» Announcements |
The Woodworking Source Grand Opening
Saturday November 22
» Online Users: 57 |
| 26 members and 31 guests |
bluthart
bwat
Charles M
DIYGUY
DRBrifle
dtomasch
flatheadfisher
gsdoby
JJD
Joe Scharle
joneill
jtodd71
Matt Schnurbusch
NC Scroller
newtonc
NZAPP1
pcooper
ptt49er
RayH
Tarhead
TopKnot
Trent Mason
woodworker2000
WoodWrangler
woodylarry
yellofins
| Most users ever online was 180, 04-22-2008 at 12:18 AM. |
08-15-2008, 01:57 PM
#1
This Space for rent
City: New Bern
State: NC
County: Craven
Avg Visit Freq/Week = 0.72 over 87 days
Cryogenic treating
I stumbled across this along time ago. http://www.300below.com/site/cuttingtool.html. Has any one ever tried this process. This has the potential to save tons of money on tools, from hand planes, chisels, to power tool blades. Any thoughts?
08-15-2008, 03:13 PM
#2
DQ
City: Charlotte
State: NC
County: Mecklenburg
Avg Visit Freq/Week = 5.94 over 125 days
Re: Cryogenic treating
it works for industrial applications, if you decide to freeze your chisel, you better be sure you can shave w/it first.
08-15-2008, 03:15 PM
#3
This Space for rent
City: Burnsville
State: NC
County: Yancey
Avg Visit Freq/Week = 6.29 over 99 days
Hock and Lie-Nielsen have been using "Cryo" treated A2 tool steel in their plane blades for years and IMHO it is the only way to go. It should be noted however that cryogenic tempering only works on high-speed tool steel and not on regular high-carbon steel. Also because of the extreme temperatures involved highly specialized equipment is required so it isn't a DIY project.
__________________
"We has seen the enemy and they is us" Pogo
08-15-2008, 10:31 PM
#4
This Space for rent
City: Apex
State: NC
County: Wake
Avg Visit Freq/Week = 5.82 over 125 days
[quote=Mike Callihan; Also because of the extreme temperatures involved highly specialized equipment is required so it isn't a DIY project.
Mike[/quote]Does that mean I can't just leave my cutting edges out in a snow storm and expect the same results?
08-15-2008, 10:48 PM
#5
This Space for rent
City: Goldsboro
State: NC
County: Wayne
As I understand it, the cryo A2 blades will last longer, but the average woodworker will not be able to get as keen an edge on it as HT carbon tool steel. The A2 steel is harder than most of the commonly available honing media. Not having used the A2 blades, tho, I am cannot give an objective comparison.
__________________
My only regret in life is that I did not listen more and talk less
08-16-2008, 09:53 AM
#6
This Space for rent
City: Burnsville
State: NC
County: Yancey
I don't believe that is true. I think you would find that most any of the commonly used sharpening medias are significantly harder than the tempered A2 tool steel. The problem has to do with the steel's increased resistance to wear and the patience of the average woodworker when it comes to sharpening.
By definition the sharpening process is one where you wear the steel away by abrading it on the sharpening media. The Cryo tempered steel's improved wear characteristics resist this abrasion process. While there is no question that conventional carbon steel cutting edges are quicker an easier to bring to a truly sharp cutting edge the same can be done to A2 with enough patience.
I do however recommend starting on diamond and then finishing on water-stones. On the other hand I never touch my Japanese bench chisels or any other high-carbon steel cutting edges with diamond. IMHO the diamond has a tendency to fracture the relatively fragile cutting edge resulting in a quick break down of the cutting edge in use.For high-carbon steel I use water-stones all the way.
My $.02
__________________
08-16-2008, 01:59 PM
#7
This Space for rent
City: Goldsboro
State: NC
County: Wayne
Thanks for the clarification and info, Mike. I rarely use the diamond on the cutting edge, but I do use it when I need to significantly change the primary bevel angle, or to get back past major nicks in the edge. I am still experimenting with different bevels on some of my chisels and irons, and occasionally find I haven't enough beef to the edge, ergo the nicks and chips. All an on-going process of learning for me.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
» Stats |
Members: 2,068
Threads: 16,095
2nd Top Poster: jeff... (6,247)
| Welcome to our newest member, dsimpson |
» Today's Birthdays |
None
