North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > "How To" Forum
"How To" Forum Share your tips, tricks and answer that age old question...."Just how in the world did you do that?"
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 09-03-2009, 09:41 AM   #1
PORTABLE BANDSAW STAND
JOAT's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 53
Show Printable Version Email this Page   Quote this post in a PM to JOAT
JOAT JOAT is offline 09-03-2009, 09:41 AM
Well, I ai'nt dead yet. That's a quote, if you question the spellilng. Been spending time with the guys that cut metal and decided that using an angle grinder to cut metal with, what with all the sparks and all, was too much of a PITA, so got myself a nifty HF portable bandsaw, and made a quicky stand for it. The stand want together nicely, and much faster than I'd anticipated, and now I can cut metal inside, with no sparks to set my shop on fire. Just an abundance of tiny little metal bits to sweep up later. This is not really a how to, it's how 'I' did it.
I made a 12"X12" base from two layers of 1/2" plywood - this will go on my take-apart workbench. I set the bandsaw on end on the base, to determine where I wanted it. The plywood block is for the saw to rest on, and raise it slightly so I can take the back on and off for changing blades.
What tha? This is the second photo, but it is now ahead of the first one. May have to make separate posts. Anyway, I cut an 'arm' that goes under the top handle, and for now is clamped to the piece of 4X4 that will be the column. Nothing glued yet, but it's steady enough to stand by itself.
OK, let's try it this way. The third picture is still just clamped, but turned.
I do not know how this got there, it belongs two pictures lower.
Vi
View image in gallery
ew image in gallery
Much better. This is the column glued where I want it, and another block, further over for the saw to sit on.
View 5. OK, still screwy things happening. Somehow got this one here, and above the other picture too. This is the arm that goes under the top handle and will be bolted to the column.
OK. Let's see if I can only get one copy of picture 6. Ah. This is the back of the column, I had to add a spacer because the bolts were a bit long.
Picture 7. And the view from the other side. I had one wingnut, but all the store had were nylon. If you look very closely at the base of the saw you can just barely see where I glued a block atop the base it sits on, because it had a tendency to shift just about 1/4" every once in awhile. The block will cure that.
And finally, the table for it. Actually this is what the table will look like. I'll trace the pattern onto plywood, cut it out, glue that on to more plywood, rout that out. I'll be drilling 3-4 holes in the blade guide, just visible in the slot in the pattern, then screw that to the table, and screw the guide back on the saw. But I figure if you can't figure out how to do that part on your own without more pictures, you're beyond help.
The stand is very steady, and I should be able to use the whole thing as a standalone, not just affixed to the top of my take-apart bench. The saw is variable speed, has a small wheel on the trigger to change speed. And, yes, it can be used for cutting wood, not just metal. It's got a trigger lock, and I found out you can change speed while the trigger is locked on. I'll be leaving it locked on because I got a foot control switch from HF for around $10, and it works like a charm.
If I hadn't refound that chunk of 4X4 I would have either laminated a column from bent plywood, sort of artsy, or made a hollow column same as I did with the bench. I had to buy bolts, because all I had on hand were just a tad too short. And the wingnut of course, had washers.
Ah yes, almost forgot, it's just right for sitting at the take-apart bench and working with it. That's more accident than on purpose, but still nice.
__________________
JOAT
Plans? Plans? Don' need no steenkin' plans.
Old 09-04-2009, 12:23 PM   #2
JOAT's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 53
Avg Visit Freq/Week
= 1.91 over 180 days
Re: PORTABLE BANDSAW STAND
Because the table came out different than planned, I thought I'd best post it also. The top of the piece I cut was much worse than I thought, so it is now in between the two pieces. That's excess glue running down, and the view the bottom of the table. I may paint the whole think yellow later.
__________________
JOAT
Old 09-04-2009, 12:50 PM   #3
Site Programmer
froglips's Avatar
City: Hillsborough
State: NC
County: Orange
Threads: 430
Avg Visit Freq/Week
= 7.00 over 180 days
Neat idea! Thanks for sharing.
Removes a few more of my "excuses" for not getting a portable bandsaw
__________________
"Why is it that I loathe washing dishes, but I absolutely love sitting out here in the shop washing parts with kerosene?"
Roger Welsch, Busted Tractors and Rusty Knuckles
Show Printable Version Email this Page   Quote this post in a PM to froglips
Old 09-04-2009, 01:16 PM   #4
JOAT's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 53
Avg Visit Freq/Week
I wish I'd got mine long ago, works like a charm, and it not very noisy. And NO sparks. Love that part. Before you use one tho, this has some good info, on any portable badsaw. http://www.shopfloortalk.com/forums/...ead.php?t=6214 On mine, the bearings were in place, but grease was quite lacking - and I would take it for a given that any other brand would be about the same; after all, they're probably all made in the same factory in China now. I greased everything that even looked like it could move. Definitely get some good bi-metal blades, I got a 3 pack at HF. I didn't even try the factory blade, but everyone seems to agree that they're bad news, sometimes breaking almost immediately. I will be putting the back on the saw before I use it. I got the variable speed model, and am happy.
__________________
JOAT
Old 09-04-2009, 03:44 PM   #5
RandyJ's Avatar
City: Macon
State: NC
County: Warren
Threads: 34
Avg Visit Freq/Week
= 5.44 over 180 days
Thanks for the How-To and the link, Theo. That's a great idea!
__________________
Randy
Any compromise between the truth and a lie can ONLY be something less than the truth.
Show Printable Version Email this Page   Quote this post in a PM to RandyJ
Old 09-04-2009, 07:47 PM   #6
JOAT's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 53
Avg Visit Freq/Week
No prob. I did a lot of research and all the stands I found were metal. Well, I don't have the metal, wasn't about to set up outside the shop and cut with the angle grinder with all the sparks anyhow, and my sons haven't let me see my welder in years anyway. But I've got wood. Printed out a couple of dozen pictures of different stands for guidelines. Then set my saw up on end and immediately saw how simple it would be, didn't even look at the pictures. Here is the first cut made with the new saw, before I started the stand. Fantastic, and not spark one. Could have done it with a hacksaw, but my joints wouldn't have liked that anymore, in fact the joints weren't thrilled with using the angle grinder either.
The cut could have been straighter, but I was standing up, and had the angle turned away from me. Turning the angle toward me would have made it much easier to see where the cut was going. I'm still very happy, because it was a rough cut anyway.
__________________
JOAT
Old 09-07-2009, 01:05 AM   #7
JOAT's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 53
Avg Visit Freq/Week
Was going to drill the holes in the blade guide to fasten the top on. And coldn't find my drillpress chuck key. Wound up buying one, then couldn't find my center punch. So drilled a hole thru the column so I could reach the last screw that holds the back on. You can also see I glued on a few more glue blocks, more than needed, to keep the saw from shifting - I didn't have a whole lot to do today.
The piece of wood is to show where the hole is, the flash pretty much made the hole vanish in pictures.
__________________
JOAT
Old 09-08-2009, 08:50 PM   #8
JOAT's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 53
Avg Visit Freq/Week
Re: PORTABLE BANDSAW STAND - Finished
Done. Holes drilled, top screwed on, blade guide screwed back in place. Just need to replace that back now. Nicely sturdy. Will now be able to proceed with a metal project I've been working on. And if it eventually doesn't work out, it will make a fancy coffee cup holder.
__________________
JOAT
Closed Thread
bandsaw , portable , stand
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Portable Torsion Box rick7938 General Woodworking 6 05-25-2009 09:14 PM
HTC Portable Miter Saw Stand $49 Shipped woodworker2000 Found for Sale/Hot Deals 4 05-21-2009 06:14 PM
Portable Bandsaw? WoodWrangler Power Tools and Their Use 4 02-12-2008 10:18 AM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,105
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
