North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Other > Off Topic
Off Topic Our new off topic forum. This is the place to discuss non-woodworking or non-site related topics. Be advised that the posting rules for this forum are same as all other forums.
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 08-03-2009, 06:25 PM   #1
Oil Hardened Steel
Splinter's Avatar
City: Wallace
State: NC
County: Duplin
Threads: 172
Show Printable Version Email this Page   Quote this post in a PM to Splinter
Splinter Splinter is offline 08-03-2009, 06:25 PM
I recently purchased some Oil Hardened steel from Enco to make some lathe tools.
I understand that the steel needs to be hardened to make it hard and hold its edge. I have read that you heat it to 1500 degrees (at this point a magnet will not stick to it) and dip it in peanut oil for several minutes to hardened it.
Has anyone here done this and if so, what process did you use?
__________________
You can't work without tools.
So many tools so little money.
Old 08-03-2009, 07:09 PM   #2
City: Lincolnton
State: NC
County: Lincoln
Threads: 16
Avg Visit Freq/Week
= 6.30 over 151 days
Re: Oil Hardened Steel
Short answer:
If you bought "hardened" steel from Enco all the processes necessary should have been done by Enco and you should just have to cut the steel to the lengths you want and grind the edge you want. Same as I do for my metal lathe.
Long Answer:
Without getting into too much detail (we can later if you want) you have to take a few things into consideration and you have to harden THEN temper or you will have a brittle tool that will break easily.
So, considerations:
1. Carbon or Alloy Steel - Carbon steel is hardened using brine or water as the quencher and alloy steel is hardened using oil as the quencher.
2. Carbon steel when hardening needs to be cooled to below 1000* F within 1 second, if it's longer pearlite will form on the part and peralite is softer than the martensite that will form if cooled below 1000* within 1 second. Alloy time limit increases above the 1 sec time limit and is also dependent on the temp the alloy is heated to.
3. Max hardness for steel is Rc53, above that it just gets more brittle and has to be tempered more.
4. Heating should be done in steps. i.e. If you are wanting a temp of 1500* you should go to 600* slowly let is "soak" then bump to 1200* or so let it soak again then quickly go to the final 1500*. depending on the makeup of the part, size etc. there are formulas for the soak times.
5. As stated above after heat treating you must temper the steel or it will break easily being so brittle. There are steps and formulas there as well that should be followed.
I won't bore you with more details at this point, but wanted to point out that there is a science to hardening steel and if it's just a chunk of steel that say you want to use as an anvil you may get away with just heating it and dipping it in oil, but if you are talking about a lathe tool that will have stress applied and if it breaks could fly off and kill you I'd make sure you do it right.
Hope that helps.
Dan
Show Printable Version Email this Page   Quote this post in a PM to mxracer
Old 08-03-2009, 11:05 PM   #3
Site Programmer
froglips's Avatar
City: Hillsborough
State: NC
County: Orange
Threads: 430
Avg Visit Freq/Week
= 7.00 over 180 days
Yupper, not a simple question to answer.
It would help if you could share the Enco part number.
I'd also suggest looking at some of the metalworking DVD's for rent over at smartflix.com They have quite a few that cover this topic in greater detail.
Its loads of fun though, and you get to play with fire!!
__________________
"Why is it that I loathe washing dishes, but I absolutely love sitting out here in the shop washing parts with kerosene?"
Roger Welsch, Busted Tractors and Rusty Knuckles
Show Printable Version Email this Page   Quote this post in a PM to froglips
Old 08-04-2009, 09:17 AM   #4
CarvedTones's Avatar
City: Cary
State: NC
County: Wake
Threads: 189
Avg Visit Freq/Week
= 6.53 over 180 days
Take a look at this page:
http://caribooblades.homestead.com/makingahook.html
It is about makinga carving tool, but has a very good (IMO) explanation and instrustions for annealing, hardening and tempering that I have seen. Getting a piece of ceramic wool is on my to do list; in fact, I need to go post that on the "where can I find?"
__________________
-Andy
Wag more - bark less.
http://www.CarvedTones.com
Show Printable Version Email this Page   Quote this post in a PM to CarvedTones
Old 08-04-2009, 10:17 AM   #5
Administrator
toolman's Avatar
City: Hookerton
State: NC
County: Greene
Threads: 68
Avg Visit Freq/Week
Well you probably got O1. The best way to harden it your self is heat it up cherry red and keep it cherry red for about 5 - 10 min. then put it in oil and move it around and around, then let cool on a table.. Then when your wife is not looking turn your oven on 300, once the oven is preheated put the part in the oven for about 45 mins to a 1 hr. let cool and it should be about 46 to maybe 50 Rc..
If you want to heat treat it right? Send to East Carolina Heat Treat..
or If you no someone with a heat treat oven they can get it up to 58 Rc.
Most all punch and shear die are made of O1, A2, or D2 harden to 58 Rc. I have made 100s in my life..
__________________
Chad
Pen turning is fast and fun!
It is highly addictive!
All your free time you once had will become a thing of the past!!
And Down The Dark Side Of Woodworking You! Will!
ooooo!!
Show Printable Version Email this Page   Quote this post in a PM to toolman
Old 08-04-2009, 08:23 PM   #6
Splinter's Avatar
City: Wallace
State: NC
County: Duplin
Threads: 172
Avg Visit Freq/Week
= 5.09 over 180 days
Correction on the description I gave for the metal I bought. It is "Oil Hardening" not "Oil Hardened" as I stated in the first post. One piece is "Air Hardening".
Item # 416-0369 http://www.use-enco.com/CGI/INSRIT?PMAKA=416-0369
Item # 415-1099 http://www.use-enco.com/CGI/INSRIT?PMAKA=415-1099
Item # 416-0473 http://www.use-enco.com/CGI/INSRIT?PMAKA=416-0473
Item # 506-0229 http://www.use-enco.com/CGI/INSRIT?PMAKA=505-0229
__________________
Old 08-05-2009, 06:05 AM   #7
Administrator
toolman's Avatar
City: Hookerton
State: NC
County: Greene
Threads: 68
Avg Visit Freq/Week
As Per my Post-
Home Hardening of O-1
Home Hardening of A-2
The best way to harden it your self is heat it up cherry red and keep it cherry red for about 5 - 10 min. then put on a steel block or table, and let cool. Then when your wife is not looking turn your oven on 300, once the oven is preheated put the part in the oven for about 45 mins to a 1 hr. let cool and it should be about 46 to maybe 50 Rc..
__________________
Chad
ooooo!!
Old 08-05-2009, 09:18 AM   #8
Splinter's Avatar
City: Wallace
State: NC
County: Duplin
Threads: 172
Avg Visit Freq/Week
Thanks Chad.
__________________
Old 08-07-2009, 11:43 AM   #9
City: Davidson
State: NC
County: Cabarrus
Threads: 17
Avg Visit Freq/Week
= 2.92 over 180 days
When dunk it oil be sure to move tip to back and never side to side. Side to side action could and probably will warp the piece. If done properly O1 can reach the mid 60's in RC before tempering.
Here is a very good link on heat treating O1 http://www.threeplanes.net/toolsteel.html
Another good link with lots of info http://www.crucibleservice.com/esele...eralpart2.html
__________________
If it isn't broke then I haven't tried to fix it....
Putting the 'fun' back in dysfunctional!
Show Printable Version Email this Page   Quote this post in a PM to BarryC
Closed Thread
hardened , oil , steel
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Win a Steel City saw jglord Found for Sale/Hot Deals 22 10-27-2008 06:34 PM
Steel Shim Stock rick7938 Power Tools and Their Use 9 07-08-2008 08:21 PM
Looking for some used steel roofing.... Tom Dunn Where Can I Find, Buy or Sell 12 03-05-2008 07:34 PM
Starrett 20-24 24" hardened steel square sapwood Found for Sale/Hot Deals 7 12-03-2007 10:06 AM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
