» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  |
02-15-2008, 11:38 PM
#1 | | Clamping box joints Name: Bas City: Raleigh State: NC County: Wake Join Date: Aug 2007 Age: 36  02-15-2008, 11:38 PM
Senior Administrator I'm making some drawers, using box joints. I'm trying to figure out how to clamp this during glue-up. I made the fingers slightly proud, so that I can plane/ scrape/ sand them flush afterwards. That's easier than sanding down the sides.
Those proud fingers do pose a problem with clamping. The only solution I can think of right now is to make four custom cauls that fit over each corner, by making recesses that match the finger pattern. Is there an easier solution?
Does it require a new tool?
__________________
Bas.
I don't need it. I just want it.
| | Views: 288 |
02-16-2008, 12:09 AM
#2 | | Moderator
Name: Tom City: Raleigh State: NC County: Wake Join Date: Jul 2005 Age: 47 Avg Visit Freq/Week = 1.87 over 180 days | Re: Clamping box joints When I did some small boxes with box joint, I just clamped right behind the corners and it worked fine for me. A whole lot easier the custom finger cauls. |
02-16-2008, 12:11 AM
#3 | | Moderator
Name: Glenn City: Baskerville State: VA County: Mecklenburg Join Date: Jan 2008 Age: 60 Avg Visit Freq/Week = 6.30 over 180 days | Re: Clamping box joints Maybe I am missing something here but I see no reason why your clamping force has to be directly over the joint, a caul directly alongside your proud mortises should suffice. On that short a span I do not see where deflection would be a problem  |
#4 | | Guest
Name: City: State: County: | Re: Clamping box joints Could you use some thin peice of wood to even out your clamps? |
02-16-2008, 12:13 AM
#5 | | Moderator
Name: Glenn City: Baskerville State: VA County: Mecklenburg Join Date: Jan 2008 Age: 60 Avg Visit Freq/Week = 6.30 over 180 days | Re: Clamping box joints I would have posted sooner but I was watching the squirrel video link Bas posted  |
02-16-2008, 12:18 AM
#6 |
Name: Mark City: Goldsboro State: NC County: Wayne Join Date: Mar 2006 Avg Visit Freq/Week = 4.59 over 180 days | Re: Clamping box joints What Tom and Jeff said. No new tools for this one. (unless you don't have a band clamp, recessed corner clamp, chain saw, felder planer/jointer/belt sander combo machine, etc)
__________________ "The three hardest things to make in your shop are time, space, and money" - Buz Buskirk (quoted in Woodworking Magazine, Spring 2009) |
02-16-2008, 08:59 AM
#7 |
Name: Steve City: Raleigh State: NC County: Wake Join Date: May 2007 Avg Visit Freq/Week = 3.93 over 180 days | Re: Clamping box joints As long as your joints are only proud by 1/32-1/16, I think a flat cork-lined caul should compress enough to give you good pressure where you need it
- Steve |
02-16-2008, 09:20 AM
#8 |
Name: Joe City: Holly Springs State: NC County: Wake Join Date: Sep 2005 Age: 66 Avg Visit Freq/Week = 7.00 over 180 days | Re: Clamping box joints Like Tom said; I've never had any problems with Bessys just behind the fingers. But I can imagine a lot of problems taking too much time getting the 'box' square with all that glue surface setting up! Most glue has a +/- 10 min open time, so I apply glue to one end then draw the sides in with clamps, then do the same for the other end. Finally clamp for square. BTW, I've tried a pair of Merles and they don't have enough umph to draw a drawer size box together.
Joe |
02-16-2008, 10:34 AM
#9 | | Senior Administrator
Name: Bas City: Raleigh State: NC County: Wake Join Date: Aug 2007 Age: 36 Avg Visit Freq/Week = 6.96 over 180 days | Re: Clamping box joints I was definitely over thinking this one.  I did a dry fit with the clamp behind the fingers, and it looks nice and tight. Best of all, I can see the joint clearly. I like the cork-lined caul idea too, except that it covers things up. As Joe said, gluing up box joints can be a stressful, being able to see what's going on helps a lot.  On more than one occasion, I've glued myself to the project or at least needed a haircut afterwards.
BTW, not sure where I read this, but I picked up a four Stanley corner braces at the local BORG. Although it looks like clamp city when it's all together, those braces really help getting the drawer square.
Thanks for the suggestions everyone.
__________________
Bas.
02-16-2008, 01:01 PM
#10 |
Name: Joe City: Holly Springs State: NC County: Wake Join Date: Sep 2005 Age: 66 Avg Visit Freq/Week = 7.00 over 180 days | Re: Clamping box joints Bas, make some of these. Clamped, they will square up your work.  |
02-16-2008, 02:37 PM
#11 |
Name: Stephen City: Wilmington State: NC County: New Hanover Join Date: Jul 2006 Avg Visit Freq/Week = 4.01 over 180 days | Re: Clamping box joints I use soft pine for cauls. Start the joints together as little as possible then reach in with a glue brush and dab a little bit of glue ( slow set) on every cheek of the joint. clamp together and don't spare the clamps. The pine will crush before damaging anything and still get the pressure where want it. Oh, when I remember, I put clear tape on the caul to prevent everything from getting glued up.
More than one way to skin a rat - this is just what I do. Good Luck
Stephen
__________________ STRIKER |
Posting Rules
Members: 3,663
Threads: 25,103
Top Poster: DaveO (14,701) | | Welcome to our newest member, Keith Senderak | |
