Better Lumber By Drying at Home Inexpensively - PRE-PROCESSING LUMBER
Tarhead explained to me that some people cannot read the end of the long titles in the list of posts. So I shortened the title listed.
To get the best results when drying lumber at home it is best to do a number of steps of pre-processing before creating a stack.
Get the best green lumber possible by hand picking it.
If you are using a log and getting it sawn then you probably want to use every piece. If you have some lumber from it that is in decent shape or others that are infected or infested. It would be best to dry them separately.
If you are buying green lumber then I'd suggest finding a friendly lumber company yard that will sell the quantity you need, at a decent price. 1"x6"x16" green White Oak in this area goes for $5 or $6 a board. I only get lumber I can hand pick. I believe it is easily worth paying 50% more for lumber if you can chose each board yourself. (If you want a REALLY great deal on lumber then go to a yard with outdoor stacks. They stack high so that the weight of the wood on top keeps enough pressure on the lower stacks. Ask the yard manager about picking through a top stack. The top stack has the most weathering & too little pressure; therefore it will eventually produce lower grade lumber which means lower costs for you. They'll bring down the stack using a forklift. Since you hand pick what you want... the quality of this green lumber can be about the same as from lower stacks.)
Most green lumber will have some end checking. I would stay away from excessive end checking (Which I define as more than one, extending more than 3" down the board). Excessive surface checking means the wood has already dried too quickly or the tree was incorrectly felled. Dark areas than do not match the natural flow of the grain indicates probable infection. Then there are general features that you know whether it ruins or limits the use of the board in your application. i.e. Bad knots, excessive knots, major splits in the middle area, bad edges, etc. NOTE: These are personal decisions.
Planing both sides of the boards before stacking is important. USFS studies show better results with drying planed lumber. Too much surface area is your enemy. I am not going to prove or justify the next statement. (If you have taken a topology course then it is obvious... if you have not then it sounds ridiculous.) A rough sawn board has hundreds of times the total surface area of a smoothly planed board.
Planed Boards have many advantages when drying.
* - Infection or infestation is much more obvious.
* - Boards dry faster and much more evenly.
* - Boards are the same thickness. Therefore a tightly strapped stack will dry much flatter.
* - Liquid treatments to sterilize the lumber will penetrate more evenly and much less liquid is required.
* - The stack size and weight are lower.
Now is when I chemically sterilize the boards (see previous thread at
LINK ) Don't proceed until all of the chemicals have been removed/diluted.
You are going to need sticks in the stack for better air flow. The sticks should be made of the same timber as the stack. I choose the worst boards and set them aside at this time to be cut into sticks.
Boards dry most quickly at their ends. Drying too quickly is the primary cause of end checking. Since I dispose of the last few inches of ALL boards, I can treat the ends to reduce end checking. This is done by applying a moisture barrier. Everyone has their own favorite. I like water-based polyurethane because it penetrates well.
At this time I find it important to immediately create the stack and keep the rain off of it.
More to follow...
