North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > "How To" Forum
"How To" Forum Share your tips, tricks and answer that age old question...."Just how in the world did you do that?"
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 11-23-2008, 08:42 AM   #1
Taper Sled
Joe Scharle's Avatar
City: Holly Springs
State: NC
County: Wake
Threads: 159
Show Printable Version Email this Page   Quote this post in a PM to Joe Scharle
Joe Scharle Joe Scharle is online now 11-23-2008, 08:42 AM
Here's the GET STARTED for the taper jig:
For ease of use, it is aligned on both sides with the blade. Simply set a mark to the edge, tighten the hold downs and cut. Tilt the blade away from the jig and make compound miters as well. The jig does NOT use the fence.
Most table saws have about about 11+ inches between the miter slots. If this is your situation, then you can use these instructions.
1. Take a slab of 3/4" BB (melamine should work too) 13" X 36" and lay it snug and square against the blade on the LH side.
2. Make a mark on the leading edge (edge that hits the blade first) of the slab, over the CENTER of the miter slot. Mark this edge as the LEADING EDGE.
a. Now place the slab snug and square against the blade on th RH side.
b. Make a mark on the LEADING EDGE over the CENTER of the miter slot.
3. Plow a shallow dado on the bottom of the slab, CENTERED between these marks, about 1/16" deep, wide enough for YOUR miter runner (usually 3/4") BE EXACT.
4. 5" from each end, on the top of the slab, cut a dado to accept YOUR T-track. Wide enough - deep enough for a snug professional fit. These tracks are where you attach the fence.
5. Mount a runner; leave an inch or so protruding from the LEADING EDGE so you'll never confuse the LEADING EDGE. Mark with an arrow or something.
NEVER GET CONFUSED about what is the LEADING EDGE!
Before the next Step. Check that the blade is 90 degrees.
6. With the runner in the respective miter slots, LEADING EDGE first, trim off each side.
__________________________________________________ ___________
Rip a 2" wide X 36" long fence. Be critical that both sides are square and true. Rout a groove for the T-track that mounts the hold downs and stop block, down the center like this. You'll need 2 slots for the fence lock down. The slots give the fence a range of motion. 2" are long enough. Note the reliefs in the center allow for the tracks bolts removal/installation.
Instead of stopped dados, you can plow a continuous groove and glue in blocks with slots for the fence lock downs.
Optionally, you can skip the fence T-track and mount toggle hold downs and bolt a stop block on the fence end.
Old 11-23-2008, 09:29 AM   #2
WoodWrangler's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 520
Avg Visit Freq/Week
= 6.92 over 180 days
Re: Taper Sled
Thanks for this how-to, Joe ... I like the look of that adjustable tapering jib!
For those who don't have one and are thinking "I'll just get one of the cheap metal ones" that they sell ... DON'T. They aren't so safe and this would be a better bet.
Show Printable Version Email this Page   Quote this post in a PM to WoodWrangler
Old 11-23-2008, 10:29 AM   #3
MikeL's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 49
Avg Visit Freq/Week
= 5.72 over 180 days
Re: Taper Sled
Joe, thank you for posting this! I had been looking at taper jigs recently. This does look like a much better solution. When is your next class?
Show Printable Version Email this Page   Quote this post in a PM to MikeL
Old 11-23-2008, 10:51 AM   #4
Bas is offline Bas
Senior Administrator
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Avg Visit Freq/Week
= 6.96 over 180 days
Re: Taper Sled
This Saturday. I'm heading out to get a sheet of melamine today and get started on the homework Boy I can't remember the last time having homework was fun!!!
__________________
Bas.
I don't need it. I just want it.
Show Printable Version Email this Page   Quote this post in a PM to Bas
Old 11-23-2008, 10:56 AM   #5
City: Holly Springs
State: NC
County: Wake
Threads: 159
Avg Visit Freq/Week
= 7.00 over 180 days
Re: Taper Sled
A couple of folks have indicated they want to get together Saturday after Thanksgiving 11/29 1-5. If you want to attend, let me know.
Old 12-03-2008, 04:34 PM   #6
City: Holly Springs
State: NC
County: Wake
Threads: 159
Avg Visit Freq/Week
Re: Taper Sled vs Dubby
Just to compare my jig with the Dubby, I ordered one from Peachtree last week when they were $59.95. Put it together this AM and cut 4 short legs. Compared to my shop built jig:
The sled is a Melamine covered 1/2" (metric equiv) but the core is stiffer than I can buy from the BORG. Minimal significant value.
The fence is 1/2" (metric equiv) extruded aluminum. Significant value.
It's anchored to the sled at 3 points along channels routed underneath, which is probably more secure, but makes adjusting the fence a little cumbersome. The middle anchor gets in the way of moving the hold downs. To cut anything over 3/4" thick, I had to make 1/2" ply riser blocks for the hold downs.
The miter track runner has the anti-tip buttons on each end and 4 bullet head set screws for snugness. This is a one size fits all compromise and the value may or may not be significant to another user. With 4 pre-drilled runner positions, it should be adaptable to any saw. Significant value. If your saw has standard cabinet saw miter channels, the sled can be trimmed to run in either side. Significant value.
The main drawback for me is that I can't run the legs 'back wards' due to the design of the stop (would get cutoff) and it places the rear hold down in-line with the blade. Negative significant value. My work around was the little 1/2" ply blocker on the LH side of the blade.
At $59.95, I feel this jig has good overall value, especially for those without the tools to plow slots and T-track channels easily. However, I think that if I could find a fence like the Dubby at a reasonable price, my version could be made by any woodworker easily and quick.
Old 12-03-2008, 06:28 PM   #7
Bigdog72's Avatar
City: Lillington
State: NC
County: Harnett
Threads: 118
Avg Visit Freq/Week
Re: Taper Sled
Joe,
I'm thinking something like this could work as a fence. Your thoughts?
http://www.woodpeck.com/supertrack.html
__________________
LET'S GO RED SOX!!!!!
WORK EVERYDAY LIKE YOU DON'T NEED THE MONEY!!
Show Printable Version Email this Page   Quote this post in a PM to Bigdog72
Old 12-03-2008, 06:47 PM   #8
City: Holly Springs
State: NC
County: Wake
Threads: 159
Avg Visit Freq/Week
Re: Taper Sled
$40.00 for 36 inches!
I was thinking along the lines of $10-20 myself. I've seen these channels online somewhere, but cannot call it up. Maybe someone will have a brain flash.
Old 12-03-2008, 08:01 PM   #9
Bas is offline Bas
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Avg Visit Freq/Week
Joe, thanks for a very honest jig comparison. For $59.95, the jig is definitely a good deal. If you add the cost of melamine, T-track, hold downs, knobs & other hardware, you're up to $30 - $35. Add to that the wear and tear of your router bits, drill bits, electricity etc. and the savings are minimal. I like how easy it is to modify the fence on the shop-made jig, but that aluminum fence does look nice.
Both will get the job done.
__________________
Bas.
Old 12-03-2008, 08:32 PM   #10
City: Vass
State: NC
County: Moore
Threads: 6
Avg Visit Freq/Week
Re: Taper Sled
Thanks Joe. Do you have any pictures posted somewhere of your jig? Looks like there were supposed to be two with you post but when I clicked on the boxes it indicated photos could not be found. I'd really like to see your jig as I am hoping to make one.
Show Printable Version Email this Page   Quote this post in a PM to woodlaker2
Closed Thread
sled , taper
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
near perfect round taper CarvedTones Woodcarving 12 04-03-2008 10:58 PM
Taper Jig Joe Scharle "How To" Forum 3 02-17-2008 03:11 PM
taper jig for tablesaw alleng Power Tools and Their Use 9 03-27-2007 05:52 PM
Taper jig mshel General Woodworking 8 03-06-2007 10:28 PM
Double taper planer jig adowden General Woodworking 6 12-17-2006 11:22 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,105
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
