» Announcements | Everyone Log on at 9:00PM Thursday December 4th to set a members online record.  |  | |
08-05-2008, 11:10 AM
#1 |
Name: Keye City: Lancaster State: SC County: Lancaster Join Date: Mar 2007 Avg Visit Freq/Week = 4.90 over 30 days | Do you release the tension on your bandsaw blade?
If you do, why? If you do not, why? |
08-05-2008, 11:22 AM
#2 |
Name: Peter City: Weddington State: NC County: Union Join Date: Jan 2008 Age: 35 Avg Visit Freq/Week = 4.67 over 30 days | I do, because there is a quick release lever on my bandsaw and it's easy to do. I'm not sure if I would bother if there wasn't. They say it helps the life of the blade and the machine, and also prevents the blade and tire from getting permanently shaped. In theory I understand this, I'm just not positive if it really makes much of a difference in practice.
If it's not too hard, I guess I would do it. |
08-05-2008, 11:50 AM
#3 | | Asst. Webmaster
Name: Bas City: Cary State: NC County: Wake Join Date: Aug 2007 Age: 35 Avg Visit Freq/Week = 7.00 over 30 days | I do it, because it's easy to do on my Grizzly and it's what the manufacturer recommends. Is it necessary? Hard to tell. Manufacturers recommend all sorts of things, not all of them required. Like using two people to lift a band saw onto the stand (should have listened....)
But - Grizzly makes "value" tools. Not the best, not the cheapest, but usually the best value. If they decided a quick release handle was a good thing on a value tool, it is probably important.
__________________
Bas.
I don't need it. I just want it.
08-05-2008, 12:19 PM
#4 |
Name: Mike City: Burnsville State: NC County: Yancey Join Date: Jul 2008 Age: 68 Avg Visit Freq/Week = 0.47 over 30 days | I have 2 band saws, a 20" Northfield and a 14" Powermatic, neither of them have a quick release. If they did I would probably use it but since they don't, I can't be bothered.
Since I don't do it I can't say if it would make a difference. Over the past almost 50 years I have broken a few blades and replaced a couple of tires but I consider that a small price to pay compared to re tensioning my blade every time I wanted to make a quick cut.
__________________
"We has seen the enemy and they is us" Pogo
08-05-2008, 12:20 PM
#5 |
Name: Jeremy City: Charlotte State: NC County: Mecklenburg Join Date: Mar 2006 Age: 30 Avg Visit Freq/Week = 6.77 over 30 days | I would like to, but I don't, on my 14" saw. On the 24" saw, I usually do, but sometimes forget. No quick release on either and just get lazy usually.
It's probably a good idea though ... so do it.  |
08-05-2008, 12:34 PM
#6 |
Name: Charley City: Kannapolis State: NC County: Cabarrus Join Date: May 2008 Age: 66 Avg Visit Freq/Week = 0.47 over 30 days | I have a 16" bandsaw that doesn't have a quick release. When I first got it I tried to remember to back off the tension whenever I was finished using it, but this got me into trouble several times when I forgot to re-tension it before using it. After this happened a few times I decided that I was doing more damage by releasing the tension than I would by leaving the tension set, so I haven't done it since. If I had a quick tension lever and hung a sign on it that hung in front of the cut line I might remember to throw the lever before cutting, but I would likely forget to release the tension and put the sign back when I finished. I've used bandsaws all my life and never got into the habit of doing this, so it's probably too late to re-train myself now. I'll just buy new tires and blades when it becomes necessary.
Charley |
08-05-2008, 12:44 PM
#7 |
Name: Don City: Yakima State: WA County: Yakima Join Date: Feb 2007 Age: 67 Avg Visit Freq/Week = 5.37 over 30 days | Originally Posted by Keye Do you release the tension on your bandsaw blade?
If you do, why? If you do not, why? I have a 16" Jet steel-frame band saw, that does not have a blade tension release. I tried to release the tension all the time when it was new, but it was a nuisance -- especially when you forget to re-tension the blade.
I can see the value of removing the tension when you are not going to be using the saw for a long period of time (between projects) but other that, I don't bother.
-Don |
08-05-2008, 01:31 PM
#8 |
Name: Trent Mason City: Wrightsville Beach State: NC County: New Hanover Join Date: Feb 2008 Age: 28 Avg Visit Freq/Week = 6.77 over 30 days | I've never actually thought about this. Not sure if I'd want to retension it before each use though.
__________________  "flight of the sea birds, scattered like lost words......"
The ability to do woodworking no longer available in Bud Light.
"We should never separate the lives we live
from the words we speak."
— Paul Wellstone
08-05-2008, 06:29 PM
#9 |
Name: Jimmy Coull City: Clayton State: NC County: Johnston Join Date: Sep 2006 Age: 49 Avg Visit Freq/Week = 4.90 over 30 days | I do on my 14" Grizzly, the reason for taking off the tension is to keep rubber tires from developing flat spots and causing problems. If you use your bandsaw once a week or more it probably doesn't matter, but I usually use it less.
Jimmy
__________________
Jimmy "There are no strangers here, only friends that haven't met " I only buy what I need now, not what I want..... except for lumber ! Remember: Support your local Sawyers and Kiln Operators. |
08-05-2008, 07:14 PM
#10 |
Name: dino drosas City: Myrtle Beach State: SC County: Horry Join Date: Jan 2007 Age: 66 Avg Visit Freq/Week = 7.00 over 30 days | I have a 24 and usually have a 1" carbide tipped blade installed. When in use, the blade is tensioned to 30,000psi and this seems to me to be quite a bit of tension to leave on the saw when I am not using it -sometimes for days. I always release the tension at the end of the day after using it. It only takes about three turns of the wheel and even though it is a PITA., I have gotten used to it, and feel better about it.
__________________ The lyf so short The craft so long to lerne |
08-05-2008, 08:48 PM
#11 | | DQ
Name: Lorraine City: Littleton State: NC County: Warren Join Date: Dec 2005 Age: 60 Avg Visit Freq/Week = 3.50 over 30 days | If I had a quick release I probably would but I don't and as a woman, I don't have the strength to deal with the process. I understand that it is important to take the tension off.
Wouldn't it be nice if someone could come up with an attachment that would provide a quick release. |
08-06-2008, 10:32 AM
#12 |
Name: Bob City: Hillsborough State: NC County: Orange Join Date: May 2007 Avg Visit Freq/Week = 7.00 over 30 days | Originally Posted by lwhughes149 ...Wouldn't it be nice if someone could come up with an attachment that would provide a quick release. Your wish has come true... for a mere $160  . http://www.carterproducts.com/produc...d=20&cat_id=16
__________________
Carpe Lignum... Torne Lignum!
08-06-2008, 12:23 PM
#13 | | Moderator
Name: Wayne City: Cary State: NC County: Wake Join Date: Dec 2005 Age: 61 Avg Visit Freq/Week = 7.00 over 30 days | I do take the tension off the blade after each use. (to prevent flat spots?  ) As a reminder to retension, I swiped this idea from another North Carolina Woodworker member. Place a small spring clamp to the blade after releasing the tension. Spring clamp ahhhhhhh - retension the blade.
HTH
__________________ ..............found out many years ago that Elbow Grease doesn't come in a bottle!!!! |
08-06-2008, 12:31 PM
#14 | | Secretary Moderator
Name: Doug Robinson City: Raleigh State: NC County: Wake Join Date: Jul 2006 Age: 47 Avg Visit Freq/Week = 7.00 over 30 days | Releasing the tension does two things. It can prolong the life of your tension spring, and it can prevent flat spots on your wheels. It is a good idea to release the tension every time. In addition to the Carter after-market tension release device, you can make a simple cheap one. There are plans in an issue of Woodsmith. I don't have it in front of me but I will try to post the issue and page numbers tonight.
Doug
__________________
Just because you can, doesn't mean you should. Unless you are Travis and you are considering buying a new tool! |
08-08-2008, 09:28 PM
#15 |
Name: Andrew City: Mills River State: NC County: Henderson Join Date: Feb 2008 Age: 50 Avg Visit Freq/Week = 5.60 over 30 days | yes, and no...
I do when I won't be using the saw for a while - like a few weeks. if I remember.
For all the reasons listed above. They put this tension release on the saw, charged me for it, so the least I could do is use it (when I remember)
I never did it on the old Craftsman. Guess that's one reason I had to replace the tired old thing. |
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 2,138
Threads: 16,404
2nd Top Poster: jeff... (6,359) | | Welcome to our newest member, gachua | » Today's Birthdays | |
None
