| Re: router plate insert leveling screws. I'm fairly certain that you can find set screws in the specialty hardware pullout bins in the Hardware aisle at Lowe's. Just get the correct thread size for the insert you have.
You can also use set screws like these when you make tablesaw zero clearance inserts out of MDF or Baltic Birch, just drill and tap them at the appropriate spots and insert the set screws with an Allen wrench.
__________________
Rob Payne  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
