North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 01-18-2008, 01:25 AM   #1
Bending Plywood Questions
BillPappas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 24
Show Printable Version Email this Page   Quote this post in a PM to BillPappas
BillPappas BillPappas is offline 01-18-2008, 01:25 AM
I need some help. I am designing my home office furniture (desk) and want it to have some curves. So I am considering laminating together 5 pieces of 3/8 inch bending plywood to serve as the legs. The legs will be about 2 inches thick and almost as wide as the desk top so they will be fairly substantial in size. I have never used bending plywood before so I have a couple of questions I thought someone might be able to help me with. A crude drawing is attached...
1. What kind of a radius might I be able to achieve with 5 pieces of bending plywood.
2. Should I try and laminate them all at once in the vacuum bag or laminate 2 pieces, then the 3 and finally put the 2 lamminated pieces together?
3. How strong or maybe better said how much weight would the laminated leg support when the force is applied from top which is shown in the attached picture as "Force - High". The top of the desk would sit on the laminated legs so it will have some weight to it and then all the stuff that goes on the top of the desk like a monitor, keyboard, etc.
Any thoughts or ideas are appreciated.
Regards,
Old 01-18-2008, 08:08 AM   #2
Tarhead's Avatar
City: Concord
State: NC
County: Cabarrus
Threads: 217
Avg Visit Freq/Week
= 6.96 over 180 days
Re: Bending Plywood Questions
Good info and formula on kerf cutting here:
http://www.tai-workshop.com/english/tech-2(b)-e.html
Show Printable Version Email this Page   Quote this post in a PM to Tarhead
Old 01-18-2008, 09:23 AM   #3
gordonmt's Avatar
City: Huntersville
State: NC
County: Mecklenburg
Threads: 42
Avg Visit Freq/Week
= 3.15 over 180 days
I did some bending wood project in my past but I have never used plywood as the bending medium. I have always used solid wood and without a steamer rack or other more specific equipment, I needed to rip my peices down to about 1/8 inch or maybe a little wider.
I soaked the wood in water for several hours (overnight) then I clamped the wet pieces into the shape I wanted and let them dry. After drying, remove from the shape clamp and then glue together and put them back into the shape clamp.
The end product is extreamely strong and has virtually not spring back tendancy. Once shaped and glued, it's done.
Here is a picture of the result of bending wood.
Show Printable Version Email this Page   Quote this post in a PM to gordonmt
Old 01-18-2008, 10:03 AM   #4
City: Dobson
State: NC
County: Surry
Threads: 51
Avg Visit Freq/Week
= 4.67 over 180 days
Bill,
I haven't much experience bending wood and I haven't tried bending ply but here's my thoughts.
A 10" or 12" radius would be as tight as I would go with 3/8" bending ply. I you want a smaller radius you may have to use thinner bending ply.
I'm guessing that your legs will be about 24" wide. I would do the glue up in stages like you stated. 2, then 1, then 2. Takes longer but uses a lot less force bending 2 sheets of ply than 5.
Seeing that the finished leg will be 2" thick I wouldn't worry too much about the weight of the stuff that you will put on our desk. 250 lbs. at most? Wood will move with changes in humidity but it should be negligible.
Rick Doby
Show Printable Version Email this Page   Quote this post in a PM to rbdoby
Old 01-18-2008, 01:30 PM   #5
Badabing's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 34
Avg Visit Freq/Week
= 0.82 over 180 days
Bill, can't help much with your questions but I thought I'd offer another idea: Why not use some hardwood to create a skeleton in the shape you want and then cover it with bending ply? Then you would get the curves you like without having to laminate anything and the hardwood skeleton would give you the strength needed.
Just a thought.
BTW, Mark your plant stand and coat rack are awesome!
__________________
Ciao,
http://www.joeswoodstuff.com
If you cannot laugh at yourself, you have not earned the right to laugh at others. -- I said that.
Show Printable Version Email this Page   Quote this post in a PM to Badabing
Old 01-18-2008, 05:26 PM   #6
gordonmt's Avatar
City: Huntersville
State: NC
County: Mecklenburg
Threads: 42
Avg Visit Freq/Week
Thanks Joe, It was a fun project to do.
Old 01-19-2008, 01:06 AM   #7
BillPappas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 24
Avg Visit Freq/Week
= 5.48 over 180 days
Great article - Thanks
As always some great advice from many of you for me to think about. Heating is out as the pieces are to big....I need to remember that heating can assist in the bending process. The one idea on building a frame has potential I was just concerned that it may not have the strength needed but I guess that can be resolved with thicker ribs and I could use plywood since it would give multi-directional stability and strength.
Gordon - nice plant stand and coat rack!
Regards,
Old 01-21-2008, 09:51 AM   #8
rhett's Avatar
City: Frankfort
State: KY
County: Franklin
Threads: 47
Avg Visit Freq/Week
= 0.00 over 180 days
A word of caution about 3/8 bending ply. The exterior surface is very rough and if you plan on veneering over it you will need to use a backed veneer or two pieces oriented perpendicular to one another, as the ridges will telegraph through the veneer. I like the interior rib idea, like a bent torsion box. You can then easily skin it with 1/8 MDF stapled to the form. This material is usually free at plywood supply houses as it is used for cover sheets on stacked goods. Bondo the staples and proceed with the veneer.
__________________
www.efcabineture.com
Show Printable Version Email this Page   Quote this post in a PM to rhett
Old 01-21-2008, 11:08 AM   #9
dino drosas's Avatar
City: Myrtle Beach
State: SC
County: Horry
Threads: 94
Avg Visit Freq/Week
= 6.69 over 180 days
First; an answer to Mike's question. Bendable plywood has all of its plys oriented in the same direction so that it bends with very little effort, and has very little strength unless it is attached to a form or is glue laminated together. You should easily be able to achieve a 6" radius and by gluing 5 layers together, strength will be the very least of your worries. I would build a form the shape of the inside of the curve you want and then glue all 5 pieces at one time clamped to the form as in any glued lamination. Use an extra piece on the outside as a cawl to prevent any clamping indentations since the plywood is somewhat soft. Also, place clear wrap between the 5th and 6th piece so there is no chance that they get glued together. I would use plastic resin glue because of the length of its open time, its strength and the fact that it does not creep. Make your laminations oversized and trim to length and width after the come out of the form.
__________________
The lyf so short The craft so long to lerne
Show Printable Version Email this Page   Quote this post in a PM to dino drosas
Old 01-21-2008, 05:11 PM   #10
BillPappas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 24
Avg Visit Freq/Week
Thanks again for all the insight and good advice.
I went out and purchased one piece of the bending ply and it is amazing how flexible it is and how rough. I am at this point planning on building a form and using the vacuum bag to create the laminate leg. I may add a layer of 1/8 inch Luan to the outside to cope with some of the roughness of the plywood. Then do a double veneer for the final exposed layers. I a now attempting to draw the leg and turn it into a template to make the form.
Regards,
Closed Thread
bending , plywood , questions
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Pen turning questions... Badabing Woodturning 15 12-16-2007 12:09 PM
Two questions... pslamp32 General Woodworking 13 05-01-2007 12:01 AM
Two Questions (For Big Mike?) gator Woodturning 1 06-28-2006 08:12 AM
Wood Bending BBF General Woodworking 3 02-17-2006 01:02 PM
A few questions ???? DaveO Power Tools and Their Use 19 01-25-2006 12:20 AM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,106
Top Poster: DaveO (14,702)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
