Originally Posted by mkepke
I think he means he ran a 240V circuit that also supported 120V circuits (both 240V outlets and 120V outlets are fed by the same run of cable and breaker - called a "multiwire circuit")
-Mark
DISCLAIMER
I'm not an electrician, just an experienced DIYer so the following should not be taken as professional advice. I HIGHLY recommend speaking to a licensed professional before installing a multi wire type circuit as I have no idea how they are regulated by code. Unless there is a very good reason, and you've researched code requirements, I'd suggest separate circuits for 220 and 110 applications.
DISCLAIMER
Yeah, the trick is you need a neutral so you'll need to run 12/3 (for a 20A circuit). A regular 220 circuit has two HOT wires and a ground. With 110 circuit you have a hot wire (with alternating polarity), a neutral which completes the circuit, and a ground. In the 220 circuits the two hot wires (if the breaker is installed correctly, you have to be careful if you're using the slim breakers) are always opposite polarity so there is no need for a neutral.
A regular 220 circuit is usually run with 2 conductor wire. Black is hot for one side of the breaker, White (should be taped black at both ends so anyone looking at it later will know it is HOT) is hot for the other side, and the ground. If you want to run a branch of 110 off your 220 line you'll need a neutral for that section of the circuit. I've heard that some people cheat and use the ground for both neutral and ground but this is a BIG NO NO. Don't do it. The correct way is to run 3 conductor wire from the box: Black = HOT, Red = HOT, White = Neutral, bare = ground. When you get to your first 220 outlet wire the two hot wires to the outlet, along with the ground and just ignore the neutral. Use a wire nut to attach it to your next stretch of wiring and move on. When you're ready to do a branch of 110 then use 2 conductor wire to extend one HOT conductor (may as well use black so that the wiring colors match up), the neutral, and the ground. You're basically extending one half of the circuit along with the neutral wire. It would also be possible to wire the whole circuit using 3 conductor wire and alternate 220 and 110 outlets by bypassing the wire you don't need. For 220v wire both hots and bypass the neutral, for 110 bypass a hot and wire the neutral.
WARNING: There is a lot of potential for danger here. While this is a cool bit of knowledge and I enjoy understanding why/how things work (which is why I'm attempting to explain it), if it's done incorrectly, or even done correctly but not labeled well, it can cause big problems. This is why I'm pretty sure it's not "code."
1) If you mis-wire your 110 branch your 110v outlets could be 220. All kinds of bad things could happen in this circumstance. This is especially possible if you attempt the latter example of alternating voltages using 3 conductor wire. Many chances for mistakes.
2) It's not very intuitive to go looking for a 220 breaker if you're trying to cut power to a 110 circuit. This in itself may be a big reason it's not code.
So, yeah, it's possible, and if done right works just fine but in the end I'd say in most cases you're better off keeping them separate. I'm a strong believer in the KISS principle.
Pop Quiz: Ever wonder why your 220v Stove has a 4 prong connector but your Table Saw only has 3? If so, from the above explanation you should be able to now figure it out. Hint: The stove needs 220 but the oven light and clock only need 110.
