09-15-2006, 04:19 PM
#1 |
Name: David City: Columbus State: OH County: Franklin Join Date: Sep 2006 Avg Visit Freq/Week = 0.39 over 180 days | I am looking for an electric chainsaw sharpener - preferably the type that uses a thin grinding wheel.
Thanks,
David |
09-15-2006, 04:28 PM
#2 |
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 5.87 over 180 days | I got one for about $20, a McCullough (spelling) that runs on a 12V battery from sears. |
09-15-2006, 05:01 PM
#3 |
Name: David City: Columbus State: OH County: Franklin Join Date: Sep 2006 Avg Visit Freq/Week = 0.39 over 180 days | Do you have any pics or a link to what it looks like ?
Thanks |
09-15-2006, 05:35 PM
#4 |
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 5.87 over 180 days | |
09-17-2006, 06:45 AM
#5 |
Name: Bernhard Lampert City: Rougemont State: NC County: Person Join Date: Sep 2005 Age: 48 Avg Visit Freq/Week = 6.84 over 180 days | Bought one from Harbor Freight quite awhile ago. Runs on line voltage, it is called 'Nick the Grinder', made in Italy was about $79 on sale and works well. Meanwhile the HF offers a reversed engineered copy `Made in China` for about $39 on sale at regular intervalls, the replacement grinding wheel is $9.99. The version that I have works well, but if used for all sharpening, you will shorten chain life a lot. I usually touch up the chain with a file and guide (Stihl guide) every time I fill up the saw. Once I get some nicks in the chain, I grind it.
PS The Stihl dealer on Raleigh on Morgan St has a half price sale on Stihl chains and other accessories every fall (October??). I usually stock up at that time.
Bernhard |
09-17-2006, 11:23 PM
#6 |
Name: dick cunningham City: Apex State: NC County: Chatham Join Date: Jul 2006 Age: 68 Avg Visit Freq/Week = 6.11 over 180 days | If you have a dremal, they have a grinding wheel and guide for about $19.00 as I remember from way back. It did a good quick job of bringing a chain back to life.
dick
__________________
Hold on tight to your dreams. "ELO"
09-18-2006, 02:25 PM
#7 | | Director Moderator
Name: Roger City: Durham State: NC County: Durham Join Date: Jul 2005 Age: 62 Avg Visit Freq/Week = 6.53 over 180 days | The Dremel (or any rotary tool) with the approporiate sized grinding stone works great for me! It only takes a few minutes to "touch up" the blade and IMHO you don't need a guide. It's pretty easy to line up the stone with the tooth.
Roger
__________________
I ain't never had too much fun!
09-18-2006, 06:20 PM
#8 | | Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 66 Avg Visit Freq/Week = 6.84 over 180 days | Originally Posted by sapwood The Dremel (or any rotary tool) with the appropriate sized grinding stone works great for me! It only takes a few minutes to "touch up" the blade and IMHO you don't need a guide. It's pretty easy to line up the stone with the tooth.
Roger Roger, and others: I use a Dremel tool as well, but here's a hint to help keep the teeth at a constant angle without a guide (always the best method). I tighten the blade so there is no slop as one normally has when cutting; this keep the teeth from canting to the side as you sharpen. This also work when using a round file. I always start at the first tooth past the index point (chain symmetry changes) and do all the teeth on one side and then repeat for the second side. If you angles are consistent, the saw will cut straight as an cleaver. BTW, don't forget to reset the blade tension when you finish to reduce bar wear.
HTH -- Rob
__________________
Rob  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
Posting Rules
Members: 2,322
Threads: 17,312
2nd Top Poster: jeff... (6,607) | | Welcome to our newest member, Git-wood | » Today's Birthdays | |
None
