» Announcements |
The Woodworking Source Grand Opening
Saturday November 22
» Online Users: 55 |
| 21 members and 34 guests |
bwat
clowman
dtomasch
Eddie Byrd
enm
GeorgeL
JackLeg
jtodd71
MT native
NC Scroller
NZAPP1
pcooper
RandyJ
Scott Kuykendall
scsmith42
sediener
SteveColes
TKKids
Trent Mason
WoodWrangler
woodylarry
| Most users ever online was 180, 04-22-2008 at 12:18 AM. |
07-30-2007, 10:42 PM
#1
This Space for rent
City: Charlotte
State: NC
County: Mecklenburg
Avg Visit Freq/Week = 6.89 over 125 days
Bandsaw Blade Question
Is there a bandsaw blade that works well at cutting veneers at 1/8" and thinner that will work on my HF bandsaw/w riser (105" blade)? I have a 1/2" 3tpi Timberwolf blade, but it seems to leave some pretty deep saw marks. Not sure if this is the blade or the saw! I want to be able to use this for inlays and marquetry.
07-30-2007, 11:00 PM
#2
DQ
City: Charlotte
State: NC
County: Mecklenburg
Avg Visit Freq/Week = 5.94 over 125 days
Re: Bandsaw Blade Question
it quite likely is the saw. but probably if you upgrated to some cool block style guides you'll get a better finish.
07-30-2007, 11:07 PM
#3
Asst. Webmaster Senior Moderator
City: Clayton
State: NC
County: Johnston
Avg Visit Freq/Week = 7.00 over 125 days
You shouldn't have any issues cutting 1/8" veneers with the type of blade. Provided you are tuned and tensioned properly. More than likely you will have to run the slices through a drum sander to clean them up and ensure a smooth surface.
Dave
__________________
  Nothing left to do but smile, smile, smile
--Dr. Seuss
07-30-2007, 11:12 PM
#4
This Space for rent
City: Charlotte
State: NC
County: Mecklenburg
Hey Phil, I already have the cool blocks, but I probably do need to upgrade the spring! I'll have to look into that.
Dave, I wish I had a drum sander, but sadly that's a one-of-these-days item! unless of course you want to pick up that really cool Steel City drum that is in the Charlotte Woodcraft for me! I think I can run 1/8 through my planer.
07-30-2007, 11:23 PM
#5
DQ
City: Charlotte
State: NC
County: Mecklenburg
if you have the blocks it's likely a tension problem. i know timberwolf blades are to be run just shy of wobbling per their sales pitch. i've not done a lot with them to know for sure though.
07-30-2007, 11:30 PM
#6
This Space for rent
City: Wake Forest
State: NC
County: Wake
Avg Visit Freq/Week = 5.26 over 125 days
I agree with Phil. It is most likely tension. Either your spring isn't strong enough (which isn't too much to replace from Woodcraft) or your frame is twisting. I would try replacing the tension spring just to see. Woodcraft should have them in stock and they are less than $20 I believe.
07-31-2007, 08:23 AM
#7
This Space for rent
City: Charlotte
State: NC
County: Mecklenburg
I saw a demo of Timberwolf blades last year. The guy was cutting some cherry and went from a jagged cut to a smooth cut just by varying the speed he fed the wood through. Try slowing down the feed rate and let the blade cut.
Also, the last blade (Timberwolf) I got from Woodcraft was bent a little near the weld. I straightened out the teeth a bit and it fixed it up pretty good.
pete
08-01-2007, 03:51 PM
#8
This Space for rent
Name: Ken Massingale
City: Liberty
State: SC
County: Anderson
Avg Visit Freq/Week = 6.83 over 125 days
I'll probably start a rukus with this but:
I'm a long time Timberwolf user but am not happy with them lately, especially with resaw blades. I bought 2 new ones with the new Rikon bandsaw and had terrible results with both. (I had ordered some Bladerunner, same as Woodslicer, blades from Iturra but they hadn't arrived). The finish on the cuts was terrible and the saw sounded like it was coming apart. After confirming tension was to Suffolk specs and all alignments were correct I gave up and called Rikon. When I explained the issue their first question was if I had a Timberwolf blade on.
I installed the blade that came with the saw and resaws were better, not great but better.
The Bladerunner blades came and the heavens opened up with glorious rewards of smooth cuts and a quiet bandsaw!
I'm not slamming all Timberwolf blades but the Bladerunner or Woodslicer blades shame the TW resaw blades.
__________________
Inside every 'old' man is a young man wondering what the heck happened!
08-01-2007, 11:17 PM
#9
This Space for rent
City: Wake Forest
State: NC
County: Wake
Isn't it spelled ruckus?
08-01-2007, 11:50 PM
#10
DQ
City: Charlotte
State: NC
County: Mecklenburg
didn't expect that to be the point in your post disputed did you!
08-02-2007, 08:01 AM
#11
This Space for rent
City: Jacksonville
State: NC
County: Onslow
Avg Visit Freq/Week = 0.00 over 125 days
I cut a lot of logs 18" -24" in length, using a simple bandsaw sled and bar clamp. Kind of simple set up, but get better results than using the fence.
Use a 3/8" x 3 TPI Lenox blade
08-02-2007, 08:17 AM
#12
This Space for rent
City: Liberty
State: SC
County: Anderson
Wellll, I waz edjucated in S.C., nuff said!
__________________
08-02-2007, 12:39 PM
#13
This Space for rent
City: Wake Forest
State: NC
County: Wake
 We Carolinians allz has to stick together.
Ain't no need to have a dispute about bandsaw blades. The only thing I can say for sure is they get dull quick. I have a carbide tipped one on my Minimax, and I can say it makes a world of difference, but the price is enough to give you sticker shock. I dread the day I have to get it sharpened.
08-02-2007, 01:03 PM
#14
This Space for rent
City: Charlotte
State: NC
County: Mecklenburg
Cool, I finally started a thread with a little controversy! (didn't think it would be fer grammar!)
Thanks for the suggestions guys!
Travis, since those blades cost sooooo much for the MM, I'll be willing to trade saws!  I really would like to upgrade saws. I think I try and put it in next years budget!
08-02-2007, 01:23 PM
#15
City: Indian Trail
State: NC
County: Union
Avg Visit Freq/Week = 6.78 over 125 days
You're a rebel Ed!!!
__________________
__________________________________________
Take the attitude of a student, never be too big to ask questions, never know too much to learn something new. Og Mandino
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
