North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 07-17-2008, 11:05 PM   #1
Adding a support for flip-up shelf
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Show Printable Version Email this Page   Quote this post in a PM to Bas
Bas Bas is online now 07-17-2008, 11:05 PM
Senior Administrator
I built a cabinet (32" high, 22" wide, 18" deep). On either side, it will have a shelf that flips up. Each shelf is attached to the cabinet via a piano hinge, and is 24" long and 10" wide.
Although quite different from what I built, the following picture will give you an idea of the wing:
Obviously, I will need a support for the shelf. I plan to use a simple "arm" of hardwood (3/4" x 3x4") that will attach to the cabinet via a small section of piano hinge. On the shelf, I will put a bracket that the arm will catch on.
Got all that? Good.
I'm trying to work out the optimal length for the arm. See the image below.
Here, ac is the cabinet, ae is the fold-up shelf, and bd is the arm. Normally, the shelf will hang down. I want the arm to be concealed by the shelf in this position.
The pivot point for the arm is located at b. Since the shelf is 24" long, ab + bc is also 24". The longer arm bd is, the stronger the support will be. But, the longer I make bd, the more obtuse the angle abd must be to compensate (as bd increases, ab must decrease to keep the ab + bc = 24). The more obtuse the angle, the weaker the support. There has to be an optimum.
My gut tells me 45 degrees for abd would be best. Applying basic trigonometry functions means arm bd is a little over 14" (14.06 to be exact). That seems reasonable.
For all you structural engineers out there - is 45 degrees the best option? Should I increase the angle to 60 degrees (effectively moving the pivot point up) and increase the arm length to 16". Better, worse?
__________________
Bas.
I don't need it. I just want it.
Old 07-17-2008, 11:50 PM   #2
jeff...
Guest
Name:
City:
State:
County:
Posts: n/a
Re: Adding a support for flip-up shelf
what's the bucket for?
Show Printable Version Email this Page   Quote this post in a PM to jeff...
Old 07-18-2008, 08:44 AM   #3
Outa Square's Avatar
City: Newton
State: NC
County: Catawba
Threads: 15
Avg Visit Freq/Week
= 5.91 over 180 days
If it was me i would focus on the strength of the top and that of the arm, The angle isn't as important. I would just move the connection as close to point e as you are comfortable with.
But if you do want a angle i would use 42
Show Printable Version Email this Page   Quote this post in a PM to Outa Square
Old 07-18-2008, 09:50 AM   #4
skysharks's Avatar
Name: John Macmaster
City: Eastover
State: NC
County: Cumberland
Threads: 83
Avg Visit Freq/Week
= 6.61 over 180 days
You could do exactly like you want to do with the arm.
However you mentioned that you wanted the arm to be hidden when the shelf is at it's downward folded position.
1. You could make the arm removable and stow it away inside the cabinet.
Or hang it on a hook.
2. Or there are locking hinges that you could use, where as the arm is divided into 2 pieces. these parts being connected by this locking hinge when rotated up inot a straight line(shelf up) it locks into place. To lower the shelf you break down the arm at the hinge point and with another small hinge at the attachment point to the cabinet it (the arm) would fold up and under the shelf.
Then with a skirt around the perimeter of the shelf, in the folded down position nothing would be visible.
Hope that you can see what I am talking about.
__________________
Long ago when men cursed and beat the ground with sticks, it was called witchcraft. Today it's called golf.
Show Printable Version Email this Page   Quote this post in a PM to skysharks
Old 07-18-2008, 10:14 AM   #5
Bas is online now Bas
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Avg Visit Freq/Week
= 6.96 over 180 days
Originally Posted by skysharks View Post
2. Or there are locking hinges that you could use, where as the arm is divided into 2 pieces. these parts being connected by this locking hinge when rotated up into a straight line (shelf up) it locks into place. To lower the shelf you break down the arm at the hinge point and with another small hinge at the attachment point to the cabinet it (the arm) would fold up and under the shelf.
Mac, I like it, I think I've seen something like that before. That is a much better solution, since the support can span the full length of the shelf. Also, I can attach both sides of the arm to the shelf with screws, so there is no danger of the arm ever slipping out.
The $64,292.53 question (adjusted for inflation): Where might one acquire such a contraption? I looked at McMcaster-Carr, and they have a very sophisticated locking hinge, at a very sophisticated price. I want something sturdy, but not industrial.
Of course! That's the (ultimate) answer! Knowing my woodworking skills, I'd probably end up at 42 anyway, if I tried to make it 45 degrees
__________________
Bas.
Old 07-18-2008, 10:42 AM   #6
woodArtz's Avatar
City: Hillsborough
State: NC
County: Orange
Threads: 81
Avg Visit Freq/Week
= 7.00 over 180 days
Something like this???
http://woodworker.com/cgi-bin/FULLPR...5&LARGEVIEW=ON
__________________
To everything... turn, turn, turn!
Show Printable Version Email this Page   Quote this post in a PM to woodArtz
Old 07-18-2008, 11:05 AM   #7
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Avg Visit Freq/Week
Bob, that would work, but it's not what I had envisioned. What Mac described is two straight arm pieces that fold up when the shelf is down. As you lift up the shelf, the two arms start to form a triangle, until they are in one line when the shelf is fully raised. The hinge point moves "away" from the cabinet during this operation.
The ratcheting support should be able to do the job, but doesn't offer any advantages over a normal, hinged short arm. Plus, $50 (two shelves) is a bit more than I bargained for. But thanks for the suggestion!
__________________
Bas.
Old 07-18-2008, 11:28 AM   #8
PurpleThumb's Avatar
City: Asheville
State: NC
County: Buncombe
Threads: 8
Avg Visit Freq/Week
= 2.84 over 180 days
Bas, let me throw another possible solution. How about two slide out (pull out) supports that would be behind your rails. If you wanted a shelf on both ends you could offset the supports, similar to a dining table pull out.
Show Printable Version Email this Page   Quote this post in a PM to PurpleThumb
Old 07-18-2008, 01:51 PM   #9
Vanilla Gorilla's Avatar
Name: Marco Principio
City: Durham
State: NC
County: Durham
Threads: 45
Avg Visit Freq/Week
= 0.08 over 180 days
Purplethumb's suggestion is what I immediately envisioned as well. When it comes to hinged supports, I always worry about the screws on the hinge eventually pulling out, or developing enough play that the shelf doesn't sit level anymore. at least with a slide out bar support underneath,. if it ever developed play you could wedge it. Plus, it seems like the hinged support might be over engineering it. the less moving parts, the less that can go wrong!!
__________________
I can't tell my adze from a hoe in the ground
Show Printable Version Email this Page   Quote this post in a PM to Vanilla Gorilla
Closed Thread
adding , flipup , shelf , support
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Flip-Flop Picture Frame jeff... General Woodworking 6 02-14-2008 05:39 AM
Ideas for Shelf and Drawer Support cpowell General Woodworking 12 02-02-2007 10:46 AM
Flip top tool cabinet plans skeeter Where Can I Find, Buy or Sell 6 10-02-2006 09:55 AM
My version of the flip-top cabinet Monty General Woodworking 21 11-09-2005 04:58 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,664
Threads: 25,110
Top Poster: DaveO (14,702)
Welcome to our newest member, Jose San Vicente
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
