North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > "How To" Forum
"How To" Forum Share your tips, tricks and answer that age old question...."Just how in the world did you do that?"
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 03-31-2009, 01:02 PM   #1
Shop made oval jig
wdkits1's Avatar
City: Midlothian
State: VA
County: Chesterfield
Threads: 42
Show Printable Version Email this Page   Quote this post in a PM to wdkits1
wdkits1 wdkits1 is offline 03-31-2009, 01:02 PM
Ever wondered how to make a perfect oval? Well one day as I was looking through a woodworking catalog I saw
a little gizmo for $19.95 just for that purpose. Being the cheapskate that I am I decided to make one.The prototype worked all-right but by making a few modifications and a few different sized jigs I can now make any sized ovals or circles that I need for use in my woodworking.
Start by cutting a piece of 4/4 stock into a perfect square blank.The one I made is a piece of mahogany cut 5"x5" .On the router table route a 1/4" groove 3/8" deep in the center running in both directions. Flip around and do it again so that both grooves are perfectly centered.
Next set up a dovetailing bit and do the same thing so that the bit widens the original grooves again routing in both directions to center the cuts.
Cut a piece of stock about a 1/4" wider than the widest part of the dovetailed groove. Move the router fence over so that you take out a portion of the stock on both sides to make the cams that will slide in the grooves. Sneak up on making the cams fit by adjusting the fence until the cams slide easily in the grooves.
The next photo shows that I have cut the cams to equal length and drilled a centered pilot hole. I then trimmed the corners of the jig and applied my favorite workshop lube (Pam) to the cams.
The next photo shows the adjustable arm layout. A series of holes drilled 1/2" apart are used to determine the axis which the cams will follow to give the length and width of the oval. The larger holes are used to hold the pencil.
The next photo shows the assembled jig ready to go. I use double sided tape to secure it to the workpiece, in this case a cardboard pattern. This position of the arm gives 1/2 of the length of the oval.
The next photo shows the position of the arm for 1/2 of the width of the oval. By adjusting the position of the screws on the cams you can adjust length and width of the oval.
The next photo shows a perfect oval drawn with the jig.
To draw circles with the jig ,remove one cam and using a longer screw through the other cam to bottom out and lock into the center position of the jig.
Pieces made with shop made oval making jig.
Intarsia of Mabry Mill
Custom marble top coffee table—Brazilian cherry,Peruvian walnut, Bloodwood, Holly.
__________________
wdkits1
www.midlothianwoodworks.com
"why buy it if you can build it"
Old 03-31-2009, 01:45 PM   #2
nelsone's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 158
Avg Visit Freq/Week
= 6.34 over 180 days
Re: Shop made oval jig
Cool jig! I've always used the 2 nails and a string method.
__________________
Never take life seriously. Nobody gets out alive anyway !
Show Printable Version Email this Page   Quote this post in a PM to nelsone
Old 03-31-2009, 03:03 PM   #3
Canuck's Avatar
City: Cary
State: NC
County: Wake
Threads: 171
Avg Visit Freq/Week
= 7.16 over 180 days
That is really cool.
I might just try one for myself!
Maybe you should send the idea in to the magazines.
Great tip!!!
Thanks for sharing,
__________________
..............found out many years ago that Elbow Grease doesn't come in a bottle!!!!
Show Printable Version Email this Page   Quote this post in a PM to Canuck
Old 03-31-2009, 10:41 PM   #4
steviegwood's Avatar
City: Arthur
State: WV
County: Grant
Threads: 69
Avg Visit Freq/Week
= 5.60 over 180 days
You should make up several of those and put them up for sale. I would take one off of your hands. I am not sure if I can get one made myself but will have to give that a try. Thanks for the step by step instructions. Steve
__________________
" If This Hillbilly Can't Fix It, Then It Ain't Broke " http://www.kodakgallery.com/Slidesho...e&conn_speed=1
Show Printable Version Email this Page   Quote this post in a PM to steviegwood
Old 03-31-2009, 10:52 PM   #5
Trent Mason's Avatar
City: Wrightsville Beach
State: NC
County: New Hanover
Threads: 81
Avg Visit Freq/Week
= 6.77 over 180 days
That is really cool Mike! Thanks so much for sharing and the projects you made with it are AWESOME!
Trent
__________________
Trent
"By the waterside I will lay my head......"
"We should never separate the lives we live
from the words we speak."
— Paul Wellstone
Show Printable Version Email this Page   Quote this post in a PM to Trent Mason
Old 04-01-2009, 07:19 AM   #6
Sully's Avatar
City: Washington
State: NC
County: Beaufort
Threads: 131
Avg Visit Freq/Week
= 6.07 over 180 days
Cool jig. File'n that one away on the to do list. Thanks for sharing.
__________________
Humility is being corrected by your 4 year old on a woodworking project.
Show Printable Version Email this Page   Quote this post in a PM to Sully
Old 04-01-2009, 10:21 PM   #7
RandyJ's Avatar
City: Macon
State: NC
County: Warren
Threads: 34
Avg Visit Freq/Week
= 5.44 over 180 days
Neat idea and neat projects built using it!
__________________
Randy
Any compromise between the truth and a lie can ONLY be something less than the truth.
Show Printable Version Email this Page   Quote this post in a PM to RandyJ
Old 04-01-2009, 11:06 PM   #8
Webmaster
Administrator
Senior Moderator
TracyP's Avatar
City: Salisbury
State: NC
County: Rowan
Threads: 332
Avg Visit Freq/Week
= 7.00 over 180 days
Really cool Jig, thanks for posting.
__________________
Tracy
Making Friends One Post At A Time
The task is always worthwhile if you learn something in the process.
Show Printable Version Email this Page   Quote this post in a PM to TracyP
Old 04-01-2009, 11:28 PM   #9
PChristy's Avatar
City: Lexington
State: NC
County: Davidson
Threads: 363
Avg Visit Freq/Week
= 6.92 over 180 days
Thanks for sharing Mike - that is a cool jig
__________________
Phillip
My Saw Is Making Dust
Time waits for no one. Treasure every moment you have. You will
treasure it even more when you can share it with someone special. (Arthor unknown)
Show Printable Version Email this Page   Quote this post in a PM to PChristy
Old 04-02-2009, 01:18 AM   #10
BobcatBob's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 11
Avg Visit Freq/Week
= 2.99 over 180 days
Really neat jig. Thanks for the detail pictures.
Bob
Show Printable Version Email this Page   Quote this post in a PM to BobcatBob
Closed Thread
jig , made , oval , shop
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Shop-made Trashcan Pre-Separator Lid KC7CN General Woodworking 28 11-13-2007 11:19 PM
Shop made skew chisels mshel Hand Tools and their Use 8 09-13-2007 10:37 PM
Shop-Made Table Saw Accessories KC7CN General Woodworking 6 02-26-2007 10:58 PM
Shop Made Router Lift junquecol Power Tools and Their Use 3 12-02-2005 04:52 PM
Oval Shaker Boxes rickc User Announcements 0 09-22-2005 10:52 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,105
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
