North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > What's Going ON? > Where Can I Find, Buy or Sell
Where Can I Find, Buy or Sell Looking for something? A product, service, organization, etc.?
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 03-20-2008, 06:48 AM   #1
small pieces of thick steel plate
CarvedTones's Avatar
City: Cary
State: NC
County: Wake
Threads: 189
Show Printable Version Email this Page   Quote this post in a PM to CarvedTones
CarvedTones CarvedTones is offline 03-20-2008, 06:48 AM
I need a couple of small pieces of 1.25" or so thick steel plate. By small I mean really smalll - 3" x 2" and 2" x 2". They need dead flat parallel faces.
EDIT - Oh yeah - Cary/Apex/Raleigh area.
Old 03-20-2008, 07:29 AM   #2
Jim Murphy's Avatar
Name: Fern HollowMan
City: Franklinton
State: NC
County: Granville
Threads: 87
Avg Visit Freq/Week
= 3.23 over 180 days
Re: small pieces of thick steel plate
Andy,
There are rules.
You must follow the rules.
I'm sure you know "No pics, didn't happen."
But you forgot that you cannot, you absolutely cannot ask for something obscure and not advise us WHY you want it and WHAT you're going to use it for. Didn't you read WoodWrangler's post, asking for acrylic, and within moments, someone asked, "What'cha gonna do with it?"
So,
Why do you want this and what are you gonna do with it?
BTW, I've no idea where to find this. I'm just up early enforcing the rules.
__________________
...I have finally reached the age where my wants and needs have regressed to my early childhood:
---I want everything and need nothing.
Show Printable Version Email this Page   Quote this post in a PM to Jim Murphy
Old 03-20-2008, 07:44 AM   #3
City: Cary
State: NC
County: Wake
Threads: 189
Avg Visit Freq/Week
= 6.53 over 180 days
I have an oddball 14" band saw that uses the same upper casting as a bunch of others, but a different lower one that results in it being 1.25" shorter. I have a riser kit on the way that will fit it (Grizzly closeout on the G1019 kits; that saw has the same upper casting). I was going to modify the blade guard and get a different blade, but someone pointed out to me that getting spacers (one for each side of the bolt) would be simpler and give me extra cutting height.
-Andy
Old 03-20-2008, 09:14 AM   #4
City: Cary
State: NC
County: Wake
Threads: 189
Avg Visit Freq/Week
I was thinking about this some more on my drive in to work...
I wonder if I could make the spacer out of hardwood ply and then drill holes and glue in steel rod or maybe screw in threaded inserts near the corners so it wouldn't be subject to compression. It needs to be strong because of the weight, tension and leverage, but going all steel maybe over engineering. Besides, I could make an exact fit.
Old 03-20-2008, 09:40 AM   #5
Secretary
scsmith42's Avatar
City: New Hill
State: NC
County: Chatham
Threads: 88
Avg Visit Freq/Week
= 6.49 over 180 days
Andy, I think that I have some 1-1/4 steel; I'll check later today.
From your post, it seems as if you're building spacers for the blade guard with it, or will this steel be used to align the guides?
Other ways that you could build a spacer are to use some all-thread rod with double nuts, or take some solid round steel and drill it for the appropriate sized bolt, and then machine it to the length that you'd need. You could also use pipe.
Show Printable Version Email this Page   Quote this post in a PM to scsmith42
Old 03-20-2008, 09:53 AM   #6
City: Cary
State: NC
County: Wake
Threads: 189
Avg Visit Freq/Week
I am talking about a spacer between the riser block and the bottom half of the saw. Basically making the 6" riser into a 7.25" riser. I was going to shorten the blade guard to fit my saw, but if I make a spacer instead, I don't have to do that. It occurs to that I am jumping the gun a bit. I came up with 1.25 because my saw currently takes a 91" blade as opposed to 93.5", which is what most 14" saws take. But in order to get the blade guard on the riser kit to fit, I need to wait until it gets here (it shipped ground a couple of days ago from WA) and figure it more exactly.
Old 03-20-2008, 09:59 AM   #7
Secretary
scsmith42's Avatar
City: New Hill
State: NC
County: Chatham
Threads: 88
Avg Visit Freq/Week
ok - this makes more sense. When you figure out the dimensions that you need, send me a PM. I'll rough cut it with a plasma cuttter and then set it up the the mill and machine it to spec.
Will a tolerance of .001 be acceptable or will you need it more precise?
Old 03-20-2008, 10:02 AM   #8
LeeNC's Avatar
City: Cornelius
State: NC
County: Mecklenburg
Threads: 14
Avg Visit Freq/Week
= 4.43 over 180 days
I can probably help you out. I have access to some odd scrap metal. The faces will only be as parallel as the plate comes from the manufacturer. They should be close enough that you could shim the difference if necessary. PM me if you still need it. I live in the CLT area, but will be in Greensboro next Sat.
LeeNC
Show Printable Version Email this Page   Quote this post in a PM to LeeNC
Old 03-20-2008, 10:17 AM   #9
City: Cary
State: NC
County: Wake
Threads: 189
Avg Visit Freq/Week
That sounds pretty darn precise to me. So I take it you could just machine the entire spacer out of one piece of metal? The more I think about it, I think I do need all metal. The riser block has a big cavity so the pressure is concentrated around the perimeter:
If you look at the top plate, another one of those is what I am after if I can get it. Thick enough to make up the difference between my saw and a "normal" one.
Old 03-20-2008, 07:44 PM   #10
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 692
Avg Visit Freq/Week
= 7.00 over 180 days
Originally Posted by scsmith42 View Post
ok - this makes more sense. When you figure out the dimensions that you need, send me a PM. I'll rough cut it with a plasma cutter and then set it up the the mill and machine it to spec.
Scott ain't kidding around, he has the capability to make anything you need...I've seen his toys. Not to mention he's a great guy who would help anyone out.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 03-20-2008, 08:49 PM   #11
City: Cary
State: NC
County: Wake
Threads: 189
Avg Visit Freq/Week
Seems like everyone here is friendly and helpful. Are you sure this is the Internet?
-Andy
Old 03-20-2008, 09:13 PM   #12
Secretary
scsmith42's Avatar
City: New Hill
State: NC
County: Chatham
Threads: 88
Avg Visit Freq/Week
Andy, as I'm sure that you've figured out by now, there is a tremendous group of folks here on NCWoodworker.net. I have learned a lot from the folks here - both about woodworking as well as other areas.
Steve and the admins really do a great job, and the members are just plain great!
I look forward to meeting you in a couple of weeks.
Regards,
Old 03-20-2008, 09:14 PM   #13
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 216
Avg Visit Freq/Week
= 6.46 over 180 days
-Andy
Hey, wanna buy some . . .
Roger
__________________
I ain't never had too much fun!
Show Printable Version Email this Page   Quote this post in a PM to sapwood
Old 03-20-2008, 09:56 PM   #14
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 56
Avg Visit Freq/Week
= 4.59 over 180 days
It will need a hole in it to run the attachment bolt through. It will also need to be thin enough that the alignment pins will extend through it, or you will have to also put alignment pins in the additional spacer.You also may want to wait to see if the riser throws the wheels out of coplaner. If so, you can use the spacer to take out any alignment errors to save a lot of wheel shimming.
__________________
"The three hardest things to make in your shop are time, space, and money" - Buz Buskirk (quoted in Woodworking Magazine, Spring 2009)
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Old 03-21-2008, 11:18 PM   #15
City: Apex
State: NC
County: Wake
Threads: 301
Avg Visit Freq/Week
= 6.30 over 180 days
Sorry, the old brain was in neutral when I first read your post. I have a length of 5/8' X 2" flat stock. I could cut you two pieces that are 5/8" X 2" X 3". That would give you 1.25 inches added height. Then Scott could drill the alignment pins and bolts. Check to see exactly what size you need. Bruce
Show Printable Version Email this Page   Quote this post in a PM to junquecol
Closed Thread
pieces , plate , small , steel , thick
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Walnut plate / small bowl owen299 Woodturning 11 03-13-2008 10:58 PM
Looking safe method of cutting 3" thick walnut lwhughes149 General Woodworking 6 08-31-2007 07:21 PM
Router-table sub-plate aids small part shaping johnpipe108 "How To" Forum 2 04-13-2007 12:22 AM
Jointing Small/Thin Pieces hannah01 General Woodworking 8 06-07-2006 11:41 AM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
