01-12-2008, 07:10 PM
#1 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 180 days | Not the fill/float mechanism, nor the flapper or seals, but the internal piping of the toilet. I have a toilet that just won't flush right. Everything is working as it should fill and flapper-wise. I have checked the drain path beneath the toilet and it drains just fine. But the toilet still won't flush. It fills up with water like it's clogged. It will slowly drain back down to normal but there is no "cyclonic" flushing action that could carry waste away.
I would hate to go out and get a new toilet (cutting into my tool/wood budget) and find that there is an easy fix.
Dave
__________________   Nothing left to do but smile, smile, smile
--Dr. Seuss
01-12-2008, 07:51 PM
#2 |
Name: Nick City: Tarboro State: NC County: Edgecombe Join Date: Nov 2006 Age: 66 Avg Visit Freq/Week = 6.88 over 180 days | There's a special auger for toilet's, it's "U" shaped and will telescropes into the toilet. I would try one of these first. If it not leaking onto the floor its "MOST LIKELY" OK.
__________________ Two Twenty Two Rule:
2 Weeks to think about it...
2 Hours to fixture it...
2 Minutes to cut it.
Sharp tools cut fast and true
01-12-2008, 08:16 PM
#3 |
Name: allen City: Plymouth State: NC County: Washington Join Date: Jan 2007 Age: 43 Avg Visit Freq/Week = 1.56 over 180 days | dave i dont think a toilets internal plumbing can go bad,as it is cast ceramic.however,i had the same problem a few years back.i went to lowes,picked up a toilet snake,and after fishing out 30 or 40 baby wipes the toilet flushed like new.by the way,nobody musta flushed em.between nobody and notme,a lot of unexplanable things seem to happen around here.boy those guys keep me busy
__________________ no i dont need that new tool.but i must have it nontheless! |
01-12-2008, 08:26 PM
#4 |
Name: Robert City: Youngsville State: NC County: Franklin Join Date: Oct 2007 Avg Visit Freq/Week = 6.03 over 180 days | Dave, there is almost certainly something in the gooseneck of the toilet . Shampoo bottle cap, piece of soap , toothbrush ......the list is endless. As an apartment maint man for 20 yrs, you would not believe some of the things I have removed from toilets
the toilet auger should fix it . Wish you were closer ...I have one
__________________
...~Robert~
It ain't scrap till I say it's scrap ! |
01-12-2008, 08:36 PM
#5 |
Name: Bernhard Lampert City: Rougemont State: NC County: Person Join Date: Sep 2005 Age: 48 Avg Visit Freq/Week = 6.81 over 180 days | If all drain passages are clear, one other possibility is a plugged vent. The way you described the problem, it sure could be a vent problem.
Cheers,
Bernhard |
01-12-2008, 09:57 PM
#6 |
Name: jeff... City: Stovall State: NC County: Granville Join Date: Mar 2006 Avg Visit Freq/Week = 6.81 over 180 days | Could be a barbie doll in the goose neck? With all the kids I raised, you would be amazed what the toilet auger has found. Get yourself a good one your gonna need it
__________________ "Do, or do not. There is no 'try'." -- Jedi Master Yoda |
01-12-2008, 10:07 PM
#7 | | Webmaster Director
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 Avg Visit Freq/Week = 7.00 over 180 days | Yep, I think I'll have to try and auger the beast out of it. I couldn't understand how the inner workings of a toilet could malfunction, but I can't get the water to drain from point A to B within the toilet itself   .
As Scott so eloquently stated...you folks really know your s#*t
Dave
--Dr. Seuss
01-12-2008, 10:15 PM
#8 |
Name: Jerry City: Salisbury State: NC County: Rowan Join Date: Feb 2006 Avg Visit Freq/Week = 6.88 over 180 days | If it is a flat lid like seals a canning jar (which we experienced one time) the auger may not move it. We had to have a plumber remove the toilet and actually dump the lid out.
Hope you can auger yours to new function.
Jerry
__________________
We make a living by what we get...............We make a life by what we give
01-12-2008, 10:48 PM
#9 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.26 over 180 days | The first thing I check on a service call is the water level in the tank. Remove the lid and look on the right rear wall of the tank. There is usually a line indicating where the tank is supposed to fill to. If water isn't up to the line, toilet won't flush properly. If you have HEAVY mineral build up under the rim of the bowl, this too can affect flushing action. Seldom is this a problem though. Plumbing- where a flush beats a full house. |
01-12-2008, 11:00 PM
#10 |
Name: jeff... City: Stovall State: NC County: Granville Join Date: Mar 2006 Avg Visit Freq/Week = 6.81 over 180 days | Originally Posted by walnutjerry If it is a flat lid like seals a canning jar (which we experienced one time) the auger may not move it. We had to have a plumber remove the toilet and actually dump the lid out.
Jerry About the only place to get one around here is the BORG. they have two kinds one is more expensive better built (and longer) than the other. Spring for the more expensive (longer) auger. It'll actually get past the goose neck and down into the pipe a little and is strong enough to bust through the toughest 5h1t and yank out nasty barbie dolls with out much trouble...
01-12-2008, 11:39 PM
#11 |
Name: Jimmy Coull City: Clayton State: NC County: Johnston Join Date: Sep 2006 Age: 49 Avg Visit Freq/Week = 6.26 over 180 days | Dave,
When my FIL(plumber for 45 yrs.) was visiting and working on my toilet I asked him that exact question ( I had to know) and his answer was yes. During his career he had a few toilets that he had changed everything on and still couldn't get to work, when he changed out the toilet itself everything worked.
Hope that helps.
Jimmy
__________________
Jimmy "There are no strangers here, only friends that haven't met " I only buy what I need now, not what I want..... except for lumber ! Remember: Support your local Sawyers and Kiln Operators. |
01-13-2008, 12:07 AM
#12 |
Name: Robert Arrowood City: Mount Holly State: NC County: Gaston Join Date: Nov 2006 Age: 49 Avg Visit Freq/Week = 6.49 over 180 days | Dave is that the same toilet that was giving trouble in your other thread? If so you probably have a problem on down the line. Are any of the sinks having trouble draining? If so you may need the septic tank pumped. Good luck I know how it is to have plumbing problems. |
01-13-2008, 08:49 AM
#13 |
Name: Fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 51 Avg Visit Freq/Week = 7.00 over 180 days | have you counted your elves lately? if they aint all accounted for just dangle a pen blank over the comode and whistle real loud!  yaeh that otta do it!  |
| | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 2,296
Threads: 17,201
2nd Top Poster: jeff... (6,579) | | Welcome to our newest member, ejmArch | |
