» Announcements | Everyone Log on at 9:00PM Thursday December 4th to set a members online record.  |  |
08-14-2008, 01:08 PM
#1 |
Name: Charles City: Wilmington State: NC County: New Hanover Join Date: Nov 2005 Age: 61 Avg Visit Freq/Week = 7.00 over 30 days | I am just before starting my first cabriole legs. They will go on a small display table, approx. 26"x14". Everything is cut out except for the legs. I have made, cut out, and sanded the pattern to the shape I like. Everything I've read about cabriole legs says to start with square stock and to cut out two sides then shape it using the cutout sides as guides. The pattern will need 3" stock to work.
I have just enough 2" Walnut to cut out four legs with minimal left over stock. If I just cut the shape on one side and round out the legs, it will be a little oblong instead of rounded, but I think it may work because of the small size of the table. Please tell me your opinions before I start cutting.
Thanks! |
08-14-2008, 01:16 PM
#2 |
Name: Mark Gordon City: Huntersville State: NC County: Mecklenburg Join Date: Dec 2007 Age: 43 Avg Visit Freq/Week = 4.90 over 30 days | Charles,
I have only cut Cabriole legs one time and I followed the instructions in woodsmith to the letter. I have no idea how modifiying from that procedure will affect your outcome.
In the woodsmith process, you make your square blanks and draw your cuts on two sides of the blank to the shape of the leg. You then bandsaw one side off. You then reattache the cut off peice with double sided tape, rotate your blank 90 degrees, and then cut off the other side. You then take off the cut peices and you have the general shape of the cabriole leg that still requires sanding and shaping.
Hope that helps. |
08-14-2008, 01:40 PM
#3 |
Name: Joe City: Holly Springs State: NC County: Wake Join Date: Sep 2005 Age: 65 Avg Visit Freq/Week = 7.00 over 30 days | Originally Posted by gordonmt Charles,
Hope that helps. Believe the above. I've made 16 (16 good ones, that is!).
Practice on a squared off 4X4.
Spoke shave is a must. |
08-14-2008, 04:19 PM
#4 |
Name: Willie City: Southern Pines State: NC County: Moore Join Date: Mar 2006 Avg Visit Freq/Week = 0.00 over 30 days | I agree with Joe and Mark. Additionally, I never like to do legs unless I have enough stock to make at least one extra  . |
08-14-2008, 04:33 PM
#5 |
Name: Charles City: Wilmington State: NC County: New Hanover Join Date: Nov 2005 Age: 61 Avg Visit Freq/Week = 7.00 over 30 days | My problem is that I don't have enough stock to laminate together to make the 3" square stock I actually need. My wood supplier won't have any more Walnut of any thickness for a couple more weeks. I'm thinking about a Cabriole "look alike" shaped from 2" x 3" stock, complete with tapered, rounded legs. I'm sure it would be more of an oblong look. Just wondering if anyone has used this modified shape and how it looked!! |
08-14-2008, 04:42 PM
#6 |
Name: Mark Gordon City: Huntersville State: NC County: Mecklenburg Join Date: Dec 2007 Age: 43 Avg Visit Freq/Week = 4.90 over 30 days | I would also add, that I started the project using laminated pine 2 x 4 (you know, from Home DeePot.) I made three mistakes on two of those before I made my first one from Oak. |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Cabriole legs anyone? | junquecol | General Woodworking | 0 | 05-03-2007 11:19 PM | | » Stats |
Members: 2,138
Threads: 16,404
2nd Top Poster: jeff... (6,359) | | Welcome to our newest member, gachua | » Today's Birthdays | |
None
