North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 03-28-2006, 06:46 PM   #1
Cutting chamfers on T & G boards
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 692
Show Printable Version Email this Page   Quote this post in a PM to DaveO
DaveO DaveO is offline 03-28-2006, 06:46 PM
Administrator
I am going to do a bit of tongue and groove work on this tea house that I am making. I have a 1/4" slot cutting bit and the tongue will be done with a straight bit and fence. I would like to put a little chamfer where the joints come together. I know I could do it with a block plane, but I have quite a bit to do. I also would think that there is a special bit that will do it in one pass over the router table, but I would like to work with what I have. Chamfering the grooved side will be easy with a bearing chamfer bit, but I am stuck on how to do the tongue side. I would appreciate any advice, thanks in advance.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Old 03-28-2006, 08:34 PM   #2
RandyJ's Avatar
City: Macon
State: NC
County: Warren
Threads: 34
Avg Visit Freq/Week
= 5.44 over 180 days
Re: Cutting chamfers on T & G boards
Dave, as you know I'm just a beginner, but how about this. After you cut the tongues, change to a chamfer bit in the router. Raise the bit just enough to reveal part of the cutting edge and run all your tongues through the router? Don't know if this would be too much work but thought I would throw it out.
Take care,
Randy
__________________
Randy
Any compromise between the truth and a lie can ONLY be something less than the truth.
Show Printable Version Email this Page   Quote this post in a PM to RandyJ
Old 03-28-2006, 08:39 PM   #3
4yanks's Avatar
City: Southern Pines
State: NC
County: Moore
Threads: 17
Avg Visit Freq/Week
= 0.00 over 180 days
DaveO,
How about using the tilt feature on your table saw. Tilt the blade to the desired angle and then experiment with the height of the blade and fence position until you get the results you're looking for. Hope this helps.
Show Printable Version Email this Page   Quote this post in a PM to 4yanks
Old 03-28-2006, 08:52 PM   #4
erasmussen's Avatar
City: Pikeville
State: NC
County: Wayne
Threads: 164
Avg Visit Freq/Week
= 7.00 over 180 days
If I read this correctly, you are wanting a chamfer on the shoulder of the tongue to match the one on the groove, not on the end of the tongue.
I would say tablesaw, unless its on the end of long and heavy boards
__________________
Earl
"If you want to learn how to build a house, build a house.
Don't ask anybody, just build a house."
"Oland tool, better than a bowl gouge, a lot cheaper to make." Darrell Feltmate around the woods
Show Printable Version Email this Page   Quote this post in a PM to erasmussen
Old 03-28-2006, 09:26 PM   #5
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 692
Avg Visit Freq/Week
Randy, I will have to experiment with your suggestion, that is the way I'd like to do it but I think that the bearing on my chamfer bit will get in the way by hitting the tongue.
The tablesaw method has a lot of potential.
Earl,I want to put the chamfer on the face of the boards so when the tongue is inserted in the groove and both pieces are brought together a small "V" is formed at the joint line. That really helps to hide any imperfections in the joint and draws your eye away from any expansion and contraction issues.
Dave
__________________
--Dr. Seuss
Old 03-28-2006, 09:31 PM   #6
D L Ames's Avatar
Name: D L Ames
City: Fayetteville
State: NC
County: Cumberland
Threads: 66
Avg Visit Freq/Week
Dave, not sure what the length of your stock is, or how wide of a chamfer you are wanting to create but how about this. Cut your T & G then assemble the boards and clamp them together, attach a straight edge then use a 90° V groove bit to cut both chamfers at the same time by running the router straight down the joint where the boards come together.
BTW.....the 90° V groove bit on the left is one of the bits WC has listed under their $5 bit sale.
I hope this helps.
D L
__________________
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. George Orwell (1903 - 1950)
Show Printable Version Email this Page   Quote this post in a PM to D L Ames
Old 03-28-2006, 09:50 PM   #7
erasmussen's Avatar
City: Pikeville
State: NC
County: Wayne
Threads: 164
Avg Visit Freq/Week
Dave
Of course
__________________
Earl
Old 03-29-2006, 06:27 AM   #8
Phillip's Avatar
City: Greensboro
State: NC
County: Guilford
Threads: 9
Avg Visit Freq/Week
= 0.12 over 180 days
daveo, how about grooves on both edges of the boards? then you could insert splines, either loose or glued to into one groove. i'm getting ready to do the same thing on a pair of vertical grain fir entry doors.
phillip
Show Printable Version Email this Page   Quote this post in a PM to Phillip
Old 03-29-2006, 06:35 AM   #9
City:
State:
County:
Threads: 35
Avg Visit Freq/Week
I think Phillip has the most elegant solution and in the end the easiest. If you don't want to do it that way then use a 90 degree V-groove bit on the router table and just expose enough of it to catch the corner on the board with the tongue.
As far as cutting the grooves, I would use the table saw with a 1/4" dado and set it as close to center as possible and then run the boards on edge with featherboards through it. I would first run it with one face through the blade, then I would flip it so the other face was against the fence and run it again guaranteeing that the groove is centered. Then it is just a matter of cutting some splines out of the same stock.
Show Printable Version Email this Page   Quote this post in a PM to Big Mike
Old 03-29-2006, 12:59 PM   #10
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
= 6.53 over 180 days
I agree with the "enhancements" Mike suggests with the exception it might be easier with a chamfer bit if you have one than a v groove.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 03-29-2006, 01:10 PM   #11
Member
Steve D's Avatar
City: Horse Shoe
State: NC
County: Henderson
Threads: 69
Avg Visit Freq/Week
Dave,
I just did this on the Shaker style cabinets I built and I did the chamfering on the tablesaw. It was quick and easy.
__________________
Home of the USS Crescent battle group.
Show Printable Version Email this Page   Quote this post in a PM to Steve D
Old 03-29-2006, 03:12 PM   #12
Charles M's Avatar
City: High Point
State: NC
County: Guilford
Threads: 3
Avg Visit Freq/Week
= 3.31 over 180 days
Sounds like the perfect excuse for a new tool purchase
Otherwise I vote for the V-groove bit on the router table or the table saw blade set to bevel.
__________________
Charles M
Freud America, Inc.
Show Printable Version Email this Page   Quote this post in a PM to Charles M
Old 03-29-2006, 04:17 PM   #13
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 188
Avg Visit Freq/Week
= 3.50 over 180 days
Don't use a bearing guided bit. Use an unguided bit, with the tongue riding on the fence, move the fence back a little until the edge to be machined is appproximately over the bit; it isn't that important because the bit height can be adjusted to get the correct ampunt to take off.
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF
Old 03-29-2006, 06:22 PM   #14
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 692
Avg Visit Freq/Week
[quote=DavidF]Don't use a bearing guided bit. Use an unguided bit, quote]
David, do you think I could remove the bearing from my guided chamfer bit and use it?
Dave
__________________
--Dr. Seuss
Old 03-29-2006, 08:37 PM   #15
erasmussen's Avatar
City: Pikeville
State: NC
County: Wayne
Threads: 164
Avg Visit Freq/Week
The bearing should be held on with a small allen headed screw.
I have removed the bearings from some other bits.
Had to change one ona flush cutter that was gummed up with glue
__________________
Earl
Closed Thread
boards , chamfers , cutting
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cutting Sheet goods procraft General Woodworking 22 03-31-2006 04:56 PM
Jointing Boards kota62 "How To" Forum 18 03-26-2006 07:04 PM
Buying Lumber walnutjerry Where Can I Find, Buy or Sell 12 03-10-2006 06:32 PM
Cove cutting with TS D L Ames Power Tools and Their Use 16 11-27-2005 11:30 PM
TS Jig for cutting spline slots. D L Ames General Woodworking 1 11-05-2005 11:02 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,666
Threads: 25,110
Top Poster: DaveO (14,702)
Welcome to our newest member, dirty b
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
