher in this pic is from another piece of stock, but the drawer front, end fills and bottom stretcher are from a single board.
Here's what it looks like finished.  |
07-31-2008, 10:38 AM
#10 |
Name: David City: Raleigh State: NC County: Wake Join Date: Feb 2007 Age: 47 Avg Visit Freq/Week = 2.33 over 30 days | Dave-I built that same table just now-how funny. I drill four holes and use a jigsaw. I then use hand tools to make it square and finally with sanding. The advantage to cutting the hole on the tablesaw is that you can use the cut out for the drawer-especially good for flush fit drawers. The disadvantage is the seam that shows in the apron.
David |
07-31-2008, 05:14 PM
#11 |
Name: Brian City: Raleigh State: NC County: Wake Join Date: Jun 2008 Age: 40 Avg Visit Freq/Week = 6.77 over 30 days | Thanks everyone again for the input. I guess my concern was since I'm going to be doing butt joints (which I forgot to mention) will the end grain look noticeably odd if I go the rip/crosscut way? I guess I could just switch it around and have the end grain of the short sections show.
Also, regardless of which method I end up doing would 1/2" above and below the opening be adequate?
TIA,
Brian.
__________________
07-31-2008, 06:46 PM
#12 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 30 days | Originally Posted by farmerbw Thanks everyone again for the input. I guess my concern was since I'm going to be doing butt joints (which I forgot to mention) will the end grain look noticeably odd if I go the rip/crosscut way? I guess I could just switch it around and have the end grain of the short sections show.
TIA,
Brian. Brain now you have me confused, which is fairly easy to do  . Where are you going to be using butt joints, on the drawers or the apron to legs???
If you use the rip/cross cut method you need a minimum of ¼" wider board than your desired apron width to allow for the two saw kerfs. A ½" + additonal length is good also to allow for good grain matching and kerf loss.
Dave
--Dr. Seuss
07-31-2008, 07:51 PM
#13 |
Name: Brian City: Raleigh State: NC County: Wake Join Date: Jun 2008 Age: 40 Avg Visit Freq/Week = 6.77 over 30 days | Dave, sorry dude I'm not really relaying what I'm trying to do worth a diddley dang.
I just ran down a picture that might help better explain what I'm trying to accomplish. The difference between the pic and how I plan to build is my legs will attach behind the corners of the aprons, not notched into them. So that's where my butt joints will be. I'm also only doing 1 drawer in the center of one side of the apron.
Does it make more sense now or did I muddy the water even more? Sorry to have been so vague, I should have found a pic or drew out my plan to show it. A novel ideal huh?
Thanks again,
Brian
__________________
07-31-2008, 09:09 PM
#14 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 30 days | OK that makes more sense now. I would definitely show the end grain of the long apron side as it will be less seen. Or you might consider using a mitered joint to hide all the end grain. I don't think you will see much of a difference in the end grain with a rip/cross cut drawer method. Personally if it was me and I wanted to keep it simple, I would use either a double biscuit joint to the leg or use pocket screws. You could reinforce those with screwed corner blocks if you wanted to make it bomb proof.
Dave
--Dr. Seuss
07-31-2008, 09:18 PM
#15 |
Name: jeff... City: Stovall State: NC County: Granville Join Date: Mar 2006 Avg Visit Freq/Week = 6.77 over 30 days | Originally Posted by DaveO Yep, I would 100% agree with Rob. That is the method I used to make the apron and drawer face on this table -
Dave   oh now that nice - when did the elves make that?
__________________ "Do, or do not. There is no 'try'." -- Jedi Master Yoda |
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 2,138
Threads: 16,404
2nd Top Poster: jeff... (6,359) | | Welcome to our newest member, gachua | » Today's Birthdays | |
None
