North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Reply
Old 09-30-2009, 01:20 PM   #1
Cabinet Lighting question
Larry Rose's Avatar
City: Ahoskie
State: NC
County: Hertford
Threads: 138
Show Printable Version Email this Page   Quote this post in a PM to Larry Rose
Larry Rose Larry Rose is offline 09-30-2009, 01:20 PM
I am in the process of building a bookcase/display cabinet from one of Norms measured drawerererings (sorry about that you guys from up north). We plan to use it as a display case for LOMLs pottery colection and it will need some kind of interior lighting. Anyone got any ideas and suppliers?
Old 09-30-2009, 01:23 PM   #2
timf67's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 55
Avg Visit Freq/Week
= 5.76 over 180 days
Re: Cabinet Lighting question
I know that rockler carries a bunch of options, and the BORG has a small selection too.
__________________
_________________________________________________
- Tim
A busy man is a happy man.
- Herb Tuttle
Show Printable Version Email this Page   Quote this post in a PM to timf67     Reply With Quote
Old 09-30-2009, 05:05 PM   #3
Ozzie-x's Avatar
City: Clyde
State: NC
County: Haywood
Threads: 18
Avg Visit Freq/Week
= 6.65 over 180 days
Of course the first consideration is electrical safety. Make sure you use appropriate wiring means and methods, and ground everything really well. The next main design consideration is heat, heat, heat. Stay away from high wattage line voltage incandescent or quartz. Some of the display lighting I've seen really scares me, cheap made, heat bombs, poor designs. A lot of them are cheap made-overseas that have questionable UL listings. Probably the source of some mystery fires. Stick with reputable American manufacturers where possible and install per manufacturers recommendations and instructions. I would recommend LED, T5 (NOT T5HO high output) fluorescent or low voltage (12 volt) lighting because of lowered heat considerations, plus the ability to remote mount the drivers, ballasts or transformers on top of the display case. On T5 and LED, most of the heat is released through the ballast and driver. Particularly the T5 fluorescent lamps themselves are not big heat producers. I'm currently building a lighted display case that I've been designing and thinking about for a couple of years. I have (2) low profile showcase T5 fluorescent fixtures with remote ballasts made by Legion Lighting Co. Inc, I will mount the two fixtures in the top of the cabinet behind a decorative wooden valance and drill a few vent holes in the top for heat venting, this will be the primary general lighting in the case. The remote ballasts will be located in the open on top for efficient heat dissipation. This project also has a top "pediment" or enclosure that will have the main display signage that will also need illumination front and back for visibility. The sign will be lit with low voltage lowered candela LED specialty strip fixtures located concealed in front of the sign with remote drivers located on top of the case. The backlighting will be done with 2 low voltage 12 volt track heads with 15 watt MR11 lamps, again with the remote low voltage transformer located on top of the case. I will drill some vent holes at the top back of the pediment for heat convection.
I you want more concentrated "cones of light" inside the case, there are some good quality small low voltage downlights available that will be safe and do a good job. You can "piggy-back" all of the low voltage downlight fixtures off one larger remote transformer located on top of the cabinet. Sorry for the windiness of this post, just try to share some the thought and work I've put into this.
__________________
Rust Never Sleeps
Show Printable Version Email this Page   Quote this post in a PM to Ozzie-x     Reply With Quote
Old 09-30-2009, 11:31 PM   #4
City: Raleigh
State: NC
County: Wake
Threads: 4
Avg Visit Freq/Week
= 5.05 over 97 days
The best source of cabinet hardware, fixtures, lighting and such is Woodworker's Hardware in Minnesota. They have a good line of lighting and wiring, transformers as well as surge protection. The catalog has very good installation information and the staff is very helpful when you call to order or have questions, I've used them for two complete kitchen cabinets' fabrications and a number of office cabinets' hardware items over the past 6-7 years.
Be sure to follow Ozzie-x excellent suggestions above with respect to installation.
Warren
Show Printable Version Email this Page   Quote this post in a PM to Warren     Reply With Quote
Old 10-01-2009, 08:43 AM   #5
Larry Rose's Avatar
City: Ahoskie
State: NC
County: Hertford
Threads: 138
Avg Visit Freq/Week
= 4.32 over 180 days
Thanks guys, a lot of good info.
Show Printable Version Email this Page   Quote this post in a PM to Larry Rose     Reply With Quote
Old 10-01-2009, 10:34 AM   #6
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
= 6.53 over 180 days
Way back when, I bought low voltage puck lights from Lowes. They could be surface mounted or recessed. Cheap and worked well.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter     Reply With Quote
Old 10-01-2009, 10:59 AM   #7
gritz's Avatar
City: Holly Springs
State: GA
County: Cherokee
Threads: 4
Avg Visit Freq/Week
= 3.62 over 180 days
The new LEDs are quickly moving to the front of the pack. The pucks were good for their time, but have been surpassed by the LEDs.
Just be sure to include a surge protector if you use any electronic transformers. It can be a real pain to exchange these items in an assembled and loaded cabinet.
Show Printable Version Email this Page   Quote this post in a PM to gritz     Reply With Quote
Old 10-02-2009, 11:37 AM   #8
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 188
Avg Visit Freq/Week
= 3.46 over 180 days
I have used recessed, low voltage puck lighting from Rockler with good results. They do get hot so read the installation guide lines. Some can be mounted in to a hole others need the back exposed - don't use the wrong one! I would probably look at LEDs these days, but depends how much light you need. most of the LEDs are about half the halogen.
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF     Reply With Quote
Old 10-02-2009, 02:54 PM   #9
Executive Vice-President
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 155
Avg Visit Freq/Week
= 6.88 over 180 days
Custom Service Hardware has a good new selection of LED lights for reasonable prices. I have used their Low-Voltage Xenon lights in the past for commissions -- they are dimmable but do run hot if left on. Looks like they are similar in price to Xenon's.
__________________
Rob Payne
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet     Reply With Quote
Old 10-23-2009, 09:04 PM   #10
City: Cary
State: NC
County: Wake
Threads: 3
Avg Visit Freq/Week
= 5.55 over 29 days
LED tapes are great for this type of thing. I order rolls of 12 volt LED tape from Hong Kong through the web site http://ledlightsworld.com/.
The LED tape is available in 8mm and 12mm widths and can be trimmed in three inch increments. You need to solder leads to the tape or purchase slide on connectors from the web site. You need to supply your own 120v to 12v transformer. These can be purchased at most big box stores.
For inside cabinet lighting, I recommend using the 8mm wide LED strips. I used the 12mm wide strips to make under counter lighting for my kitchen. They were a little too bright and had to be dimmed.
Show Printable Version Email this Page   Quote this post in a PM to hholgate     Reply With Quote
Reply
cabinet , lighting , question
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cabinet Question Mike Davis General Woodworking 22 07-19-2009 03:33 PM
cabinet drawer question lwhughes149 General Woodworking 3 01-18-2007 04:40 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
