North Carolina Woodworker
Changes to DQ as of 12/1/2008 Very important that you read
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
Notices
» Announcements
Everyone Log on at 9:00PM Thursday December 4th to set a members online record.
Featured Photos
by TopKnot
24868 photos
9957 comments
by skysharks
24868 photos
9957 comments
by sawduster
24868 photos
9957 comments
by Dick
24868 photos
9957 comments
» Online Users: 18
1 members and 17 guests
AndyBarnhart
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 05-01-2008, 11:38 PM   #1
Bas is offline Bas
Asst. Webmaster
Bas's Avatar
City: Cary
State: NC
County: Wake
Threads: 121
Avg Visit Freq/Week
= 7.00 over 30 days
I started a new project, this will be a cabinet to put my bird cage on (one of the legs broke off, and it's been resting on a piece of PT 2x4 for 6 months now....). The cabinet will have a big shelf for the kitty litterbox.
I liked the episode on the Woodsmith Shop on making frames and panels, so I decided to give that a try. Plus, I had to do something with that great plywood I got from Robert. Since I'm going to paint it, I decided to use poplar for the frames.
Dryfitting a panel:
One thing I learned is that it is OK for the plywood to be somewhat loose. The stub tenons need to be tight, but not the plywood. Once you add glue, it swells a little, and won't budge even if you whack it with the Big Orange Deadblow.
Here is the rear panel:
All the panels done:
This is what it is supposed to look like in the end (it will have a top of course):
I plan to join the sides with biscuits, no brads in this one:
The picture is a little fuzzy, but the joint is perfect. I found a video on the Youtubes (on the Internets) on cutting biscuit joints, the woodworker used a piece of sandpaper underneath the biscuit joiner when making the surface slots, to raise it slightly. That ensures the edge of the mating piece will stand just a hair proud, which can be easily sanded flush:
I tried to use biscuits to attach a piece of poplar trim to the plywood top. That didn't work out so well. Turns out there is a slight bow in the plywood (shocking!), so the biscuit slots don't line up. Arg! I think I'll just glue some biscuits in to fill most of the holes, cut them flush, and just use glue and clamps. One case where biscuits actually make alignment harder....
Anyway, I discovered I really like frame and panels, even if they're plain and flat. The biscuit jointer works like a champ, I think I'll also use it to attach the bottom. Attaching the top with biscuits might be too difficult, since it will have an overhang (alignment has to be spot on). I may just use screws instead.
__________________
Bas.
I don't need it. I just want it.
Show Printable Version Email this Page   Quote this post in a PM to Bas
Old 05-02-2008, 12:11 AM   #2
Canuck's Avatar
City: Cary
State: NC
County: Wake
Threads: 134
Avg Visit Freq/Week
= 7.00 over 30 days
Great progress there, Bas!!!!!
One thing I've seen Nahm do was use a slot cutter in the router and cut a continuous slot in the edge of carcase, then cut biscuit slots in the faceframe. That way you can use the biscuits in the faceframe and fit it to the continuous slot in carcase. (I hope I explained this right!)
That stand is going to make the cage look real good!!!!
__________________
..............found out many years ago that Elbow Grease doesn't come in a bottle!!!!
Show Printable Version Email this Page   Quote this post in a PM to Canuck
Old 05-02-2008, 08:44 AM   #3
NC Scroller's Avatar
City: Cary
State: NC
County: Wake
Threads: 108
Avg Visit Freq/Week
= 6.77 over 30 days
Bas, looks great. You have been busy. Now I know where that noise came from at 2:00 AM the other night.
__________________
Making Saw Dust With a Scroll Saw
Show Printable Version Email this Page   Quote this post in a PM to NC Scroller
Old 05-02-2008, 09:51 AM   #4
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 157
Avg Visit Freq/Week
= 3.73 over 30 days
Did you cut the tenons on the tablesaw? Did you use a tablesaw tenoning jig?
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF
Old 05-02-2008, 09:52 AM   #5
City: Chapel Hill
State: NC
County: Orange
Threads: 19
Avg Visit Freq/Week
= 6.07 over 30 days
Looks great! If you're like me you start to feel back about making all those cool joints and then cover them with paint .
I really like the panel construction as well. Make a nice strong but very lightweight piece. What I have done just to help lining up the sides was to do a rabbet on the front and back panels so the sides fit in easily.
On the right side you can see the rabbet on the front of the stand.
Here I dry fit it. Makes it really easy to get the joints correct since I sometimes screw up the biscuits...
Also another little trick I did was to make the rabbet 1/4" deep so it matched the depth of my slot cutter for making the panels. That way all the grooves, dados, rabbets and the panels are at the same depth and match up very nicely and it made the measurements easy.
Wes
Show Printable Version Email this Page   Quote this post in a PM to Kicbak
Old 05-02-2008, 10:47 AM   #6
City: Wake Forest
State: NC
County: Wake
Threads: 130
Avg Visit Freq/Week
= 6.53 over 30 days
How big of a bird do you have? That is a BIG cabinet!!!
__________________
Wife changed my perspective. I need want some additional tools. I need want a
multi-spindle line borer - Found one!!!! Could I? Should I? Do I????
pocket hole machine - unlikely in 2008
Festool sander and vacuum -told I don't need 2 not going to happen
Edge bander - unlikely this decade
oscillating edge sander - unlikely in 2008
floor model chisel or slot mortiser - unlikely in 2008
and a bigger shop - maybe in 2009
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 05-02-2008, 11:24 AM   #7
City: Clayton
State: NC
County: Johnston
Threads: 142
Avg Visit Freq/Week
= 4.90 over 30 days
That cabinet's not big for the bird , it's big for a cat box. I think that the cats name is Sir Poopalot.
Jimmy.
ps. nice job so far Bas.
__________________
Jimmy
"There are no strangers here, only friends that haven't met"
I only buy what I need now, not what I want..... except for lumber !
Remember: Support your local Sawyers and Kiln Operators.
Show Printable Version Email this Page   Quote this post in a PM to JimmyC
Old 05-02-2008, 11:49 AM   #8
FredP's Avatar
City: franklinton
State: nc
County: franklin
Threads: 75
Avg Visit Freq/Week
= 7.00 over 30 days
if the bird broke a leg off you should be building a splint not a box!
Show Printable Version Email this Page   Quote this post in a PM to FredP
Old 05-02-2008, 12:47 PM   #9
Bas is offline Bas
Asst. Webmaster
Bas's Avatar
City: Cary
State: NC
County: Wake
Threads: 121
Avg Visit Freq/Week
= 7.00 over 30 days
Yes, I cut the tenons on the table saw. It's a very simple method, used the miter gauge with a backing board for stability, then just nibbled the material away (using the fence to control the size of the tenon). No fancy tenoning jig, although I've been eyeing the Grizzly one for a while...
__________________
Bas.
Old 05-02-2008, 12:50 PM   #10
Bas is offline Bas
Asst. Webmaster
Bas's Avatar
City: Cary
State: NC
County: Wake
Threads: 121
Avg Visit Freq/Week
= 7.00 over 30 days
It's a pretty big cage, it's sized for a parrot but it just houses two cockatiels. I wanted to make sure it had enough mass so it wouldn't wobble when sliding out the shelf w/ the litterbox, so bigger is better!
__________________
Bas.
Old 05-02-2008, 01:12 PM   #11
Bas is offline Bas
Asst. Webmaster
Bas's Avatar
City: Cary
State: NC
County: Wake
Threads: 121
Avg Visit Freq/Week
= 7.00 over 30 days
Looks good! Yes, a rabbet would work just as well, so many techniques to learn... I don't feel bad about covering things up with paint, I'm very pragmatic in that aspect. Plus, paint means you can use a little filler to hide your mistakes
I've been thinking about getting one of those lock miter router bits...that looks really strong, and I think the shape would help with alignment as well. Plus, new tool!
__________________
Bas.
Old 05-02-2008, 01:35 PM   #12
FredP's Avatar
City: franklinton
State: nc
County: franklin
Threads: 75
Avg Visit Freq/Week
= 7.00 over 30 days
you will like the lock miter bit! setup can be tediouse but the results are good with some practice! the wenge boxes in my gallery were done with one and concidering the choise of materials they turned out good. one of them was done useing lock miters on all six sides. that can be tricky!
Old 05-02-2008, 03:48 PM   #13
City: Lancaster
State: SC
County: Lancaster
Threads: 119
Avg Visit Freq/Week
= 4.90 over 30 days
Think I just read somewhere that some lock miter bits come with a jig to make setup easier. Might want to look into it. If I am wrong it is because I am old. That's my excuse and I am sticking with it.
Show Printable Version Email this Page   Quote this post in a PM to Keye
Old 05-02-2008, 03:54 PM   #14
City: Chapel Hill
State: NC
County: Orange
Threads: 19
Avg Visit Freq/Week
= 6.07 over 30 days
I almost bought a lock miter a few weeks ago when infinity was running the 1 item %25 off deal. Ended up getting the kitchen cabinet bit set with the stile, rail, panel, edge glue and drawer lock bit. I really wished it came with the locking miter too but that will have to come later after you tell us how good it works.
Wes
Old 05-02-2008, 04:38 PM   #15
Director
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 199
Avg Visit Freq/Week
= 6.53 over 30 days
Keye,
Hey, I'm old too . . . but the info was recent
MLCS lock mitre bit and set up blocks. Includes how-to video
Roger
__________________
I ain't never had too much fun!
Show Printable Version Email this Page   Quote this post in a PM to sapwood
Closed Thread
biscuits , frames , panels , pictures , progress
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Picture frames lottathought General Woodworking 42 01-05-2008 08:20 PM
Mmm... Biscuits! Monty Old Off Topic Forums 10 11-11-2005 12:11 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,138
Threads: 16,404
2nd Top Poster: jeff... (6,359)
Welcome to our newest member, gachua
» Today's Birthdays
None
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
