» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  |
04-21-2008, 03:19 PM
#1 | | Rough Cut lumber for equipment shed needed Name: John City: Efland State: NC County: Orange Join Date: Apr 2008  04-21-2008, 03:19 PM
I need approx. 1000 sq ft of rough cut lumber for equipment shed I'm building in Sea Level, NC (about 25 miles northeast of Beaufort in Carteret Co.). I need 1"x aprox.13' in length, variable widths OK. thanks, John | | Views: 398 |
04-21-2008, 05:18 PM
#2 |
Name: Geoff City: Lillington State: NC County: Harnett Join Date: Jan 2008 Avg Visit Freq/Week = 7.00 over 180 days | Re: Rough Cut lumber for equipment shed needed Home Depot but if you want rough cut stock contact one of the sawyers who frequent this site. They will need more info than you have provided in your post.
__________________ LET'S GO RED SOX!!!!! WORK EVERYDAY LIKE YOU DON'T NEED THE MONEY!! |
04-21-2008, 05:33 PM
#3 | | Moderator
Name: Ray City: Raleigh State: NC County: Wake Join Date: Mar 2006 Avg Visit Freq/Week = 0.04 over 180 days | Re: Rough Cut lumber for equipment shed needed John,
Welcome to the North Carolina Woodworker pile-o-sawdust. Tell us a bit more about what you are building so we know how to answer the question. There are a number of sawyers in this forum and they could supply you with as much lumber as you could use.
You mentioned 1X and that you wanted boards to be 13 feet long. How wide should the boards be? Better yet, what are the dimensions of the shed. How long and how tall are the walls? Do you really want to build with with board walls? Have you considered framing it with 2X4 studs and covering that frame with something like T1-11 sheets? If you can describe the project in a bit more detail, we can offer more with regards to what you might need and where you can get it.
Since this is your first post, I'd like to encourage you to post a note to the "Who We Are" forum and tell us a bit about yourself and the projects you like / need to build.
Ray
__________________
I cut that board twice and it's STILL too short.
04-21-2008, 05:54 PM
#4 |
Name: Jack City: Rolesville State: NC County: Wake Join Date: Apr 2007 Avg Visit Freq/Week = 5.72 over 180 days | Re: Rough Cut lumber for equipment shed needed I will be glad to saw the lumber for you, but I think Ivey is alot closer to you than I am, he is in Burgaw. PM if I can help you
Jack |
04-21-2008, 09:00 PM
#5 |
Name: Reggie City: Albemarle State: NC County: Stanly Join Date: May 2007 Avg Visit Freq/Week = 6.03 over 180 days | Re: Rough Cut lumber for equipment shed needed I was down at Ivey's this past Saturday and he was sawing some nice pine logs. He can definitely help you, and he's an OK guy also. Jack (saw4u) Jeff, and several other guys can ease your pain also, but Ivey is probably nearest to you. We buy cypress from him often and he has good stuff at reasonable prices.
__________________
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. – UNKNOWN!
04-21-2008, 10:16 PM
#6 | | Guest
Name: City: State: County: | Re: Rough Cut lumber for equipment shed needed Board and Batten siding? If so - I've cut a few orders of it...
Most folks look for the widest boards and narrowest battens. I would not go with anything less than 6" boards spaced 1/4 ~ 1/2" apart, battens should overlap by at least 1". If you use wider boards, increase batten size (wider batten) to allow for greater shrinkage. There really is no set widths for board and batten siding but a good combination seems to be 1x3 battens and 1x10 boards, this combination is the most popular with my customers. Siding should be nailed to good 2" thick furring strips. Boards up to 6" wide should be set with one nail in the center of the board. Likewise the batten covering the gap between boards should be set with one nail also in the center of the batten. The shank passing between the edges of the boards (this is important) Use two nails for boards over 8" wide, space the nails approx 2 1/2" to 3" apart. Nailing and spacing this way allowed for shrinkage and expansion - less chance for the boards to crack because the are allowed to move under the batten. Wait one season then prime and paint this give the boards ample time to air dry.
Depending on how long you want your siding to last you could go with SYP or Poplar both which will last several years, white oak may outlast me. Other good choices are sycamore and cypress - sycamore like white oak and cypress is quite rot resistant and will hold up for a long time to come. Use hot dripped galvanized 12 and 16d screw shank nails to help prevent nail pop.
Talk to Ivey or Randy (Wood Butcher) they are not all that far from you - I'm sure one of them will hook you up.
Later |
04-21-2008, 11:22 PM
#7 |
Name: John City: Efland State: NC County: Orange Join Date: Apr 2008 Avg Visit Freq/Week = 0.00 over 180 days | Re: Rough Cut lumber for equipment shed needed Thanks to all for sage advice. Jeff, I appreciate your detailed description of how to do board-and-batten right. Does anyone have Ivey's contact information? He may be the best bet, though I wish there was someone even closer. Sea Level is about 2-1/2 hours from Burgaw--could be worse. John |
04-21-2008, 11:36 PM
#8 | | Executive Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 67 Avg Visit Freq/Week = 6.88 over 180 days | Re: Rough Cut lumber for equipment shed needed Moses,
Click on Where Are? on the upper Menu Bar and then on NC Sawyers for the names of sawyers across the state, by region. You'll find Ivey in that listing with his contact info.
__________________
Rob Payne  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
04-22-2008, 07:52 AM
#9 |
Name: John City: Efland State: NC County: Orange Join Date: Apr 2008 Avg Visit Freq/Week = 0.00 over 180 days | Re: Rough Cut lumber for equipment shed needed Thank you Rob! --John |
Posting Rules
Members: 3,663
Threads: 25,105
Top Poster: DaveO (14,701) | | Welcome to our newest member, Keith Senderak | |
